Question about Honda Car Audio & Video
How to change clock time on 2006 Honda Element
2 Suggested Answers
  • 244 Answers
SOURCE: what needs to be done for 2006 honda element with
100k check air filter, have timing belt inspected, rotate tires, plugs and wires should be good for another 20-30 but doin it now would not hurt. Have an intake cleaning done. There's a intake cleaner TKO that works well.
Posted on Apr 25, 2010
2006 honda element transmission not shiffting to 3rd gier I have code po970 that is the pressure control solenoid "C" but may is other problem
I have seen this code several times and usually it is the 3 shift solinoid, I have however had a transmisson that wwas bad and also one with a wiring issue to the solinoid.
May 23, 2011 | 2006 Honda Element
How do I find the code for my 2006 Honda Element so I can reset after changing the battery. I never received one when I purchased the car.
I had this same problem before and I did not have the code.I called a dealer and they told me to bring it in and so I did. What you need to do is take your vehicle to a honda store near you and they will be able to give you the code using your VIN number.
Oct 15, 2010 | 2006 Honda Element
I changed the oil. Do I need to grease it?
HI. It is a good rule to have a lube inspection preformed during every scheduled oil change. This will cover all lube points at the front and rear axle assemblies and steering assemblies, as well.
With that said; if you are not hearing any sounds that may indicate that you do, indeed, need a lube job, I would not recommend it at this time.
Aug 15, 2010 | 2006 Honda Element
What needs to be done for 2006 honda element with
Apr 25, 2010 | 2006 Honda Element
How to program the clock
Press and hold the sound button on your stereo until the time flashes. To adjust the time i think it was the number 4 cd button for the hour and 5 for the minutes. After setting time press the sound button again and wella.
Deadends
Mar 10, 2009 | 2006 Honda Accord
Headlight not working
check fuses first under dash and engine compartment then if you need to change bulb by behind the headlight there is a cover twist or pull off then change bulb Please rate my response thank you very much
Jan 30, 2009 | 2006 Honda Element
2008 Honda clock
Heres the procedure for setting your clock http://senduit.com/de12f7
Nov 04, 2008 | 2006 Honda Fit
2006 Honda Element EXP - 40K miles
I have a 2006 Honda Element as well, and mine started making "rubbing" noises when I made a slow hard turn left or right. It had 49K on it. Took it to a dealership and had it looked at. The technician knew what it was right off the bat. The rear differential needed to be serviced. Said the fluid had broken down and needed replacing. $79.00 to fix. CRV have the same problem. Just get it serviced and it should be ok.
Jun 16, 2008 | 2006 Honda Element
Open Questions:
Car Audio & Video Logo
335 people viewed this question
Top Honda Car Audio & Video Experts
Are you a Honda Car Audio and Video Expert? Answer questions, earn points and help others
