Question about Kenmore 55672 / 55674 / 55679 Side by Side Refrigerator
All of a sudden water/ice doesnt work??
I just replaced the water filter inside teh refridge. It worked at first then all of a sudden stopped working? Unhooked the water line and reconnected. Water flows into fridge, but does not flow out! Also doesn't make ice?!?!
Any suggestions? Thanks,
Adam
  • redroc25 Jun 22, 2008
    waterfilter in side block? sorry I do not follow what you mean?
    Check water flow? Again, any additional response/comments so I can check/do something??
    thanks,
    adam
    Problem Solver:
  • 27 Answers
Water filter in side block or cheak water flow
Posted on Jun 16, 2008
I have a GSH25JSTE refrigerator. the water has suddenly stopped worki, but the ice maker works fine. will the water stop if the filter needs to be replaced?
Todd, Harrie, I have exactly the same problem. Water suddenly stopped. Dispenses ice ok. The blue water solenoid inside the bottom back of the fridge is working. I've read that the water line can freeze! I plan to replace the water filter asap, due to age. Will let you know if that resolves this...
Jan 31, 2015 | Refrigerators
Water doesnt come out after replacing filter modGSS23WGTA
This is possibly one side of your=> WR57X10032 Dual Water Control Valve
has stopped working. The ice maker water works, right? Another thing to check is that your water storage tank inside fresh food compartment is not freezibg. If you have questions please ask, Thanks Sea Breeze
Nov 15, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
All of a sudden I can't get water from the door also no water is filling for the ice so I have no ice
You can try replacing the water filter, if that doesnt work it is either going to be a bad watervalve or there is a frozen water line inside the unit
Jan 06, 2011 | LG LFX25960ST Stainless Steel French Door...
Refrigerator dispenses ice, but does not dispense water?
Unfortunately, the housing that the water filter fits into is also the housing for the solenoid controlled water valve, and that is the most likely failure item.
Mar 29, 2010 | Whirlpool GS6SHAXMQ Side by Side...
Exterior water function stopped working. This is simultaneous with me removing the ice holder to defrost, then replacing. Ice maker functions and all else seems normal.  It seems like water and ice...
ck the fresh food tempt it may be too cold . and has frozen water line . adjust to a warmer tempt and it should start working .. mm ps in 24 hr or so ..
Dec 23, 2009 | Refrigerators
Intermittantly no water from inside water dispenser
I just started having the problem of no water dispensing from the in-door dispenser. I checked the operating manual and it suggested that the refridge temp may be set too low thus freezing up the water line. I have set the temp higher and we will see if that helps. I do not think that will do it because as you too note, the ice maker works fine. If the filter were an issue the ice maker would not refill either.
illinoisjas
Apr 19, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
Whirlpool sidebyside FF stopped working after ? motor stopped ...
this refrigertor is leaking refridgent gas it needs checked by an engineer
Feb 15, 2009 | Whirlpool 25.3 Cu. Ft. Frost-Free...
Icemaker not working.
I just had the same problem. I found a small amount of ice formed under the water inlet point in the ice maker tray. This ice prevented the rotation of the "ice cube ejection fingers" so it couldn't cycle and re-fill. I used a hair dryer to melt this ice and the fingers immediately began rotating. Once they cycled, the tray filled with water as it should. All seems well now.
Jan 18, 2009 | KitchenAid KSRS25IL Side by Side...
Refridgerated water spout suddenly stopped producing water
Have you changed the water filter. It should be located in the front loer grille of the refrigerator.
Jan 10, 2009 | Refrigerators
Amana French door Refridge-water dispence inside the door not working
pull out crisper and deli shelf thers a tank behind them its probably froazen, hit it fora few minutes especally around top neck portion with a hair dryer, common issue
Jan 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Kenmore 55672 / 55674 / 55679 Side by Side Refrigerator Logo
109 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
