Question about HP Office Equipment & Supplies
I have an HP Officejet 4500 g510 - how do you turn off the power save mode? Thanks,
Called Hp, they said it is a firmware problem and they would notify me when they solved it. All I do is unplug and then plug it back in. If that don't work, make sure you have a phone line plugged in you're printer and pretend to make a phone call, this will "wake up" the printer, it will say "phone off hook". Then on the keypad of the printer push the star and pound buttons at the same time, then enter 1, 2, and 4. Scroll thru until you see "system menu" then push the OK button and find "system mode timeout" push OK then enter 1800 and push OK. Push OK again to make sure. That is the dafault setting for this printer. After doing all that you're printer will go to power save mode after 30 minutes sitting idle but it should pop right back to normal by pushing the power button once or sending a print command from you're computer. At least that's what I did and now it seems to come out of power save mode when it's supposed to....gary
Posted on Jun 17, 2011
  • Alex Rojas Riva Jul 27, 2013
    The problem is that I can't find a controler or driver for Hp Officejet 4500 G510 g-m and Ubuntu 12.10 in internet. How can I do?
I am trying to install the hp 4500 g510 to my computer. The options that I am getting are hp 4500 g510 a-f class, are they the same?10
no there not quite the same some versions of this model have a document feed - some don't ,- the product Number is what you should use to find the correct driver which could be one of the following-CB867A/CB877A -CM743A/CM744A-if you look at the serial number Sticker(with barcode) it will have one of these id tags on it - use this code in HP website to locate the correct driver
Jan 24, 2014 | HP Designjet 4500ps InkJet Printer
Tip
HP OfficeJet 4500 drivers for Windows 10
To install Drivers for printer and scanner of Hewlett-Packard Officejet 4500 same as G510 don't try to install it on Windows 10. You may found that. So what to do.
find in main HDD c: programfiles x86 hp and delete. (check if you have other hp machines so be careful) .download free program auslogics registry cleaner or with regedit in cmd command and find and delete all entries.
now for example you have the hp officejet 4500 wireless and you have download the OJ_AIO_4500_G510n-z_Full_Win_WW_140_408-5 . find it in the folder and with free 7zip or other like winzip extract it in a folder.
go to printers and add printer. When Win asks for drivers guide the request in extracted folder with checked the subdirectories.
That's it.
Have Fun and make a pray for me.
Nick.P.
on Nov 24, 2016 | HP Officejet 4500 Wireless All-in-One...
Why isn't my HP office jet 4500 G510 a-f printer connected?
Maybe you didn't install the driver properly, i guess that model will need you to install the driver 1st before connecting your printer to the PC.
Try uninstalling the driver...restarting PC...reinstalling driver...connecting printer (while in off position)...switching on your printer.
Sep 23, 2017 | HP Office Equipment & Supplies
I have an HP office jet 4500. How do I turn off the sleep mode? I am having to unplug it everytime now to get it to turn back on.
Sleep mode option for avoid consumption of power which was widely used in high end laser technology to save power. This option is not avail in inkjet technology where that much power not required..Even power saving mode not switch off entire internal functions except fusers/heaters.
Sep 24, 2011 | HP Officejet 6500 Wireless All-in-One...
How do I turn off the power save mode on my 4500 wireless hp officejet?
Follow the steps below to power cycle: 1. Shutdown your computer. 2. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port. 3. Wait 30 seconds. 4. Plug in the power only. 5. Repeat steps 2-4 two more times. 6. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer. 7. Restart your computer and check the functionality. Now check the functionality.
Jul 22, 2011 | HP Officejet 6500 Wireless All-in-One...
I have an HP Officejet 4500 G510n. How do you turn off the Power Save Mode. It won't do anything when it is on. Better yet, why does it keep coming on?
This is a known fault with this printer.
You can try this solution:
When the printer is in the Power Save Mode is to press the number "1" key on the printer. For some people, it comes out of power save mode.
To Turn off Powersave Mode Permanently:
Using The Printers Control Panel
1. Press # and # at same time.
2. Then press 1, 2, 7, 4 in sequence.
3. Go to Underware menu. (This is the first menu that pops up after enter that sequence)
4. Go to System menu.
5. Look for System Mode Time Out and set value to 0 and press OK.
6. Press Cancel to return to the main screen.
Apr 13, 2011 | Office Equipment & Supplies
I HAVE A MAC OS X 10.4.11. HP OFFICE JET 4500. HOW DO I SCAN? WHAT OPENS ON MY COMPUTER? WHAT SOFTWARE SHOULD I HAVE? I SAW I PHOTO OPEN BUT DID NOT SEE MY DOCUMENT.
OS X driver which allows your Mac to interface with a HP Officejet 4500 wireless all-in-one printer
This is a free Mac OS X driver installer package for the HP Officejet 4500 wireless all-in-one printer.
Enjoy the convenience of wireless connectivity with the Officejet 4500 wireless all-in-one printer. You'll be able to print, copy, scan, and fax all from one device, plus print at speeds as fast as 28 pages per minute in black and 22 in color. And with tje Officejet inks, you'll get professional-quality color printing at a low cost per page.
http://mac.softpedia.com/get/Drivers/HP-Officejet-4500-Driver.shtml
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 13, 2010 | HP Office Equipment & Supplies
How do you turn off power save mode on the hp officejet 4500 printer? Thank you in advance for your assistance.
Are you ready? T disable the Power Save on your 4500 hp all in one printer, d the fiollowing: ( Use The Printers Control Panel ) #1 press # and # at same time. #2 THen press 1, 2 7 4 in sequence. #3 GOTO underwars menu. #4 GOTO System menu. #5 Look for System mode Time out. Set value to 0. THat's it.. Enjoy Ken Mayer mayer.k@vetrizon.net
Oct 22, 2010 | HP Officejet 6500 Wireless All-in-One...
I ve just bought the HP Officejet 4500, I ve done everything allwright for installation of the machine, but in the last step where i have to install the cd (G510) I cannot make it because the disc is not...
You can still download the drivers/software from Hp official website. (click here), open this link and download whatever you need for your printer (for windows xp only).
If you need further help, let me know, but don't forget to include the name of the operating system installed on your computer.
Good luck.
Thanks for using FixYa.
Sep 17, 2010 | HP Office Equipment & Supplies
How do you turn off sleep mode on the hp officejet 4500?
This no doubt violated the warantee, but I got tired of turning the printer around and unplugging the power cord etc.
So I got a cord switch I had (Ace hardware 31089, others will not doubt work) and installed it in the power cord per directions.
Now it is easy to reach behind printer and cycle the power with the power cord switch and thus wake up the printer.
May 20, 2010 | HP Officejet 6500 Wireless All-in-One...
389 people viewed this question
Ben Johnson
