Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
Pump keeps running - Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
  • 2,382 Answers
The Saniplus has a pressure chamber and at the bottom is a rubber membrane which acts as a float switch. Water pressure pushes up on the membrane, the unit turns on, pumps out the waste and as the pressure is released, the membrane goes back down and shuts off. So the problem might be a warped membrane, something stuck at the bottom of the membrane or the microswitch may be stuck on the on position. You will have to open the unit and remove the motor and pressure chamber to inspect it. Also the water level on the toilet is meant to be very low, Saniflo uses a rear discharge toilet, not a bottom discharge (standard toilet). Unfortunately the water level cannot be adjusted on Saniflo toilets.
The following are the possible problems and solutions:
  1. The tank flapper (Flush Valve) leaking allowing water into bowl. Make sure flapper is fully seated. If flapper is fully seated and still is leaking replace flapper.
  2. Faulty Non-Return Check Valve, water leaking back into Macerator. Clean and Inspect check valve replace if after clean water still flows back into Macerator.
  3. Check micro switch, the micro switch turns on pump when the water level reaches to a determined level. Location of switch is in the pressure chamber. Check to see if switch is sticking.Note: For safety Macerator should never be operated with lid open
Posted on Nov 08, 2010
I have a TBI on my Chevy and when I turn the key on it keeps running the fuel pump after the 2 seconds like to know what to look for and where to find it
didnt specify year model or engine --generic answer --if the tbi is flooding ---check the fuel pressure regulator --and the tbi itself
Apr 16, 2017 | Cars & Trucks
Fitted one of your shower pumps when I turn off shower pump keeps running terry
cannot be a fixya pump as the site sells nothing
if the pump keeps running after the water is turned off then it is the pressure switch that is not working
contact your pump supplier if the pump is new or get a new pressure switch
Oct 08, 2016 | Plumbing
Why does my 2012 dodge ram 1500 fuel pump stay on...
About 117,000 results (0.73 seconds) Search Results
    TIPM Repair & Bypass Solutions for 2007-2014 Dodge ...
    www.verticalvisions.com/TIPM_solutions.php
    2011-2012 Dodge Ram 1500; 2011-2012 Dodge Ram 2500; 2011 Chrysler Town ... test your fuel pump relay, and bypass a bad fuel pump relay to stay on the road. .... Mytesting/bypass device will often narrow down your problem to the TIPM ...
    Dodge Ram 1500 Questions - fuel pump keeps running ...
    www.cargurus.com > Questions > Dodge > Ram 1500
    CarGurusNov 1, 2013 - fuel pump keeps running when key removed - 2011 ram 1500 slt quad ...fires right up but will not stay running unless I keep my foot on the gas.
    I Changed The Fuel Pump On My 97 Dodge Ram 1500. Ran ...
    CarGurusI changed the fuel pump on my 97 dodge ram 1500. Ran great for 2 days then stopped running. I can hear pump working, replaced fuel system relay, engine tur... ...Jun 24, 2012 at 03:48 PM about the 1997 Dodge Ram 1500 2 Dr ST 4WD ... The truck fires right up but will not stay running unless I keep my foot on the gas.
    2011 Dodge Durango Fuel Pump Relay Stays Engaged ...
    www.carcomplaints.com/Dodge/.../fuel.../fuel_pump_relay_stays_engag...
Feb 03, 2016 | Dodge Cars & Trucks
Pump keeps running
THE ELECTRIC WATER PUMP CAN RUN AS LONG AS THE ENGINES ECU GIVES THE ORDER!!IT MUST NOT RUN MORE THAN 2 HOURS!!COOLING FANS DO NOT WORK AT ALL?NOT EVEN WHEN U TURN ON THE A/C??
Apr 08, 2014 | 2002 Volkswagen Beetle Turbo S
1989 range rover not pumping petrol 3,9 runs on gas but will not pump petrol
Hi there, did you run the petrol low or out, the fuel pump will keep pumping while the key is on and if your running on gas them it's still running, I would say the fuel pump has failed due to no lubrication from fuel, be sure to keep your petrol tank at least at 1/4 of tank full
Mar 06, 2014 | Cars & Trucks
Where is the fusible link that keeps feul pump from running on 1992 s10
there may be a safety shut off switch that has been activated.
Feb 17, 2013 | Chevrolet S 10 Cars & Trucks
My sunk pump machine keeps running since last night. Is that a problem?
Check your float it may be stuck causing the pump to keep running.
Jun 10, 2010 | Little Giant 10 Cia, 1/2 Hp, 83 Gpm...
Gas not getting to engineto keep it running
CHECK FUEL PUMP FUSE AND RELAY.IF BOTH GOOD LISTEN FOR FUEL PUMP RUNNING IN GAS TANK WHEN YOU TURN ON THE IGNITION SWITCH.YOU HEAR NO SOUND.SCAN VAN FIRST FOR PCM FAULTS SINCE IT CONTROLS FUEL PUMP IF PCM GOOD.FUEL PUMP IS BAD.IF FUEL PUMP RUNNING REPLACE FUEL FILTER.
May 22, 2010 | 1995 Ford Windstar
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
1,515 people viewed this question
Top Saniflo Home Experts
paulcarew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
