Question about Alpine MRP-M1000 Car Audio Amplifier
There is a smell in my car every time I play my system for long periods of time. Its a burning smell. Everything is wired correctly and I have a separate battery in the back of my car to power my subs. I have two alpine type R's 10 inch and a CDE 102 radio. My lights dim every time my bass hits in my car. Is my amp bad? And how do i fix my lights dimming? Also the battery in the back of my car is a stinger battery.
    Sniper:
  • 59 Answers
The problem could either be the amp over-heating or the subs could be over-heating as well. One of my friends owns an Alpine MRD-M1005, and one day they decided to clean it inside and out and realized they had some burnt spots on the circuit board, although they never smelt anything burning, and the amp still works fine.... As for the lights dimming you should probably buy a power Capacitor, atleast a 1 Farad or larger.
Hope this helps.
Posted on Nov 08, 2010
So I just bought a kicker cx 300.1 mono block amp to run my 10 inch comp d 4 ohm 300 watt sub. I ran it parallel and it smells like the coils are burning. Help
That's only normal for the burn in period. Make sure you're not running it in 2 ohm by wiring the sub wrong. That amp is not really 2 ohm stable for a sustained period
Feb 03, 2015 | Kicker Car Audio & Video
Car dashboard lights wont turn on and smell of burning wires
If you're smelling insulation burning - STOP. Fuses should be blowing before insulation melts / burns.
Have the car checked my a trusted mechanic before using anything in the car that makes the wiring burn or melt.
Apr 16, 2014 | 2001 Ford Taurus
Hi iam having an electrical problem after jump starting car at first i put the jump cables wrong way round !! then corrected error started car ok but had a fuse burn smell ! sho checked everything and...
check all positive wires coming from battery sounds like you melted one and it's touching something it shouldnt, Thats what u smelled, clean and tape damaged wire(electrical tape) check wires behind fuse block also
Aug 30, 2011 | Hyundai Excel Cars & Trucks
2001 aurora when fan is on high for a period of time it smells like the header is burning.
Not sure what a burning header smells like, but I would expect two possible smells. First, if the blower motor itself is going, you might smell the windings getting hot - like a transformer burning. If this were the case I would expect that the motor wouldn't spin on the low speeds.
The other smell you sometimes get is when the heater core leaks. Then you will get a coolant smell inside the car and sometimes (usually) a wet carpet as well.
Feb 22, 2011 | 2002 Oldsmobile Aurora
When i am driving on the highway for long periods of time, my car has a really foul burning smell to it, what is causing that?
WHAT SMELLING ROTTEN EGG SMELL OR BURNING RUBBER SMELL.MAKE SURE YOUR EMERGENCY BRAKES RELEASED.YOU WILL SMELL BRAKE SHOES BURNING UP OVER HEATING.
Jan 27, 2011 | 2009 Pontiac G8
It smells like something is burning smells like the gas is not burning very harsh odor that burns your eyes after a period of time
If it smells like an incomplete combustion smell, clean the burner first. I'm assuming it used to work and now doesn't? If it never worked correctly it may have the wrong jet in it. There is a jet for propane and one for natural gas. They do not interchange. If it smells like plastic burning, something probably got past the screen and fell into the burner.
Sep 28, 2009 | Dryers
I have a Kenmore Elite microwave oven... 69-65e05590-000637. We noticed that it would not heat food or liquids... played with the power level a bit and it started to heat again...then a day or two later we...
Is this oven still under warranty? If so, take advantage. If not, remove the power plug and the case. Short out, with a screwdriver, the large can-shaped capacitor with two terminals sticking out. Check the wiring and circuit board for signs of burning. If everything looks ok, remove the thin sheet metal wave guide that sits above or beside the microwave energy port into the cooking cavity. Under the sheet metal, there is a metal fan-like device called a 'stirrer' that has a plastic bearing. Remove this stirrer and smell the bearing. If it smells like the burning wire smell, replace the stirrer. You can buy it through 'Sears Parts' online.
Sep 14, 2009 | Microwave Ovens
Hoover HDC7FM condensor dryer starts then cuts out
Open the dryer door (right after the breaker trips) and check for a burned smell. If it smells in the dryer, you probably have a direct short in the dryer wiring. Check for a burn smell at the wall socket. There may be a short in the socket itself, but not likely unless a mouse is lying across the contacts in the wall.
If everything checks ok replace the circuit breaker if this is an older home. Circuit breakers weaken after years of use. A 30 amp circuit breaker will trip at a much lower amperage after a period of years especially if it has tripped often.
Mar 12, 2009 | Hoover HDC7FM Dryer
Electrical burning smell in house
Mhenn, It is my guess that the 'electrical burning' smell is from your heating system. Since there is no smoke and the walls are not warm.... then there is no real problem. The smell maybe just dust has collected in the duct work that is burning off the central heating systems electrical heat strips. If you have electrical heat strips then that may be the problem. If you have a central gas heat system, it may be the same type problem. Hope this helps you. Henry
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
Feb 05, 2009 | Honeywell Electronic Programmable...
Bad smell from ac unit in my house
does it smell like literally , dirty socks?if so it is dirty sock syndrome, a plague of heat pumps for years. if it smells like an electrical melting or burning of wires then time to call a pro.it could be a weak capacitor or a weak fan motor. if it is dirty sock syndrome then its the microbes that thrive when temps are middle temps and reproduce when temps are hot and cold in intermittent days. hot one day and cold the next equals call for cool then call for heat and hot steam from heated coils cause s bacteria to grow and microbes to spread across coil. when you switch back it causes the smell.if the coil is clean you can spend a chunk of money on sanitizers but best bet is to run it cool for hot weather and hot for cool weather. the transitional periods are what create the smell. avoid semi cool and semi hot periods. this condition is common to acs from all brands . lots of stuff on the internet about dirty sock syndrome
Oct 31, 2008 | Sharp CV-P09FX Air Conditioner
Alpine MRP-M1000 Car Audio Amplifier Logo
178 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
