Question about IBM ThinkPad T40 2373 Notebook
How do i put a password on the laptop to ensure that someone can't log in and use it without my permission?>
  • Anonymous Mar 24, 2014
    family using my laptop without permission. need to change password
  • 320 Answers
To put a password to your laptop, click start and click control panel, and click user account. Click your account name and select create a password. Type your desired password and have it confirmed and supply hint for your password. Press create password button at the bottom to activate the password..
Posted on Nov 08, 2010
Using net withou user
You really need more information. I can only guess you mean someone is using your wifi without permission? If so, put a password on it.
Jan 06, 2014 | Computers & Internet
HI, I have a IBM Thinkpad R50e and i had a CMOS battery failure. After replace the battery it has now started to ask me to check the date and time and when i press enter it is asking for a BIOS...
Dear john, replacing CMOS Battery usually RESET password ( plug out your laptop battery,then plug out the CMOS battery. keep it out for 5 minutes.)
After 5 minutes by, put back on the CMOS battery. put it back all together. laptop battery the last one.
On the first boot you need to set the time and date. or by pass it by pressing ESC. >> If your Operating System goes >>> right click on clock task bar >>Adjust Date/Time >> set as you wish >> apply >> ok >>>RESTART your unit.
akee_akee@live.com
Aug 16, 2011 | IBM ThinkPad R50e Notebook
How can i lock my Hp laptop so that no one can open it without my permission
The easiest way is to set-up an administrator account (user name and password) on your computer. You can go to Control Panel > User Accounts to create an account or set a password for your account.
Hope this helps.
May 06, 2011 | Computers & Internet
How to Install IE8 in WinXp Without Administrator Access
If someone has turned off software installation permission using an admin password there is no simple way to defeat that permission. Depending on how the permission was set, either from a server that you log into, or on the local machine itself, you might be able to take the hard drive out of that PC and then install it onto a computer that is not limited by that permission. You would then install your IE8, and then re-install the hard drive back into your PC. The only catch might be that your system may also be limited against running IE8 as well.
The other trick that might work is getting a disk version of the Linux Knoppix program. You would have to boot your PC to the Knoppix install, and then use it to break the Admin Access permission. There are several issues with this hack. Your PC would need to have permission to boot from a floppy or a CD/DVD drive, and chances are that permission has been turned off as well. Any admin who has at least a couple of years experience knows about the Knoppix hack, and will have taken steps to ensure no one would be able to use it. You might unfortunately be stuck with whatever browser you are currently using.
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Feb 17, 2011 | Computers & Internet
Well lets just say i kinda forgot the password for my main user name now i gotta sign on under guest and because of this i cant download anything that i need.so i guess my question is, is their anyway i...
Try going into the control panel in the start menu. Then open the user accounts and see if you can change the password within here. There will be a link to click that says change password. If it does not work You can try loading safe mode.
To load safe mode press F8 repeatedly when turning computer on. This will bring up an advanced options menu. > Within the advanced options menu use the arrow keys on keyboard to navigate.> Highlight safe mode and press enter. > This will load windows into safe mode when loaded it will take you to screen for users to sign in. > Try logging into the administrator account without putting anything in the password field. > you can try any other accounts here as well to see if they may let you in > If this allows you to log in. You can go into the control panel under the start menu. > Then go into user accounts and change the password from within here. There will be a link that says change password.
Oct 22, 2010 | Computers & Internet
Cause of user profile not loading
The question is:
What causes a user profile not to be loaded in Windows domain based network?
the answer is:
there are probably 3 broad reasons for this,
1. the user corrupted their profile somehow, such as shutting down without logging off (hard power off)
2. the connection to the domain was lost ungracefully, and offline information was not copied entirely, causing a mismatch of some encrypted profile data, (effectingly corrupting again) and preventing the logon.
3. an unknown event took place between the last time the user sucessfully logged on, and this time where the profile is now not loading. this could be hardware related (faulty Hard disk), RAM parity errors( bad memory), a change to the user profile SID details on the domain controller or other domain change.
Usually the cause is not so much a problem, unless it consistantly reoccurs.
Fixing it however, in XP is fairly easy.
with an account with domain admin rights, just navigate to the UNC path "\\computername\c$\documents and settings" - note the name of the folder/user affected, and just .old their profile folder.
example, username is Philip. - you see in their c:\documents and settings\ folder the folder called Philip, rename it to philip.old or something else.
You have to ensure this is done while the user is logged off, as files in this folder will be in use otherwise. potentially useful to reboot the computer before navigating to the profile folder.
Jul 11, 2010 | Microsoft Windows XP Professional
Yesterday I deactivated my facebook,4-3-10,someone else reactivated it today,without my permission. Now how do I stop this?
Have you tried changing the password?
If this still doesn't work I suggest you look into it and make sure your passwords ain't saved so someone can't log in e.g. remember me, remember password.
Hope I helped Dr Reed
Apr 05, 2010 | Dell Inspiron 530s Desktop Computer...
Heya Laptop
It sounds like you closed the lid, which put the computer into "Standby mode" (which can be seen by the flashing green lightning bolt light on the front) . Whenever you turn your computer on from standby mode, it locks the computer so that an unauthorized person can't open your computer and run your programs without permission. To log in, you can just type the password you normally type when you log in to the computer. If you don't have a password, try just hitting enter instead of typing a password. (You may need to hit Ctrl + Alt + Delete before you can enter your password, just follow the instructions on your screen)
Oct 23, 2007 | Compaq tc4400 Tablet PC
IBM ThinkPad T40 2373 Notebook Logo
82 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
