Question about Hoover Washing Machines
I have a Hoover SE147 with which the spin has stopped working - any ideas?
3 Suggested Answers
  • 6277 Answers
SOURCE: Hoover SE147 stays in early spin cycle and wont
9no promises but try this!)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Apr 25, 2011
  • 215 Answers
SOURCE: Hoover se147 washing machine, wont
Have you checked the carbon brushes within the motor, chances are they are worn. you will need to remove your motor to get to the 2 carbon brushes.these will be in a plastic casing, held in place by 2 screws. There is just 1 wire going to each brush. When brush is removed, the carbon should be at least 20mm long. If not replace with new
Posted on Aug 13, 2011
Hoover se147 washing machine fills with water then trips electricty
it has a short in it,could be the drain pump,or the wash motor or a bad fill vavle
Nov 10, 2014 | Washing Machines
I have a Hoover H160i that is coming up with E05 error. Any ideas?
Thank you. I ran a 2 and 3 wash (60 and 40 degree wash). It allowed me to put it onto a rinse/spin/cycle but it didn't allow the wash.
Nov 28, 2012 | Hoover H160I Front Load Washer
Hoover se147 washing machine, wont spin at all , it will fill and drain. Have checked pressure switch and appears okay. Have also had circuit board out and that seems okay.
Aug 13, 2011 | Washing Machines
Hoover SE147 stays in early spin cycle and wont complete
John C
Apr 25, 2011 | Hoover Washing Machines
Hoover hse 130m washing machine problem
i found a squirt of wd40 worked wonders
May 27, 2008 | Hoover H130E Front Load Washer
Hoover Commander 7kg (about 9 years old) not working. It does not spin in any wash cycle, although it can be done manually with ease in the 'spin dry' cycle. There was a strong rubber smell before. Any...
I have a Hoover Commander Model 2045LOAUS. The machine washes OK but will not spin (ie pump the water out). Could it be a burnnt out spin solenoid or motor??
Apr 26, 2008 | Hoover Washing Machines
Hoover washer dryer saver 1300
I have inherited a hoover saver 1300 in new flat, the dials have worn away and it goes onto drying mode after wash, how can i have it on wash and spin only - NO DRYING? Thanks
Apr 12, 2008 | Hoover H120M Front Load Washer / Dryer
Hoover windtunnel
would suggest the drive belt is stretched and thus is slipping when contact is made with the carpet.
Jan 14, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Washing Machines Logo
154 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
