Question about Belling BE808 Compact Refrigerator
Hi I have a BE808 Integrated Larder fridge & a few days ago the light inside the fridge was flickering and there is like a buzzing noise, so I went to my lockal DIY store and replased the light bulb, but I am still having the same problems ? can anyone help with this please. Regards Tommy
How do you stop ice building inside, at the back of fridge model Beko LA87 Larder fridge
It can be 2 things. One is that the thermostat is broken but then it will also freeze your food. The other reason is that it has lost part of its gas charge due to a leak on the system causing the unit not to reach temperature thus not switching of on the thermostat and building ice inside. Normally it is not economically viable to fix the unit.
Oct 06, 2017 | Refrigerators
Oster OM1202E0VG 1.2 Cu.Ft. buzzing and light blinking..I just got it 6 months ago what is wrong with it?
Yes! it sounds from your description you have a short in the system, the problem is caused by the inverter board or the magnetron, I suggest returning the unit because the alternative is a huge expence.
Jul 07, 2012 | Oster OGB61101 Microwave Oven
Hello. I have this fridge-freezer, but unfortunately I can't remember when it was bought. I guess it must be between 7 and 12 years ago! It's worked fine but a couple of days ago it started making...
By your description you may have a compressor problem. The noise is makes if a buzzing noise when it struggle to start (locked up). The clicking noise would be the relay clicking out on overload to the compressor.
If your correct on the date, you will be better off replacing the unit then looking into the repair, a normal compressor change out can run over 500.00. Your best bet is to cut your losses and replace the unit before spending any more money on it.
Good Luck
Aug 28, 2011 | Refrigerators
Light inside the refrigerator flickers (or not) and the door makes a buzzing noise when opened. There appears to be a small light flickering inside the fridge behind the vegetable bend. The refrigerator...
Sounds like the electronic control in the rear compartment by compressor may be bad . There is a light in the crisper as well I believe and that one and the main light are controlled by the control in back.
Dec 03, 2010 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
I have a 6year old Frigidaire tall larder fridge, over the last couple of days it has beening making an unusual noise. Yesterday I thought I had had a power cut but I have now found out that it is the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 07, 2010 | Frigidaire Refrigerators
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
Tenant says fridge is not cold enough and that food has gone off
I would check to see if the heater is working? It would behind the plastic back wall of the freezer. if its all frozen up and ice all over, get a hair dryer and melt ice and get a new heating element. cost is about 50 dollars
Dec 06, 2008 | Belling BE808 Compact Refrigerator
Belling BE808 Compact Refrigerator Logo
48 people viewed this question
Top Belling Refrigerators Experts
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
Nater13
Are you a Belling Refrigerator Expert? Answer questions, earn points and help others
