Question about Sony Cyber-Shot DSC-S50 Digital Camera
I cant find where my usb port is on my camera
Just left side of your camera down the volume button, there is rubber cover, plz pull it and you will see usb port.
Posted on Nov 10, 2010
WHY MY NIKON COOLPIX S3000 FLASH NOT WORKING?
okay let mi think....
you cant charge a nikon camera via usb port the usb port is data only
please reply and try to use a nikon coolpix s3000 charger
Feb 22, 2013 | Nikon Coolpix S3000 Digital Camera
When I connect My Samsung VP-D77i Camcorder to my Laptop I always get a message saying "cant open camera device". My Laptop does not have a fire wire port but only with USB ports. It has Windows 7 Pre
First, try attaching the camcorder via usb cable with the camera OFF, then turning it on. This may trigger Windows to activate the driver scanner and activate the driver. If you've been attaching with camcorder off, try attaching with it on, to see if that activates driver installation.
If that doesn't work, you may have a low-power usb plug; often the usb ports in the back of the computer put out more juice than the handy ones on the front. You may also need a shorter and more robust usb cable; I've found with various cameras and phones that certain usb cables work fine for recharging but won't necessarily provide adequate data transfer.
Jul 03, 2012 | Samsung VP-D77i Mini DV Digital Camcorder
I lost my charger for my Sanyo x1250 digital camera. Cant i use my USB cable as an alternative charger?
Did the mains charger connect to the camera's USB port? If so, it will probably charge from any USB port including your computer. Otherwise, no.
I found a charger (and batteries) for this camera on Amazon by searching for "Sanyo x1250 charger".
Nov 30, 2010 | Cameras
I think my A735 General electronics camera wont work because i have a disfucting USb but my mouse is plugged into the other usb and without the mouse plugged in i cant download anything help?
Your computer isn't seeing the camera through the USB port. You should of had a disk that came with the camera try that and if you don't you have to have a serial driver for your usb port ,so go to device manager and add new device.
Dec 26, 2009 | General Electric A735 Digital Camera
When i plu gmy digital camera into my usb port my
i cant get camera to connect or com on when i plug it in
Aug 20, 2009 | Cameras
I cant see what im shooting at its all fuzzy with colors
Normal 0 Probably has corrupt driver.
Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Dec 30, 2008 | Logitech QuickCam Messenger Web Camera
USB cables
make sure you plug the small plug on your usb cable into your camera...easy..
the big plug on your usb cable must be plugged into your usb port on your computer. It can only fit in one way and not upside down. It will also fit into your network port, but this not correct port. If your usb plug fits into the port the right way up, and upside down, then it is the wrong port. If your computer is old, then it may not have a usb port.
Oct 08, 2008 | Cameras
When i plug my USB from my camera into the computer nothing pops up and i cant download my pictures. i have the sanyo VPC-E760
Hi!
Make sure that both ends of the USB cable are properly connected to your camera and PC. After that, you should TURN ON the camera for it to be detected by the computer.
If that does not work, connect your camera to a different USB port on the computer (when using a desktop, use the USB port at the back).
Good luck and have a nice day!
Oct 02, 2008 | Sanyo Cameras
Charging camera
Are you using the front usb ports on your computer? My computer's front usb ports were not able to charge my camera, but the rear usb ports were able to (the charging light should stay on if it's charging correctly). I'm not an expert on this stuff, so maybe there's a power output difference between your frontal and rear usb ports.
Also, on the CD there was a camera connection driver. You might try installing that and see if that makes a difference?
Sep 28, 2008 | Kodak Easyshare M753 Digital Camera
Drawing to much power over usb port
use a USB port on the back of the PC, not off a hub, or use a powered hub, It cant take more than 500mw of power per USB port, even though there are 2 ports, they may be off the same controller inside the pc. I use a powered hub and have not had that problem ever since. I had a webcam that drew 450 and no other device worked off that port.
Feb 25, 2008 | Samsung Digimax S630 Digital Camera
Sony Cyber-Shot DSC-S50 Digital Camera Logo
27 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
