Question about Kenmore 13202 Top Load Washer
Hi i have a kenmore washer approx. 30 years old serial #13294. the problem is when it fills up and is in the agitate cycle it slowly loses its water level
Amigaman
  • 248 Answers
SOURCE: Kenmore Washer
  If this is a Kenmore or Whirlpool washer less than 20 years old it may be a motor coupler.  This part couples motor to transmission.  It can also be a transmission that has a bad seal that is leaking oil onto the clutch.  In this case you need a new transmission and a clutch.
Posted on Oct 21, 2007
centurionin
  • 20 Answers
SOURCE: kenmore washer 80 series
you need to check the lid switch, does it click. you can unplug and then remove the 2 screws to see it, if it looks like it is coming apart then the lid switch is bad. you can buy one for about $40 or so dollars. i am assuming it doesn't spin either.
Posted on Dec 19, 2008
  • 65 Answers
SOURCE: Kenmore washer overflows during rinse cycle.
SOME OF THESE MACHINES HAVE TWO PRESSURE SWITCHES IN THEM, ONE FOR THE MAIN WASH WATER LEVEL AND ONE FOR THE RINSE WATER LEVEL. CHECK FOR A PLUGGED AIR PRESSURE HOSE FIRST AND THEN CHECK THE PRESSURE SWITCHES.
Posted on Jan 27, 2009
ned_san_jose
  • 234 Answers
SOURCE: Kenmore 90 Series fills with water but would not agitate or spin
You have a problem with the motor coupling. Top-load washers use what's called a direct-drive system, meaning it does not use a belt but what's called a "motor coupling". I probably replace 5 a week because these little guys break because of 2 reasons that i've found.
1) The break mechanism is too dry and causing the basket to stop at a holt, which puts a lot of strain on the coupler.
2) They break because of over-loading. I don't think you're over-loading though because it was find for 5 straight years.
Good luck to you. The repair is kind of hard to do on your own for the first time, so I would call an authorized technician. It will run you anywhere between $90 to $120 at most.
Best of luck!
Posted on Jul 16, 2009
  • 1122 Answers
SOURCE: Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
Posted on Jul 17, 2009
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
Doesn't agitate and spin cycle work when reset
you have a worn motor coupler
you can order a new one at sears
and its a ver y easy repair
Oct 06, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Doesnt agitate or spin.
Mine is 1 1/2 years old and this worked for me
unplug from power for at least 30 seconds
turn the dial to spin but don't pull out
plug back in to power and open and shut completely so switch is engaged solidly 11 times in 15 seconds.
pull out knob to turn on
This should clear a error code.
hope it helps!
Jun 02, 2009 | General Electric WHDSR316G Top Load Washer
Washer will not agitiate or spin
Motor coupler between motor and gearcase.
Mar 30, 2009 | Kenmore 24032\24036 Top Load Washer
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
Agitator always moving
The inner tub on some machines does rotate very slowly while filling to assist with the even distibution of the load. If the agitator is turning back & forth while in fill mode, you could have a timer or transmission problem. You need a tech.
Nov 04, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 13202 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
