Question about Dremel Variable - Speed Multipro Rotary Tool 395
Flexshaft 225 T2
How does one attach bits, etc. to the shaft? When I try it just spins and nothing locks in.
TIA
The Dremel has a safety feature, it must be in the 'hanging up" position, or the shaft will not spin when using the 225 attachment.
Posted on Sep 05, 2008
  • 13 Answers
Do you have a 'nut' on the end, or just a wide open shaft (1/3 inch or so?)
You need a collet nut to tighten bits, and maybe collets of varying sizes also (not sure about this particular shaft).
Posted on Jul 29, 2008
  • Herbert Fellows Jul 29, 2008
    Forgot to mention, you need to hold the button in the front of the tool down to lock the shaft, that's probably your problem.
Why does Flexshaft get hot after a couple seconds
Perhaps you are bending the shaft too much, or the original lube in the flex shaft has been compromised. Take it back to the dealer, for an exchange.
Jul 12, 2014 | Dremel Variable - Speed Multipro Rotary...
How do I replace a flexshaft on my huqvarna 128 LD weedwacker.
I have a Husqvarna 128LD and love it. When using a tiller attachment the part of the shaft that has the knob comes loose. I have tightened the screw with allen wrench but it still comes off. or gets loose. Can I weld the bracket to the shaft?
Sep 14, 2013 | Husqvarna 128 LD Weedeater
One end of the 225 t2 is a large receptacle with threads inside and a shaft below the threads.I have no adapter to connect it to the Dremel. The FlexiShaft came with the variable-speed Dremel but no...
To use the flex shaft, you need to remove the bit collet. Included in the kit is a nut looking item--mine is silver. It has a square end and screws on to the end of the dremel. It is simlar to the collet, but is slightly smaller. Then you place the square end of the flex shaft into the nut and screw the shaft on to the dremel.
Hope that helps
Jan 18, 2011 | Dremel 225 Multipro Flex - Shaft...
Where can I get a flex shaft attachment (Model 225 T2)?
Check w/ Home Depot and/or Lowes. If they don't stock they can get quickly
Jan 04, 2011 | Dremel Variable - Speed Multipro Rotary...
Flex shaft attachment
Takes an adapter to screw onto the nose of the Dremel. The shaft itself is gripped by the correct size collet tightened as you would any bit.
Mar 02, 2010 | Dremel 225 Multipro Flex - Shaft...
Ref: Stihl FS46 string trimmer. Broken Flex shaft.
Remove orange sheild,remove single screw holding head in shaft then grab head with pliers and twist side to side until complete head is free.You should then be able to grab part of shaft.On power head loosen screws {about one turn each} that hold two white case halves near trigger,I think there are four,then there is a single torx screw on the bottom of lower case half in the middle that must be taken out to allow tube to be removed.Romove flexshaft from top.Check 4 plastic burnt to flexshaft,if there is you must replace tube liner as well,usally around bent part of tube the liner will go bad.
Nov 27, 2009 | Garden
Craftsman rotary tool doesn't lock down on the bits.
the collet is either the wrong size for the shaft on the attachment or is missing alltogether
Jul 04, 2009 | Dremel Variable - Speed Multipro Rotary...
Bottom of shaft is getting red hot
Have you greased your shaft lately? It is necessary to put grease inside the shaft from time to time. Remove the engine of the trimmer, pull the flexshaft or rod (which ever it has) out of the shaft and while slowly reinserting the flexshaft squeeze "oo" grease or any type thick grease into the shaft and on the end of the flexshaft. Reassemble engine and you should be good to go.
Jun 03, 2009 | Garden
I have lost instructions for dremel flex shaft attachment sue
There are no manuals I have found but I have a website and phone number for them the site is Dremel.com and the toll free number is 1-800-437-3635 you can use either one to get the manual you need.
Apr 18, 2009 | Dremel 225 Multipro Flex - Shaft...
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
1,153 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
