Question about Makita Garden
I was running my blower when it started making a sqweeling type noise, so I shut it off and then went to go pull cord to start it again. As I went to pull the cord it won't pull out, it is stuck and won't pull..any ideas how much this will cost to fix or what I should do..being a single mom don't have alot of funds and need my blower :(
SOURCE: the pull cord on my toro powerlite snowblower wont retract
YES YOU CAN JOE,Your recoil has come undone or the spring broke. but it can be fixed.richardm69
Posted on Jan 01, 2009
SOURCE: the pull cord has no tension to make the engine start
It seems you do not have enough spring tension. Remove the starter housing and grab the slack rope and wind the pulley two or three times in the tension direction until the slack gets pulled into the pulley by the spring. Hope this helps. Donnyb60
Posted on Mar 19, 2009
slohry
  • 87 Answers
SOURCE: Husqvarna 130BT leaf blower - locked-up
If you stored it with fuel in it, the piston and cylinder may be stuck together. The old fuel turns to a gummy varnish. spray some WD-40 in to the cylinder through the spark plug hole and rock the flywheel back and forth to break it loose. Then flush the fuel system and carburetor. If that isn't the problem, remove the muffler and inspect the piston, rings, and cylinder for vertical scoring, if scoring is present a top end rebuild may be necessary.
Posted on Apr 13, 2009
SOURCE: toro self propelled 22 inch recycler lawn mower start pull cord is "stuck"
Casey,
My son just bought a new Toro self propelled 22" recycler and has had problems on two different occasions. The mower just bogs down to a stop and when he tried to pull the starter cord, it was very VERY difficult to pull. At first I thought the engine had seized up for some reason (no oil?), but we found the problem.
First, disconnect the spark plug wire from the spark plug (to avoid the engine starting); tip the mower on its side and check very carefully the pulley and transmission belt. In his case, a piece of wood had gotten stuck between the belt and the pulley. Removing it fixed the problem (now he mows a little higher so as not to get so close to any debris). (We did have one further problem after that - the engine would not start - not even fire. After pulling and pulling, checking for gas, and checking that the air filter was cleean, we decided to check if the cylinder was flooded - we removed the spark plug, wiped and dried if off, and replaced it. It started right away.)
This belt 'n pulley arrangement isn't the best idea, if you ask me.
Good luck.
Posted on Jun 08, 2009
  • 574 Answers
SOURCE: 2-cycle blower starts up but wont run full power rpm
Have you tried choking it about half way and see if that helps? Does it do the same after it is warmed up?
Posted on Mar 11, 2010
Need starting instructions for Ariens snow blower Model # H5065226H
do you have a fuel shut off valve? if so make sure its in the open position. choke closed,prime 3 times and pull cord. if not started after three pulls open choke and look in carb for fuel delivery. if none service your carb also check to make sure you have spark before assuming its the carb
Nov 22, 2014 | Garden
My Husqvarna 150BT leafblower was running great then started to loose power like when I run out of gas, I shut it off check fuel level which was fine, cleaned the air filter, added more fuel and pulled the...
Pull the muffler and look for scoring on the piston. I think you cooked it my friend. You may have a bad coil or fuel cap, but it's more likely you ran the mix too lean.
Nov 04, 2013 | Husqvarna 150Bt Leaf Blowers
How to start the blower friend lost manuel
I am going to presume this is a gas blower.
1. Make sure you have the properly mixed oil and gas in the fuel tank.
2. Put throttle lever setting to choke or start.
3. Press primer bulb 4-5 times, until it gets stiff and feels full.
4. Pull cord until the unit starts or at least sputters.
5. Put the choke lever to the 1/2 way point and pull rope again. Should start. When it has run 30 seconds or so, put choke to the off position.
Dec 19, 2010 | Mtd Garden
BenQ DX 650 Won't power up making clicking noise
Those units are designed to be fan cooled after the bulb shuts off. When the cord was pulled, the unit lost power and without the fan, sat there and cooked. Could be a thermal fuse, could be the bulb.
Mar 10, 2017 | BenQ DX 650 Multimedia Projector
Cannot turn engine over to start. Ariens 924 snow blower
pull spark plugs and see if it will pull over if not fuel may have filled the crank case drain & refill to proper level (starter is stuck in lube shaft & movethe gear up & down by hand to free up)
Feb 13, 2010 | Sport & Outdoor - Others
Loud sqweel noise when start car.
going to be your power steering pump
Feb 01, 2010 | 1999 Volkswagen Passat
I CANNOT START MY MOWER. iT FEELS LIKE SOMETHING
I bet it got over heated and shut off? That happems often to me when the grass is to long and wet!! When it cools down it will start again right?
Aug 13, 2009 | Toro Lawn Mower With Toro Power Tools
Echo pb 200 leaf blower want start
Turn on ignition switch, Choke, prime bulb 5 times (or until fuel flows), hold throttle down and pull starter cord sharply until it tries to start, then place choke in mid position pull cord sharply again until it runs then move choke to off when it will allow it.
Also you can go to toro.com then customer care, then manuals and parts then type in model no. and download an owners manual.
Apr 06, 2009 | Echo Garden
HEATER MAKING LOUD NOISES
Check the draft inducer motor for any partial blockages or dibri.
I've seen sticks, birds nest particles and pieces of deteriorating fan blades (squirrel cage type fans) cause this.
You might also find that the inducer motors bearing are going.
If its a loud vibrating grinding type noise, I'd suspect bearings or missing pieces of the blades. (unbalanced)
If it's a clanking type noise I'd suspect loose items hitting the fan.
The inducer motor will only operate right before and during burner operation, while the blower motor can operate at any time depending on your setting.
Dec 06, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Will not start again.
If the cord sparked, then it is bad and needs replaement. If it sparked at the plug end, then replace the plug.
Feb 23, 2008 | Hoover V1 SteamVac SpinScrub Vacuum
Garden Logo
Top Makita Garden Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you a Makita Garden Expert? Answer questions, earn points and help others
