Question about Dell Latitude D600 Notebook
My usb ports are not working when i check the drivers ter is no problem with drivers pls send proper solution
  • 613 Answers
Restart your computer. Also you may try to download a free registry cleaner. ccleaner is one.
Posted on Nov 08, 2010
USB PORTS NOT WORKING
try to update or download the usb cord of your laptop
Nov 27, 2013 | Toshiba Satellite C655-s5090
NOT PRINTING OUT OF DOS PROGRAM
The problem is, the DOS program tries to print to LPT1, which is your parallel port. We need to redirect this to your USB Port. First, you have to set up printer sharing: Go to Control Panel | Printers | Your printer and share the printer. Assuming that you share it with the share name "MYPRINTER" and the computer is called "MYCOMPUTER", then type go to Start | Run and type in: NET USE LPT1: \\MYCOMPUTER\MYPRINTER /PERSISTENT:YES That should do the trick, unless there's a driver problem, which is unlikely for a dot matrix printer. If that doesn't work, let me know and I can troubleshoot further.
Sep 09, 2007 | Panasonic KX-P2130 Matrix Printer
My hddr640e04xr is not detected
You don't need to have a driver for your external HDD to work.
You have three possible problems:
1. USB port (software problem) - outdated USB driver or with bugs
Try updating them via the device manager. Or you can try uinstalling it then scan for hardware changes. It will automatically reinstall.
2. USB port (hardware problem) - try a different USB port.
3. HDD defective - You may want to try connecting it to a different computer. If it doesn't work in a different computer then it should be defective.
David
Feb 20, 2013 | Computers & Internet
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
USB port not sensing after reinstalling windows xp, drivers are installed properly. not able to use usb stick, tried to access cam with usb port, nothing is working. pls help email id :...
Check your Device Manager "Start > Run > devmgmt.msc" you may have not installed controllers for your motherboard. Look for "!" and install the drivers using your motherboard driver disk. If driver CD is not available you can download updated drivers from Gigabyte Support Site.
Hope this helps.
Jan 04, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
I lost my CD for my Netopia USB wireless router
go to windows update after you have installed netopia usb adapter and do custom scan and it will bring up ralink 2500 usb driver install that and it will work netopia usb adapter i think it has ralink chip but it works with mine
Mar 28, 2009 | Netopia 3-D Reach (TER/GUSB-N1)...
Linux driver for netopia 3D reach USB adapter
check here
http://www.tuxpages.com/helppages/gentoo-wireless-3d.shtml
Dec 26, 2008 | Netopia 3-D Reach (TER/GUSB-N1)...
Dell Latitude D600 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
