Question about HP Pavilion zd8000 Notebook
Probable loose dc jack on hp zd8333cl laptop
Has problems charging...cord/plug (end that goes into the dc jack) has to be wiggled and adjusted it seems to get it to charge. Once I "play" with it to get that "sweet spot" it will charge. Usually, i have to leave it alone for a while to allow the charge and or use it on ac power. Its been getting harder and harder to get that right position. I had entire ac adaptor (cord and voltage adapter "brick") checked by the Geek Squad. They verified with a multimeter that the proper voltage is at the plug end that goes into the laptop. I have found a dc jack online for under 20 bucks...do I need to replace it or just fix the one that's there so its not loose anymore. if i can somehow tighten down the probable loose connection between it and the motherboard? i can't even figure out how to get the bottom cover completly off. i have taken almost a dozen little screws out...everyone that i can see/get out.
  • kiwi_zg Jul 23, 2008
    I have the same problem on a HP laptop.
  • Anonymous Apr 02, 2009
    have same problem for ac aspire 3600
    Problem Solver:
  • 5 Answers
Hello, If you are still in need of getting this fixed I can help. I have replaced many of these DC jacks and have since moved my service to ebay. If interested you can look at the ebay link that I have provided below. This will take you directly to my service ad. As you will see, I am a certified computer technician and on top of that, I have a 100% positive feedback rating. My price is very reasonable as well. So if you would like to get your system fixed, please consider me. The link is: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=220284642915&ssPageName=STRK:MESE:IT&ih=012 Thank you and I look forward to hearing from you! Sam
Posted on Sep 27, 2008
  • 752 Answers
It is not a job for beginners. It requires COMPLETELY dismantling the computer and resoldering the jack to the motherboard. One slip and the computer is a paperweight. Check local PC repair shops for a price to fix it.
Posted on Aug 05, 2008
HP Elitebook 2530 Pindicator says battery charging but battery not charging
Could be a back power brick or DC jack yes. Power off the computer and remove the battery. With the battery out plug in just the power brick and turn on the computer. If the computer doesn't power on gently wiggle the plug into the laptop and repeatedly hit the power button if it comes on briefly then off again you dc jack is loose. If it doesn't come on at all then its the power brick. If the laptop comes on gently wiggle the plug into the PC. Powers off while wiggling DC jack.
Jul 09, 2012 | HP EliteBook 2530p Notebook
Gateway MS2291 wont power up
Did you check the DC Jack where the Power Cord plugs into the laptop? If it is bad (wiggly or loose) then the laptop will not power on. Take an ink pen and put it where the power cord would plug into the laptop and see if the jack wiggles or is broken. If so, that's your problem.
The old power cord might be some good if the problem is with the DC Power Jack.
May 01, 2012 | Gateway Computers & Internet
Gateway kav60 not charging. i have to wiggle the cord and sometimes it refuses to charge.
I guess you've got a broken laptop power dc jack or power cable.
Symptoms of a broken Laptop DC power jack:
- The laptop only operates when you hold the DC power plug in a certain direction (DC jack is broken or loose).
- The laptop only runs on battery power (no power is getting through the DC jack).
- The laptop gets no power at all.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently due to a loose or broken power jack.
- The laptop suddenly shuts off.
- The DC jack may feel loose.
- Sparks come out of the back of the laptop when you insert the power plug into the DC jack.
Apr 21, 2011 | Lifetime Gateway KAV60 Replacement Laptop...
My HP dv7 laptop wont turn on I purchased a new battery and a new cord it worked for an hour then shut off again!!!!!!!!!!
Your DC connector is loose from the system board:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it's still under warranty, it would be fixed at no charge to you.
http://www.insidemylaptop.com/disassemble-hp-pavilion-dv7-notebook/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Dec 01, 2010 | HP Pavilion dv6000z Notebook
My HP dv2000 shuts down and does not turn back on. The power cord is connected but the charging light is not on.
Your DC connector on the system board is loose:
Problem symptoms:
If it is under warranty, HP will repair it. If not , read this:
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Thanks, Joe
Nov 30, 2010 | HP Pavilion dv2000t Notebook
I have ac adapter plugged into the wall, and into the computer, the charge pack light is green, the battery is in the computer and the computer won't turn on at all
You probably have a bad or loose DC jack on the laptop:
Problem symptoms:
http://www.insidemylaptop.com/laptop-dc-power-jack-repair-techniques/
Nov 30, 2010 | Gateway SL1450-30145063 Notebook
My compaq Evo n610c my battery wont charge when on ac power.The light for when the battery wont go on.
sounds like your DC coonector came loose from the system board.it is a common problem with laptops,
Problem symptoms:
here is how to repair:
Nov 26, 2010 | HP Compaq Evo n610c Notebook
Hi There, I have a HP Pavilion ZE4900 and recently the AC plug in won't work. I have taken the battery out and put it in another comuter that is the exact same and it charges fine, I put my battery in the...
If your computer won't charge the battery, but the battery charges fine in another computer, and you are sure that the charger is good, then your problem is probably the DC power jack. If you wiggle the end of the power cord where it attaches to you laptop, and it starts charging properly, then the DC power jack is broken.
Apr 26, 2010 | HP Pavilion Ze4900 Notebook
My laptop lenovo 3000 N100 battery has a problem.. therefore i purchased a new battery but the problem with this battery is that when i use the battery it runs the laptop for 10 -15 mins and then with a...
My Dell laptop has a power problem.
d600a.jpg?w=300&h=258
The Dell Precision M20 Battery stops charging when I move the power cord on the DC adapter. When I start moving the cord left to right, the power LED light on the front goes on and off and the battery charge LED goes on and off too.
dell-precision-m20.jpg?w=300&h=225
I removed the precision m20 battery and tested the laptop again. The laptop starts fine from the DC adapter when the battery is removed, but as soon as I start moving the power cord the laptop shuts off. It looks like the laptop looses power immediately.
If you have a problem like that, most likely it’s related either to the power adapter or the DC-IN power jack.
First of all, I tested the laptop power ac adapter with a multimeter. The power didn’t cut off no matter how badly I moved the cord. The power adapter output voltage was 15.45VDC all the time. That means there is nothing wrong with the power adapter and most likely there is a problem with with the power socket inside the laptop.
Now I’m going to test the power socket inside the laptop.
In order to access the power socket I had to disassemble the laptop and remove the top cover assembly with the display.
You can find disassembly instructions for many HP, Dell, IBM, Lenovo, Sony and Toshiba laptops in these service manuals and guides.
In the laptop I was fixing (Tecra M2) the power jack is attached to a DC-IN harness and this harness can be unplugged from the motherboard.
As you see, I removed the DC-IN harness from the motherboard, plugged in the power adapter and tested continuity with my multimeter as it shown on the picture.
When the power cord is still, the voltage output is 15.45VDC, the same as on the plug.
But as soon as I start wiggling the plug inside the jack, the power cuts off and voltage goes to 0. It means, the power harness is bad.
The problem was fixed after I replaced the defective DC-IN harness with a new one.
In some laptops the power socket (DC jack) is soldered to the motherboard.
If the battery stops charging when you wiggle the power plug inside the jack, either you have a bad power adapter (test it with a voltmeter) or the power jack is broken or loose.
You cannot simply unplug the jack and replace it with another one. You’ll have to unsolder the old jack and solder a new one back on the motherboard as I described in this post.
If the power jack is not broken but loose (not making good contact with the motherboard) you can resolder the old jack without replacing it with a new one.
If you want to buy a new one,you can see more information from http://www.udtek.com
Feb 18, 2010 | Lenovo 3000 N100 Notebook
Screen blackout when using AC cord
I think you're goin to have to replace your" dc-jack" as it's called. This is where your AC cord plugs into your laptop.DC-jack problems are very common in laptops.Over time they wiggle loose just enough to mess up the solder connection on the motherboard.Try gently wiggling your AC cord where it plugs into your computer ,if you screen returns to normal when you wiggle the plug a certain way,then you've most likely got a bad dc-jack.
Feb 12, 2008 | Dell Latitude D600 Notebook
HP Pavilion zd8000 Notebook Logo
179 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
