Question about Microsoft Windows XP Home Edition
Computer lost os
Error -- winlogon.exe- unable to locate component
this application has fail to start because SHLWAPI.dll was not found. Reinstalling the application may fix this problem.
I assume I need to reinstall windows xp?
  • harcarphoto Jun 16, 2008
    I don't have a CD.
  • 106 Answers
Instead of doing so, you could perform a repair on it. Run the cd, skip the first screen indicating the repair (which takes you to dos) and at the second screen asking you whether to install xp or perform a repair, just choose the repair option (R).
If you have access to the desktop on that machine, then run service pack and hopefully it'll take care of the issue.
the majority of the time, winlogon issues could be related to viruses or spyware.
Posted on Jun 16, 2008
My call of duty games not working.it says that Entry point_binkcontrolbackgroundio@8 couldnot not be located in the link library binkw32.dll
Try uninstalling and reinstalling the game and make sure your antivirus is turned off while installing, sometimes they will interfere with an install. hope this helps
Oct 14, 2014 | Operating Systems
Game will not start. error message comes from TOPGUN.EXE unable to locate component' this application has failed to start because d3dx9_40.dll was not found. reinstalling the application may fix this...
It sounds like your copy of Top Gun is corrupt. If you downloaded it from the internet, you should try to find another version. If you purchased the game then your best bet would be to call customer service and see how to get your game replaced.
May 04, 2011 | Cosmi Operating Systems
When i try to shut down my computer a blue screen appears with an error report : stop:c000021a {fatal system error}
This is the cause:
The STOP 0xC000021A error occurs when either Winlogon.exe or Csrss.exe fails. When the Windows NT kernel detects that either of these processes has stopped, it stops the system and raises the STOP 0xC000021A error. This error may have several causes. Among them are the following:
  • Mismatched system files have been installed.
  • A Service Pack installation has failed.
  • A backup program that is used to restore a hard disk did not correctly restore files that may have been in use.
  • An incompatible third-party program has been installed.
If possible contact a local technician to the do the below,if you are not sure of this process.
and also ask him to take a backup of your registry keys and create a system restore point without fail.
To troubleshoot this problem, you must determine which of these processes failed and why.
To determine which process failed, register Dr. Watson as the default system debugger (if it is not already the default debugger). Dr. Watson for Windows NT logs diagnostic information about process failures to a log file (Drwtsn32.log). Also, you can configure this program to produce memory dump files of failed processes that you can analyze in a debugger to determine why a process fails.
To set up Dr. Watson to trap user-mode program errors, follow these steps:
  1. At a command prompt, type System Root\System32\Drwtsn32.exe -I, and then press ENTER.
    This command configures Dr. Watson as the default system debugger.
  2. At a command prompt, type System Root\System32\Drwtsn32.exe, and then select the following options: Append to existing log file
    Create crash dump
    Visual Notification
  3. After the computer restarts from the STOP 0xC000021A error, run Dr. Watson (Drwtsn32.exe).
  4. View the Dr. Watson log to determine what user mode process may be causing the problem.
  5. If the Dr. Watson log does not contain sufficient information to determine the cause of the problem, analyze the User.dmp file to determine the cause of the STOP 0xC000021A error.
    If Dr. Watson did not create a User.dmp file for either Winlogon.exe or Csrss.exe, you may have to use a different tool to generate a memory dump file of the process that fails. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 241215 (http://support.microsoft.com/kb/241215/ ) How to use the Userdump.exe tool to create a dump file Note Follow the instructions in the Knowledge Base article to troubleshoot a process that shuts down with an exception. While you follow these instructions, monitor the following processes to troubleshoot the STOP 0xC000021A error:
    • Winlogon.exe
    • Csrss.exe
    Note Most STOP 0xC000021A errors occur because Winlogon.exe fails. This typically occurs because of a faulty third-party Graphical Identification and Authentication (GINA) DLL. The GINA is a replaceable DLL component that Winlogon.exe loads. The GINA implements the authentication policy of the interactive logon model. The GINA performs all identification and authentication user interactions.
It is very common for certain types of remote control software to replace the default Windows GINA DLL (Msgina.dll). Therefore, a good first step is to examine the system to see if it has a third-party GINA DLL. To do this, locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Value = GinaDLL REG_SZ
  • If the Gina DLL value is present and if it is anything other than Msgina.dll, it probably means that a third-party product has changed this value.
  • If this value is not present, the system uses Msgina.dll as the default GINA DLL.
If this error first occurred after the installation of a new or updated device driver, system service, or third-party program, the new software should be removed or disabled. Contact the manufacturer of the software to see if an update is available. For more information about hardware and software vendor contact information, visit the following Microsoft Web site: - http://support.microsoft.com/gp/vendors (http://support.microsoft.com/gp/vendors) Last known good configuration If the previous steps in this article do not resolve the problem, start the computer by using the last known good configuration. To start the computer by using the last known good configuration, follow these steps:Note Because there are several versions of Microsoft Windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
  1. Click Start, and then click Shut Down.
  2. Click Restart, and then click OK.
  3. Press F8 at the indicated time:
    • For an x86-based computer: When a screen of text appears and then disappears , press F8. (The screen of text may include a memory test, lines about the BIOS, and other lines.) There may also be a prompt that tells you when to press F8.
    • For an Itanium architecture-based computer: After you make your selection from the boot menu, press F8. There may be a prompt that tells you when to press F8.
  4. Use the arrow keys to select Last Known Good Configuration, and then press ENTER.
    NUM LOCK must be off before the arrow keys on the numeric keypad will function.
  5. Use the arrow keys to highlight an operating system, and then press ENTER.
Dec 23, 2010 | Operating Systems
I have a dell desktop 8300 dimension running on xp. when opening itunes an unable to locate component window pops up stating "This application has failed to start because JavaScriptCore.dll was not found....
This is due to the dll file is not registered. Try to register the dll file will resolve your problem. For this
1st step: search for JavaScriptCore.dll file and copied the same to system32 folder using search menu.
2nd Step: type regsvr32 JavaScriptCore.dll in run menu and enter, it will rigester the dll.
Still you are facing the problem, once again reinstall the application.
Revert back for more assistance and also give your valuable feedback/rating for the solution provided.
Feb 10, 2010 | Operating Systems
Nerror rundll32.exe
most likely due to a virus infection scan your computer for viruses with latest virus definition updates
and
use system restore to restore sytem to a previous date when it was working properly
Jul 11, 2009 | Operating Systems
LSASS "Unable to Load Component" Error
I think because of the power failure, some parts in your hard drive are broken, bad sector may be.
So, when reinstalling, I suggest you to do full format, not a quick format. That way, the installation will recognize the place where bad sector is located, and will not put anything at that place.
Can not load component, usually because windows can not read from the disk.
Dec 07, 2008 | Microsoft Windows XP Professional
Microsoft Windows XP Home Edition Logo
104 people viewed this question
Top Microsoft Operating Systems Experts
Brian Sullivan
Brian Sullivan
Joseph Coppeto
Joseph Coppeto
M Beutner
M Beutner
Are you a Microsoft Operating System Expert? Answer questions, earn points and help others
