Question about Craftsman Garden
Can a craftsman tractor "model 60923" series "yts
  • 246 Answers
SOURCE: owners manual for a craftsman model 917255812 lawn tractor
Hello:
>>You can Use the Site Addys at this Site Addy; http://www.yetmans.mb.ca/antiques.html to Search and Locate New/Used Parts or for Manuals for this Unit.
Respectfully
John
Posted on Apr 21, 2009
  • 148 Answers
SOURCE: How to remove snow blower from Craftsman YS4500 garden tractor
Go to www.managemyhome.com to download the manual for free. Just type in the model # 944606950.
Posted on May 21, 2009
wadembly
  • 448 Answers
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Posted on Jun 08, 2009
mickey813
  • 472 Answers
SOURCE: I have the DYT 4000 model. My tractor will start
SOUNDS LIKE YOU HAVE ONE OF YOUR OTHER SWICHES ARE BAD LIKE THE SEAT
Posted on Sep 30, 2009
  • 78 Answers
SOURCE: need manual for craftsman snowblower 42 or parts below
Ok
That Snowblower is made by Agri- Fab for Sears/Craftsman .If you go online to the agri-Fab website it is possible to down load the manual or if you email them they will send you a copy. I have dealt with them.They have even sent me missing parts. GOOD LUCK
Mike
Posted on Oct 22, 2009
Owner's manual for craftsman YT4000 model 917.288561
Bob, Check the attached links, Craftsman Riding Mowers instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://lawnandgarden.manualsonline.com/manuals/mfg/craftsman/yt_4000.html
Craftsman 28925 YT 4000 24 HP 42 Yard Tractor Manual
Apr 05, 2016 | Craftsman Garden
What do I need to be able to use my Snowblower attachment Craftsman 2 stage blower 486.24839 933 on my Craftsman Riding lawnmower YTS 3000
Michael Brady,
Here is a customer contact reference for your records. For help and evolvement. Sears Customer Phone Number Shortest Wait Best Support .
Here is a review and site you can navigate for your decision Craftsman Dual Stage Snow Blower Tractor Attachment .
This second link shows a Husqvarna as an option to your rider Sears com. If it does not apply. The following will guide you to success
I have best results in the past by utilizing this link Craftsman Riding Mower Tractor Parts Repair Parts . Repair help and ask an expert in their arena.
Open any manual, there, are options for contact and assistance. Here is a phone number in the meantime for customer service 1-800-252-1698. You will see this example.
Fare well
Sep 30, 2014 | Craftsman Garden
Craftsman dgt 4000
Broken gear at the end of the steering linkage, or broken teeth, also check to see if the stationary gear mounted to the tractor itself isn't broken off or worn out.
Jun 08, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Its a 21hp 46'' cut craftsman yts 3000 riding mower
Richard:
Check your blades to see if they are balanced. They should sit level when you put them on an arbor, (something pointy that you can put in the hole in the blade that will not go all the way through the hole. If the blade is heavy on one side you can grind or file the heavy end of the blade (I sharpen the blades and the heavy side gets extra sharpening to remove the excess weight on that side). Also check the spindles that you bolt the blades to when you install the blades. make sure that there is no slop in the spindles... they must not wobble. If they wobble, you didn't keep them greased. You'll have to but new spindles... they're not hard to install.
Nov 11, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to fix the toe out problem on my 2010 craftsman lawnmower?
Your gonna have steering rods called tie rods going to each spindle (wheel). Most lawnmowers dont have threaded tie rod ends where you can unbolt it and turn it in or out to achieve perfect alighnment. If its a larger expensive tractor you will find this and its a easy fix but most likely you just have a bend in one of the tie rods or on some cheaper models there could be a plastic bushing warn out causeing play in the front end.( Being able to slightly turn wheels without steering wheel turning) I would most likely say you have a bent steering rod or two... GoodLuck Ken
Aug 04, 2012 | Craftsman Garden
Where can I get a free 4500 yts Craftsman tractor manual
Go to sears parts (http://www.searspartsdirect.com/partsdirect/index.action) and type in your model number. The model number is found under the seat and starts with a number like 917.XXXXXXX. Click model search and then GO. After the site finds your equipment look all the way over to the right it will say "get manuals for this model"
Dec 07, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
Hi, My YTS 4000 is shutting down after mowing for a short period. I believe it is not getting fuel flow. could you assist with this problem?
no professional, but my father's Murray did the same thing a few years back and it was the Coil going bad. Replaced it and it was fixed. Hope this helps.
Nov 11, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
YTS 3000 clutch return spring noise, sounds like it is rubbing on something when you release the clutch but I can't even find the spring
The spring will be attached to the tensioner pully right on top, there is a threaded bolt with nut holding the spring on, I just had to order the clutch cable because the spring broke, from rubbing on metal when engaging and disengaging the clutch lever.
Jul 30, 2010 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Garden Logo
115 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
