Question about Motorola Mobility H620 Bluetooth Headset
Got I phone 4 and don't have pin for h620 blue tooth Worked fine with my 3G How do I get pin it is asking me forone
The pin is 0000
Posted on Nov 08, 2010
I want to listen to music on my phone with my bluetooth headset
iIn order to listen to music on your blue tooth headset you first must pair them to your phone,To do this you first must turn the power to blue tooth to on in your phone menu,then you will have to put your blue tooth device into discovery mode,most bt manufactures use the power button for this feature,when turning your headset on continue holding down the power button for 6 to 10 seconds and a light should stay on ,thus putting your bt device into discovery mode thenfrom your phone you can search or add new device,it should recognize the device and ask for a pin or pairing code.Most manufactures use a factory 4 digit pin pairing code,they are as follows 0000,1234,9999,or 1111,once your code is entered they should pair,then you will be able to use your blue tooth device to listen to music.glad to be of assistance
Feb 26, 2011 | Radio Communications
How do I pair this bluetooth device to a phone
First step is to turn the blue tooth power to on in your phone menu,then you must put your blue tooth device into discovery mode,Now most blue tooth manufactures use the power button for thiws feature,when turning your device on keep holding the power button sown for 6 to 10 seconds a solid light usually stays on,this means you are in discovery mode,then you can add new or search for device from your phone menu,once it finds it it will ask for a pin pairing code.Most manufactures use a factory 4 digit pin pairing code they are as follows 0000,1234,1111,or 9999. enter one of these codes starting with the first one ,when it recognizes the pin it will pair and you are ready to use your blue tooth device,glad to be of assistance
Feb 26, 2011 | Motorola Mobility Motopure H12 Bluetooth...
Can't remember how to pair my LG HBM-710 to my new phone - Samsung Fascinate. Can you help?
to pair a blue tooth device to a phone first you must turn the bt power on the phone to on,then you have to put your blue tooth device into discovery mode,now most manufactures use the power button for thisw feature.By holding down the power button on your device when turning it on for 6 to 10 seconds it usually puts the device into discovery mode.there should be a light that stays on on your blue tooth device.once you have the bt device into discovery mode you will be able to pair the device to your phone by search or add new device,once it pairs it will ask for a pin or pairing code.most manufactures of blue tooth devices use a 4 digit factory pin pairing code they aare as follows 0000,1234,9999,or 1111 once youve put tjhe pin code on they will pair ,i hope this helps
Feb 25, 2011 | LG HBM-710 Wireless Headset
Unable to put phone into pair mode motorola hs810 to a i phone 3g
Most blue tooth device manufactures use the power button to set your device to discovery mode,first you must turn the power to on for your blue tooth from your phone menu,then most manufactures use the power button to put the blue toooth device into discovery mode,by holding the power button down when you turn your device on holding it for 6 to 10 seconds,usually a solid light appears on your blue tooth device,it is now in discovery mode,on your phone menu there should be an add new or search devices,once you've clicked that it should discover your blue tooth device,then you will need a pin or pairing code,Most manufactures use a factory 4 digit pin pairing code the y are as follows 0000,1234,1111,or 9999, if you have done the steps correctly the menu will say connect,press conect and you should be connected..i hope this helps
Feb 22, 2011 | Motorola Mobility HS810 Consumer Headset
How to you set it up with your phone
In order to set up your blue tooth device to your phone you first must turn your blue tooth power to on in your phone menu then you must turn your blue tooth device into discovery mode.this usually is done by holding the power on for 6 to 10 seconds and a solid light will be on,then in your phone menu you can add or search for blue tooth device if you have your blue tooth in diuscovery mode the two will pair then you must enter a pin or pairing code,most manufatures of blue tooth devices use a 4 digit factory pin or pairing code they are as follows 0000,1234,9999 or 1111 enter the code and they will pair ,once paired it might ask you to connect ,selet ok or yes and your in business, i hope this helps
Feb 21, 2011 | Plantronics Explorer 230 Bluetooth Headset
I has sony ericsson blue tooth, my phone is nokia E72 how to connect?
By sony ericsson blue tooth i think you mentioned the headset. If you got the manuals for that headset, just check for the default pin code for the headset. But if not try these pin codes such as 1111 or 0000 or 1234 etc.
To Connect:
1. goto connectivity in ur mobile nokia e72. you will find it as a seperate icon in your menu, or you can get it from setting/connectivity.
2.in that switch blue tooth on.
3. now go to the next tab, and select options. from that select new paired device.
4. Now it will find the blue tooth headset. If it didnt detect, make sure your bluetooth headset is switched on.
5. then select that headset fro the search result and then it will ask for confirmation with the pic code.
type the pin code you hv gt from the manual or try these(1111 or 0000 or 1234 etc.). then it will accept. If its accepted, the bluetooth headset will start working!
Thanks, ask me if u gt any doubts.
Oct 06, 2010 | Cell Phones
BLUE TOOTH H 500 NOT GETTING CONNECTED, CEL IS ASKING PIN CODE
thanks
a friend of mine told me the pin code of h 500 blue tooth
which had solved my problem yesterday
any way thanks
ather m.khan
Apr 10, 2009 | Motorola Cell Phones
Can't set up blue tooth
Strangely enough I went to the website where I purchased the blue tooth. It recommended holding down the button for 8 seconds as opposed to the 3 or 4 listed in the manufacturer's instructions. When I did this it found my phone. The pairing worked fine and now so does the blue tooth.
Jan 15, 2009 | LG Vu CU920 Cellular Phone
N95 will not pair with Philips shb7100
The Philips tech-support asked if I pressed the connecting button on the blu-tooth dongle long enough or until it blinks back and forth from red to blue. This takes 5 s of pressing. After this the connection worked just fine. You can actually read this in the user manual too...
So don`t just start the SHB7100 when you pair it with 95, keep the button pressed down until the light shifts from blue to red and back after which you can enter the code 0000 and Voilà!
Sep 30, 2008 | Nokia N95 Cellular Phone
Motorola Mobility H620 Bluetooth Headset Logo
79 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
