Question about Omega 1000 Juice Extractor
All hooked up but won't start. Electrical outlet working fine.
    Champion:
  • 356 Answers
There may be a reset button on the bottom. Try pushing it.
Posted on Feb 02, 2011
Hello my juicer is not working. had not used for more than 2 years and now when i tried to use it its not wokring
Need more info. Maybe there is a switch on the base for the cover that is not being pushed on when cover is applied or something similar. It is hard to say unless you can list the brand and model. sometimes the cord can have an open wire. Try to wiggle and replug into the outlet. Also, make sure you did not trip the gfci outlet that it is plugged into.
Jan 27, 2018 | Juicers
Russell Hobbs Juice Extractor Won't Start
if it is intermediate workings there is a micro switch that is a must so it wont turn on when your fingers are in it might have some junk in it clean your machine. look if the micro switch fell inside machine ?
May 12, 2014 | Juicelady JL500 Juice Extractor
My omega juicer won"t turn
Unscrew the bottom cover to expose the electrical cord. Check voltage if coming from the electrical cord by using a tester.If there is power, look for a a thermistor or a fuse and test if it is broken.
Sep 03, 2011 | Omega Juicers
My machine won't turn on when I flip the switch. It is properly connected, I tried it in several outlets - that are working for other appliances and I am left baffled. I haven't used it in about 6...
do you have user's manual with wiring diagram? if not try H.B. If you get one, there is a diode that keeps your machine from frying from over-voltage. Kinda like a fuse, but is not a fuse. If you can check voltage across it, it is not the diode. That is a simple start and the most common problem for not starting.
Aug 03, 2011 | Hamilton Beach 67601 Juicer
Juicer was working fine yesterday and today it won't start up, period. Checked at different outlets and still nothing
Championjuicer.com sells replacement switches. Order the oil seal and o-ring too to save on shipping. Newer models have a safety cut off that does not allow the juicer to turn on unless all parts are properly positioned.
Oct 19, 2010 | Champion G5NG853S Household Juice...
Juicier will not work at all
Try the juicer on another circuit to see if the breaker failed altogether on the circuit you were using. It's possible that the machine is drawing more power than it should and may need to be checked by an appliance service dealer. An electrician can also check the power draw at the breaker to see if it is being overloaded. If the machine itself is defective, it should receive professional service. Good luck!
May 07, 2010 | Champion G5NG853S Household Juice...
I bought a home with no home inspection and i have a little electrical problem in the basement area. the house was built in 1978. it looks like one of the previous owners did the basement.basement looks...
POSSIBLY THE EASIEST THING IS FIRST TO DETERMINE ALL THE THINGS THAT ARE ON THE CIRCUITS IN QUESTION AND WORK FROM THERE , AT LOWE'S OR HOME DEPOT OR A GOOD ELECTRICAL STORE YOU CAN PURCHASE A DEVICE CALLED A CIRCUIT FINDER THAT WILL HELP YOU FOLLOW THE CIRCUIT FROM THE PANEL TO EACH PLUG IN OR LIGHT FIXTURE , WHEN YOU GET IT ,It WILL COME WITH DIRECTIONS ON ITS USE IT SIMPLY PLUG IN OUTLETS IT WILL SAY TO PLACE OVER BREAKER BUT SINCE YOU ARE WORKING OUT OF A FUSE PANEL DO THIS PLUG INTO OUTLET YOU THINK IS THE FURTHEST FROM PANEL AND PLACE DEVICE OVER OUTLET NEXT CLOSEST CHECKING BACK TOWARD IF YOU NEED TO PLUG INTO LIGHT FIXTURE USE THE SCREW IN 2 PRONG PLUG LIKE YOU WOULD SCREW IN TO HOOK UP A EXT CORD ETC CHECKING FOR PROBLEMS ALL THE WAY BACK TO AND INC THE FUSE PANEL BY DOING THIS YOU SHOULD BE ABLE TO DETERMINE THE CIRCUIT ROUTING AND HOPEFULLY FIND THE PROBLEM ,HOPE THIS INFO USEFUL
Oct 20, 2008 | Champion 2000+ Household Juice Extractor
Waring Pro Juice Extractor model #WE100PC - WILL NOT POWER ON!
check bottom of the basket and see if piece is missing or broke.
Sep 04, 2008 | Waring Pro¿ PJC Series PJC11 Juice...
Juicelady juicer dead after 10 uses
This may sound silly, but have you tried plugging it in to a different outlet in your kitchen-i.e. (as in an outlet that is on a different breaker? or fuse?) I thought our slow cooker was toast--& it was the outlet, not the unit. When we are busy or tired & frustrated sometimes we can overlook the simpilest things.
Is it possible you have a defective cord? Taking it to a repair place is your best bet if either of those ideas don't help. Call to get an estimate first--call around to parts & repair depots in your city/area, as the cost can vary widely. Some are very reasonable while others make you wish you'd replaced it instead!
Or ask around for a retired repairman that does repairs occasionally. They often charge a lot less-but you may have to pick up the part once he/she's identified the problem. Also--trade schools that teach repairs to small appliances may fix it for a nominal fee--or even just for the cost of the part--if a part is involved.
Hope this helps...
Jul 02, 2008 | Juicelady JL500 Juice Extractor
Darn thing STILL won't turn on
There is a little knob on pulp collector that pushes in a switch, probably to assure the unit is assembled before operation. Mine broke off. I opened bottom of unit and used electrical tape to permanently engage the switch. The Juicer now works. I consider it poor construction that such an important part of the operation of the unit is able to break off and poor customer relations that there is no help for this on their web site. I have used it only a handful of times and the unit has mostly been in storage and has not been abused.
Jun 11, 2008 | Jack Lalanne Power Juicer 250 Watts
Omega 1000 Juice Extractor Logo
88 people viewed this question
Top Omega Juicers Experts
eyecam
Andrew Taylor
Andrew Taylor
Are you an Omega Juicer Expert? Answer questions, earn points and help others
