This problem only occurs when I scan or use photocopy mode. A black line is either produced electronically onto the scanned document file or, if a document is photocopied, is printed onto the photocopied page. The black line of 15mm width runs top to bottom on the left hand side of the longest side of the A4 copied document. The line is 30mm set in from the left hand edge of the document.
  • andy_fisher Nov 08, 2010
    I've checked the glass bed and the inside of the scanner area and no particles to speak of. The make and model is EPSON STYLUS PHOTO RX520. Attached is a scanned copy of gridlined paper which produces the same band when a photocopy is performed. Thank you for help so far. Let me know if image arrived ok?
  • 4,737 Answers
Check the Scanner Lamp Surface and make sure nothing is stuck . If you see something on it, you need to disassemble the machine and clear the obstruction. The lamp faces upward on the glass bed, so to check the lamp, run a scanning and unplug the power cord while the lamp reaches the middle, otherwise it's not visible when you Turn off the machine as usual. It'll be hidden on the other end.
It's also possible that there's something wrong with the Flex cable which connects the Lamp to the motherboard.. or it could be the motherboard itself. First try with the Scanner Lamp and it'll be easier for you to troubleshoot.
Good luck.
Posted on Nov 08, 2010
  • 2,069 Answers
You should service your unit and watch out for dirty particles especially on the scan/ photocopy glass. also, please indicate exact model of your printer for a followup if this doesn't help.
  • Muzahura Frank Nov 09, 2010
    you need to clean the print-head and run a nozzel check
Bizhub C652 has horizontal lines.
its important to find out whether the \'lines\' are in scan direction/ or only through Radf or only from scan glass,
if the lines are only showing when documents are fed throught the Radf, then the problem lies with the document scan plate( left of the main glass platen (about 2" in width)) or with the scan plate blade cleaner
if the lines ONLY appear when copying from the Glass then the issue lies within the optics (probably nothing more than a clean will be needed)
another question would be to ask if the lines are solid (black line overprinting image) or if they are \'missing\' lines where the image has failed to copy, sometimes it can be hard to work out which side the fault lies,so try shaded greys as a copy original .
if the scan lines are appearing on both Radf and Glassplatten ,mode then the issue may be dirty optics/ccd sensor or it could e an indication of the ccd failing or image control pwb in error while interpreting the image file.
what to do
1) place a grey sheet of paper in the Radf and have the copier photocopy both sides of the original and print to single sided sheets ( so the printer turns the original over to complete the task)
observe the result.
2) have the copier photocopy directly from the platten glass- single sided.
observe the result.
ckeck to see if the error has appeared on both sets of prints ,
if the error has only appeared in the first set of prints then the issue may be a tiny DOT on the slit glass (left of platten) - a dot on this glass will indeed appear as a Line as the original is scanned across the glass.
hhope thhis helps
Feb 19, 2014 | Konica Minolta Bizhub C652 Color&b/w...
How to make darker copies
if your referring to photocopying but printout is darker, it doesnt work. canon copiers produce copies like the original or better than the original sometimes. try to scan the file in custom mode and adjust the brightness and contrast and click preview to view the outcome before scanning it then print it later
Sep 30, 2013 | Canon PIXMA MP210 Photo All-In-One Printer
How do I scan multiple documents and email them as one attachment
1. Click PDF on the Custom Scan with One-click tab or click PDF in the one-click mode screen to open the PDF dialog box.
* If you wish to convert the text in a document to editable text data, scan the item with the OCR. The precision of OCR is affected by the nature of the scanned original
2. Select the type of document to be scanned.
Important
To scan correctly, select a document type that matches the document to be scanned.
3. Select a file type to save the scanned image.
Select PDF, PDF(Multiple Pages) or PDF(Add Page)
Important
Click Set... to open a dialog box and specify the PDF compression type and other advanced settings for creating PDF files.
4. Place the first original on the scanner and click the [Scan] button at the right bottom corner of the PDF window.
5. When scanning is completed, place the next original and click the [Scan] button.
6. Repeat scanning by clicking the [Scan] button until you finish all the originals.
7. When all the original is finished, click the [Exit] button.
8. When the scan is complete, it automatically starts the application program that displays PDF files and opens the scanned image file in it.
To scan a text document or black and white document, you are recommended to set the Scan Mode to Black and White or Grayscale.
You are recommended to limit the number of pages in any one multiple PDF file to 20 or less if you are scanning a color document with the Image Quality set to 300 dpi and the size to a setting equivalent to Letter size.
Aug 07, 2013 | Canon MP Navigator EX for Windows
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
When I am photocopying and scanning documents I am noticing vertical lines on the print in the middle of the page which is ruining the copy, any ideas? Alos message intermittently coming up waste toner...
Most probably you are using the automating document feeder for the photocopy or scanning. If you can lift up the document feeder , there should be the mirror where you can put the original document for manual photocopy or scan. Clean the edges of the mirror with a printer cleaning liquid. There may be some foreign particle stuck there or it is just dirty from long use. Hope this helps.
Sep 02, 2011 | Office Equipment & Supplies
I am scanning a photo. I have translucent lines running horizontal through the picture before i print it.
Documents scanned/copied from the document feeder pass over a thin glass area where scanning occurs. Clean this area if sent faxes, copies or scans have black or white vertical lines.
  1. Lift the document cover to expose the platen glass.
  2. Wipe the ADF scan area (C) with a clean, soft, lint-free cloth moistened with water.
  3. Then wipe with a clean, soft, dry, lint-free cloth making sure there are no residues left, especially on the platen glass.
  4. Close the document cover and make a copy of a text document to confirm the black line has disappeared.
Dec 20, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Every time I try to batch scanning on my Pixma MP530 I get a vertical line running through the page. I've cleaned the platen glass, the inner side of the document cover, the transparent sheet (I even...
When using the ADF to scan multiple document the scanner assembly stay stationary and the paper is fed across it. Where the scanner parks for this there is something between the scanner and the document, likely on the glass. Often there is a small strip of glass on one end of the scanner bed. Clean here if there is one, otherwise look around and I'm sure you'll find it. Remember, never spray cleaning solutions directly onto the glass, always onto a cloth or towel first. The scanner has a calibration strip that can be damaged otherwise.
Feb 05, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Scanning slides produces black images. Slide
Make sure the white document matt from uner the lid has been removed. Also in Epson scan make sure you have changed the document type from reflective to Film and Colour positive.
Jul 03, 2009 | Epson Perfection V350 Flatbed Scanner
Can i use my DCP 130C machine for photocopying? for small business. meaning iwill frequently use my machine for photocopying. would it be okey?What could be a posible problem in the future if there's any
You may use this a copier but usually, all in one printers used as copier take a long time to produce print outs. It isn't as robust as It usually scans the pages first (duration is the same as scanning a document) then prints it out (duration is the same as printing a document from a PC).
In my experience with our multifunction printer, a single page can be photocopied in about 45 seconds to 1 minute. It isn't as robust as photocopying machines.
Jun 25, 2009 | Brother DCP 130C All-In-One InkJet Printer
130 people viewed this question
k24674
