Question about Nikon COOLPIX L5 Digital Camera
My nikon says lens error
My camera says lens error. The lens is also stuck in the position as if it where taking pictures. It will not retract.
  • Anonymous Jun 24, 2008
    same thing with mine... it was dropped
  • Anonymous Oct 12, 2008
    qwf
Remove the 4 screws from the bottom 2 each from the sides, gently remove back leaving the wires and cables attached, remove 4 screws on logic board. left up slightly then set back down. Set the back cover in place put in batteries and test. When working put screws back in and your set.
Posted on Feb 08, 2009
My camera says lens error. the lens is also stuck in the position as if it where taking pictures. it will not retract.
Posted on Nov 09, 2008
I have a Nikon AF-S 55-200mm 1:4-56ED. Focuses fine, lens goes in and out fine...except...it doesn't retract completely flush with the barrel of the lens. Is this a big problem?
I do not have that particular lens in my collection, but not all lenses do completely retract to a flush position. If your lens performs well at all focal lengths and takes sharp pictures, it is probably ok.
Aug 26, 2012 | Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S...
Lens error
There is a possibility that a bit of grit or debris has got stuck in the retraction mechanism or the lens has been knocked out of alignment.
The camera will have switches inside to tell it when the lens is retracted or extended and if it doesn't make contact within the expected time then it will give this error.
If the there is no warrantee or you dont mind voiding it then I would suggest carefully disassembling the camera and turning the retraction motor by hand to see where the problem is.
Please comment again if you discover anything.
Good luck
Oct 19, 2007 | Nikon Coolpix 5200 Digital Camera
Lens error. lens is currently retracted. will not open. nikon s8100 bought xmas 2010.
Had issue with lens stuck and not retracting on nikon s8100. first removed battery. then manually (gently) rotated lens counterclockwise until lens seated in fully retracted position. inserted battery, turned camera on and camera operational again. I suspect that root cause of lens jamming was turning off camera while simultaneously moving zoom lever
Mar 11, 2011 | Nikon S8100 Digital Camera
I Have a Nikon Coolpix S210, the lens is stuck in the extended position and I have no pictures on the screen. I have at times seen that when I turn on the camera and the power light is on, it tries to...
Here are some ideas. Once I solved such an issue on a camera that had fallen down on a hard floor (by applying force on the lens to make it retract)..but please read everything here first *before* you try that:
http://www.wikihow.com/Repair-Lens-Problems-on-Your-Digital-Camera
Nov 28, 2010 | Nikon Coolpix S210 Digital Camera
Lens error
i had the same problem....my problem was the lens was pushed forward and the third zoom was pushed back. so the lens is blocking the cover(thing that covers the lens) so push the lens back carefully with a cottom swab and pull the third zoomer thingy out.
Jul 31, 2008 | Nikon COOLPIX L2 Digital Camera
Camera lens stuck
Look at some of my posts today.
This may be that the lens is off track and may be able to be pushed back by a little force as you start the camera....see my other posts on this problem.
Jun 11, 2008 | Nikon COOLPIX L3 Digital Camera
Lens is stuck open says lens error nikon coolpix l6
when the camera is turned on it displays "lens error". I can't take a picture and i can't access my pictures on the camera.
Apr 29, 2008 | Nikon COOLPIX L18 Digital Camera
Nikon COOLPIX L5 Digital Camera Logo
290 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
