I am trying to remotely print froma server running Windows server 2003. My machine is windows 7. Do I need to install the driver for my remote printer on the server. I
    President:
  • 3,278 Answers
Hello.
If your printer is on your network, the driver is installed on your computer, not on the server.
If you haven't done so, set up your printer on the network. Once your printer sees your network, then any computer on your network would/could see the printer. Install the printer's driver for that operating system. In other words, if you have Windows 7 installed on the computer, find the printer through your network and install the Windows 7 driver for that printer. If you have Windows XP on another computer that is on your network, install the Windows XP driver for the printer on that computer.
Hope this helps.
Posted on Nov 08, 2010
Run a cnet cnp430 on windows 7
I hope you are connecting the print server to a network hub or switch and not trying to connect directly to your Win 7 machine.
There are no drivers, a print server is a network device. Connect the ethernet cable from print server to your router. connect your printer to the switch. Search the network for the printer.
Apr 06, 2014 | Cnet CNP 430 (CNP430) Print Server
Netgear ps121v2 Smart Wizard does not appear
If you are running WIndows 7 64 bit, you need to run the 64 bit version of the installer. Look in the directory ...\bin\driver\MFP\Utilityx64
Also in, Windows 7 you need to run the install wizard as administrator, since it is installing drivers.Right click on SetupWizard.exe and select "Run As Asministrator".
Jan 19, 2013 | NetGear PS121 Print Server
For key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install...
1. instal server utility on Windows 7
2. right click icon choose properties
3. select compatibility tab choose your o/s
now run it and presto......
regards, dean
Jan 08, 2011 | Keyspan USB Server US-4A (d47710) Print...
I have window 7 64bit and the keyspan software installed fine but the server utility does not recognize the print server. I allowed port 3842 tcp and udp through the windows firewall but still no luck.
for key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install windows virtual pc, start it up and insert a windows xp pro install disk. for info on this google 'workaround to install windows xp mode in windows 7 home premium and home basic') Once you have windows xp mode running, install the keyspan server utility int he virtual machine and setup as usuall. then share the printer. go to windows 7 devices and printers and add a printer, chose a network printer, select the new virtual machine and select the shared printer. In order for the printer to work just start up the keyspan program from windows 7 and print....your welcome.
Sep 08, 2010 | Keyspan USB Server US-4A (d47710) Print...
MY WINDOWS 7 LAPTOP WONT RECOGNISE PRINT SERVER
Please note that all old devices drivers have upto windows xp or 2003 server files becuase now only windows 7 has been launched in the market. So don't worry you can download print server drivers from the site .
If your print server is USB connected , the windows 7 will say found new hardware after that it will ask you update drivers, there you can click on have disk and locate the driver files where you have kept and clickon windows 2000 or xp from here you can select the driver and install it. Defently your print server will work.
If this answer is helpful ,pls rate it.
Feb 26, 2010 | Office Equipment & Supplies
I am trying to download PCAnywhere 12.0 to windows 7 and it tells me they are not compatible
That is correct Symantec list supported operating systems and Windows 7 is not compatible..
System RequirementsWindows 2000 Professional/Server/Advanced Server
Windows XP Home/Professional (32-bit and 64-bit)
Windows 2003 Server Standard/Enterprise (32-bit and 64-bit)
Windows Vista Ultimate/Business/Enterprise/Home Premium/Home Basic (32-bit and 64-bit)
Windows 2008 Server
Internet Explorer 6.0 or later
Regards
Nov 10, 2009 | Symantec pcAnywhere 12.0 Host & Remote...
Cannot detect other printer in remote desktop connection
Hello my friend, regarding on your problem kindly check your system particularly your windows 2008 server OS. Kind reinstall the printer drivers then then shared it. Then after you share the printers kindly check the ip address of your windows server 2008 OS then go to the workstation Computer then click start button found in your task bar manager then click run. Then kindly type the "\\IP of your windows server 2008" where your printer drivers installed then enter. As soon as you can log in the Windows server 2008 menu environment then if you can find or see the printer icon then click the printers icon then right click then click connect. Let the system automatically installed the printer driver to your workstation computer. then as soon as your system finished installed the printer drivers then try to run and print if you can now print using network LAN.
Hope this solution able to solve your problem. If you need more assistance kindly rely to this post.
Thank you.
geo_jonas
Jul 17, 2009 | Office Equipment & Supplies
Cant configre printer sharing via web on win server 2003
Yes is possible. Use Routing and Remote Access facility from Windows 2003 server to create a VPN Server. Create a VPN connection to Windows server, and thus you get an IP address from windows 2003 server and you can use printer.
Jul 07, 2009 | Microsoft Windows Server 2003 R2...
Windows Server 2003 - How can I install Services remotely ?
In my opinion, using Windows Password Reset Software or free Ophcrack is the best method to reset Windows server 2008 password.
Windows Password Reset Software is such software that you can reset forgotten Windows password for Windows 7/XP/Vista by burned CD/DVD/USB. It is professionally designed to reset lost password with less time-consuming and 100% recovery guaranteed. Also it can reset windows password for Windows Server 2008/2003/2000.
If you want to get more information about Ophcrack, please login Ophcrack Official Website.
May 29, 2008 | Microsoft Windows Server Standard 2003 for...
Unable to use printer over network with Server 2003 64Bit
Probably the best and easiest solution for your problem would be to buy an EDIMAX USB-Ethernet print server, or something equivalent. I have several of these running on the network at work. They're easy to setup and they work great.
Nov 11, 2007 | Konica Minolta magicolor 2430 DL Laser...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
