Question about Dell 5330dn Laser Printer
Fuser error in dell 5330 dn - Dell 5330dn Laser Printer
Replace the fuser lamp and the thermistor.
Posted on Nov 08, 2010
Received fuser error u4-1. Replaced fuser, and still get same error
Try to hard reset your printer. To do this, unplug the cord at the rear of the printer while still powered on. Then remove it the plug from the socket. Let it sit for a few minutes. Then, plug the power cord and then reattach the cord at the back. The printer should power on itself, if not just power it on manually by pressing the power button.
Doing the hard reset should clear off any error messages from your printer's memory.
Feb 06, 2013 | Xerox Phaser 5500/DN Laser Printer
How do you reset the fuser counter, or page counter, on a dell 5330?
There is no mention of resetting the counters during the replacement process in the manual for the printer. (Link below) Try powering off the printer by using a switch or unplugging it.
Manual:
http://support.dell.com/support/edocs/systems/5330DN/en/index.htm
Mar 02, 2011 | Dell 5330dn Laser Printer
HP Color LasrJet 5550 dn Error code 59.30
The error says that the printer has a "fuser motor startup error".
Not a good error to get.
Possibilities are a bad fuser motor, bad DC Controller or fuser drive assembly.
If you haven't already, power cycle the printer.
If the error persists, you are going to have to have a tech look at it.
Feb 28, 2011 | HP LaserJet 5550 Printer
Show me how to replace a fuser in a dell mfp 1815 dn printer please
Pull down the rear door. There should be 2 screws on either side.....remove them....look for 2 more screws towards the bottom. Remove them....the entire rear plastic of the machine should pull off...exposing the fuser. Remove the screws holding the fuser in place. Pull the connectors from the power supply below and you should be able to pull the fuser out! If you need a fuser you can get one at www.getthatpart.com they have good used fusers at good prices....you can also call them at 410-374-1261
Oct 25, 2010 | Dell 1815dn All-In-One Laser Printer
Engine fuser low heat error on my xerox phaser 3500
You will need to replace the fuser.
You may want to look and see if you just have a piece of paper wrapped around the roll, but most likely the heating element has gone bad or one of the thermistors have failed.
Call 1-800-835-6100 and tell them the model number, and if it is a 120 volt or 220 volt fuser.
Feb 10, 2010 | Xerox Phaser 3500/DN Laser Printer
DELL Laser printer 1700/1700n
All flashing lights for the Dell 1700 series (1700, 1710, 1720 including those that have n or dn as part of the model) printers is a service related error. When double pressing the continue button twice quickly, the printer will give a secondary error code, narrowing down the printer part being effected. It is possible to even narrow the error code down even futher by double pressing the continue button and taking note of which combination of lights come on, wether they are steady or blinking. Most generally when this series of printers, when you get all flashing lights, something major is going on with the printer. It could be pointing to the fuser, or main board, etc. You can call dell warranty support and they will help narrow down which part is being effected. Most generally, what is being effected is not cost effective to get fixed if you are no longer under warranty.
Sep 18, 2008 | Dell 1700n Laser Printer
Dell 5330dn Laser Printer Logo
1,275 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
