Question about Metz 60CT-1 Flash
My 60CT-1 only fires at full power. Worked fine one day the next time I used the unit it would only fire full power each flash.
    Problem Solver:
  • 14 Answers
Is the top dial set on AUTO?
Is the sensor window clean or obstructed?
Checking both of these may solve your problem. Do you have a Manual for this flash? There are free pdf downloads on the I/Net.
Posted on Jul 15, 2008
Metz 60ct-1 manual
Apr 07, 2012 | Metz 60CT-1 Flash
1987 thunderbird won't fire
ok dude i have had the same problem i have a 3.8 v6 i am not sure what u have but fine the negtive battery cable and there should be a little black wire follow it to a fuse type connector make sure it os on there tight it does some twisty type thing it is a kill/ground switch it is there so the car wont catch on fire and stuff like that next check the starter and ignition module try those few things and get back at me hope it works
Oct 17, 2008 | 1987 Ford Thunderbird
NiCad battery not charging
the charger adapter that plugs into the battery pac from the wall has a fuse inside it open it uo and check the fuse has not blown as that's normally the reason i get no light on the pac also using a small enough file clean off all the terminals and check that the spring terminals contacting the circuit board from the plug are not corroded and contacting correctly
Oct 23, 2007 | Metz 60CT-1 Flash
Can't fire properly at 90 degrees
Did you buy this used? Maybe the following problems: wires inside are loose or cold soldered. Flash tube has coated with film coating or flash head(inside)is dirty. Alexander
Jan 13, 2007 | Metz Mecablitz 60CT4 TTL Flash
Flash doesn't fire properly at regular position
Did you buy this used or new?
If used: neck has broken/shorted wires.
Try fires with the Test Button in A mode with hand blocking sensor and then without. Move head around.
If I can help.
Dec 31, 2006 | Metz 60CT-1 Flash
Problem with AF-360FGZ Flash
Yes. The *istD shutter can only provide X-sync for electronic flash up to 1/150 sec. The *istDS reaches 1/180 sec. "High speed" electronic flash is done by strobing the flash repeatedly during the period that the shutter slit is traveling across the focal plane, at th expense of cutting power output quite a bit.
Sep 08, 2005 | Pentax AF-360 FGZ TTL Flash
Metz 60CT-1 Flash Logo
265 people viewed this question
Top Metz Cameras Experts
Level 1 Expert
Are you a Metz Camera Expert? Answer questions, earn points and help others
