Question about Soehnle 63530 Alpha Digital Bath Scale
I changed batteries on my soehnle digital bathroom scale and zero is now at 9.1 kg. How do I set it back to 0?
SOURCE: resetting the scale
You do not reset the scale. It only saves the last recorded weight of the user. So, if you weighed yesterday, it will put your recorded weight in memory. The next time you select your user number and step on the scale, it will compute the difference from your previous record and save your current weight.
Posted on Mar 25, 2009
fitnessbalan
  • 59 Answers
SOURCE: instruction manual soehnle scale
I have looked and maybe you have the model number wrong the scale you are talking about 63700 Calando Quattrotronic scale is a simple digital scale and does not provide bmi, and hydration.
here is a link to the manual, http://www.leifheitusa.com/manual/63700.pdfit is in several languages including english as the company is european and sells to many countries. If you look english is there it is a very simple manual as the scale is only desinged to weight in either lbs or kgs nothing more. Sorry. If you would like a bmi chart you can get that here http://www.healthdiscovery.net/links/calculators/body_massindex_chart.htm and figure out your bmi based on height and weight in the chart.
Posted on Apr 24, 2009
SOURCE: Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Posted on Oct 18, 2009
award462
  • 395 Answers
SOURCE: Free on line instruction manual for Soehnle scale
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
Posted on Jun 03, 2010
SOURCE: My Soehnle scale shows an out2 error - how do I fix?
How to calibrate when "out2" is shown.
With the power off andthe scale on a stable surface, hold "g" and press "on". Some number will show up, probably a negative number. Press the "on" button again and the scale should display "Zero". Wait until it says "200.0". Gently place a 200 gram weight on the scale and wait a few seconds. If your successful it will say "Pass" and your scale will work again, yay!
Posted on Jun 21, 2010
I just installed a new CR243 battery in my Soehnle bathroom scale, A red light came on inside, but nothing happens on the screen. Can you help?
Sometimes a CR2340 battery is still in it's package, but it may be very weak, even though it tests OK. Try another good battery.
Jun 15, 2017 | Soehnle Health & Beauty
Programming soehnle volga
If battery replacement did not help, the scale may have failed.
Sep 19, 2016 | Soehnle 63691 Volga WhiteGrey Body Balance...
How do i reset my digial bathroom scale
Remove all the batteries. In ones with memory, there are two sets, a 9 volt and 2 x AA.
The GNC WirelessWeight GS-7006 Digital Bathroom Scale accurately measures weight, body fat, water hydration, bone and muscle mass. This item features a removable wireless display that can be conveniently mounted on the wall, so you can see the readout clearly. Built with durability in mind, the scale is made from extra-strong tempered safety glass. The GNC bathroom scale also features an energy-saving auto on/off function and auto zero.
  • Removable wireless wall mount readout display
  • Measures weight, body fat, water hydration, bone and muscle mass
  • Energy-saving auto on/off and auto zero
  • Extra-durable tempered safety glass
  • Weight capacity: up to 330 lbs
  • Requires one 9V and 2 AAA batteries (included)
Jul 16, 2015 | GNC Digital Bathroom Scale
After inserting new batteries (CR2430) the display flashes E then alternates between 0.0 and 79.9
Had same and after short cirquit two contacts under silver sticker it started to calibrate, show 40 80 120 kg ...
Feb 08, 2011 | Soehnle Slim F5 Scale 63721
Jobar international JB5413 large cap. scale It shows in kg i want to change it to pounds.
press WT then press SET for 3 secs
then use up/down arrows to change between kg lb and st
when selected press SET again
Dec 07, 2010 | Jobar International Idea Works Wireless...
I replaced the 9 volt battery on my Soehnle scale and the display on the front reads 8888888 and stays that way, never going to 00. Please advise.
mcdevito75 here, You can try to disconnect the battery, then step on the scale then step off, Now re-install the battery and see how it works. If same contact scale manufacturer.
Jun 29, 2010 | Soehnle Linea Quattrotronic Digital...
My weighing scale is not working
try checking the battery and installing a new one
Jan 12, 2010 | Soehnle Linea Quattrotronic Digital...
I changed the battery on bathroom scale Salter 987
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
Jul 21, 2009 | Salter Stainless Steel Electronic Bathroom...
How to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
Jul 08, 2009 | RTO Pelouze Scale With Remote Display -...
Soehnle 63530 Alpha Digital Bath Scale Logo
42 people viewed this question
Top Soehnle Health & Beauty Experts
Tom Chichester
Greg P
Greg P
jerry sheehan
jerry sheehan
Level 1 Expert
Are you a Soehnle Health and Beauty Expert? Answer questions, earn points and help others
