Question about Olympus VN-1000 Digital Voice Recorder
Hello. My VN-1000PC olympus voice recorder cannot transfer its files to my pc through its software Digital Wave Player. Do you know how I could transfer my files? Thank you in advance!
    Genius:
  • 1,218 Answers
Go to www.olympusamerica.com to check on software downloads and compatability with your PC operating system...you can also talk to someone at 1-888-553-4448.
Posted on Nov 17, 2010
Transfer audio files to pc with vn 960pc
download latest software ok from ther website 1st then windows update thats should help u transfer
Jan 26, 2008 | Olympus VN-960PC
I recorded meeting minutes to my digital OLYMPUS VN-480 PC voice recorder and want to transfer the recording on it to my Dell Inspirion/1100 laptop. Could I transfer the audio from the headphone jack to...
yes, it is possible. You will connect the earphone jack from your voice recorder to Mic of your laptop. Then you will be needing a wave software on your laptop, download the wave software from the internet, open the wave file, then press play on your voice recorder and the minutes will be recorded into your laptop as a wave files.
But the easiest method of tranferring the minutes is by using the usb cable of your OLYMPUS VN-480 PC voice recorder. If you don't have it you can purchase it, then connect it from your OLYMPUS VN-480 PC voice recorder to the usb of your computer and it will be read like a flash drive.
After that, go to my computer and you will see a drive representing the OLYMPUS VN-480 PC voice recorder, open the drive and you will see your minutes, then simply create a folder on your computer, and copy, paste the minutes into the created folder. And the would be all.
God luck.
Oct 11, 2010 | Sony ICD-B200 Digital Voice Recorder
Transfering a stored PC recording
The recordings simply reside on your pc, but not in the "Digital Wave Player" software. The software is merely there to let you play the recordings, probably because they are not in a native Windows format.
If the recordings are "Wave, .wav" files as suggested by the software, then simply locate the files you want to put on disc... I am guessing you want to burn on cd.
Then, use a burning program such as Nero to add these files and burn to disc.
If you don't have Nero, then you would need to figure out what type of burning software your machine has installed and go from there.
Mar 18, 2009 | Olympus VN-2100PC Digital Voice Recorder
How can I transfer files form a VN-2100PC recorder
Digital Wave Player (2.0):
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update: http://olympusamerica.com/files/DWPUP2EN.zip
Download update 2.1.3: http://olympusamerica.com/files/DWPUP4EN.zip
Do not have recorder connected until all software installed and then reboot computer. Once computer rebooted then connect the recorder.
Mar 03, 2009 | Olympus VN-2100PC Digital Voice Recorder
File transfer VN-480PC doesn't work on notebook (Vista)
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Feb 19, 2009 | Olympus VN-480 PC Digital Voice Recorder
Olympus VN-3100 software
Call tech support at Olympus. They maybe able to help you with a special link.
Feb 06, 2009 | Olympus VN-3100PC Digital Voice Recorder
I can't transfer my files from recorder to pc
This problem can typically be solved by unplugging the device from your computer's USB port and plugging it in to another USB port on the same computer.
Also be sure you have Olympus Digital Wave Player installed and open with your Transfer Options set to Auto Transfer. To do this, follow the steps below:
Open Digital Wave Player > select Transfer from the menu > select Transfer Options > under Auto Transfer, check the box which reads "Transfer all audio files after detecting Recorder."
Jan 21, 2009 | Olympus VN-3100PC Digital Voice Recorder
Here is the download instructions for the VN recorder software it work with the VN 240Pc up to the VN 4100PC and Widows 2000 - VISTA.
Digital Wave Player (2.1): is available via download as a courtesy, please follow the instructions below:
Jun 23, 2008 | Olympus VN-3100PC Digital Voice Recorder
Transferring files to CD
Just use the Cable u got with it, also u will need the installation cd for it...!!!
Feb 15, 2008 | Olympus VN-3100PC Digital Voice Recorder
999 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
