Question about Panasonic CW-1006FU Air Conditioner
It still doesn't working eaven with this instructions. The timer lighting still shining and the light power on, turn off after 10 seconds. Can you help me?
    Problem Solver:
  • 12 Answers
Reset the remote control,the reset button will be avaliable either on front or rear side of the handset,after resetting switch off the ac for a while,and on after
Posted on Nov 09, 2010
Entrance light on Lift Master garage door opener won't stay on when door is opened ?
Light Feature
Activate the Light Feature
  1. Close the garage door.
  2. Start with the garage door opener lights "ON".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn off and come on 10 seconds later.)
Deactivate the Light Feature
  2. Start with the garage door opener lights "OFF".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn on and go off 10 seconds later.)
Light Timer
Press the Light button to turn the opener light on or off. It will not control the opener lights when the door is in motion. If you turn it on and then activate the opener, the light will remain on for 4-1/2 minutes. Press again to turn it off sooner. The 4-1/2 minute interval can be changed to 1-1/2, 2-1/2, or 3-1/2 minutes as follows:
  1. Press and hold the Lock button until the light blinks (about 10 seconds).
  2. A single blink indicates that the timer is reset to 1-1/2 minutes.
  3. Repeat the procedure and the light will blink twice, resetting the timer to 2-1/2 minutes.
  4. Repeat again for a 3-1/2 minute interval, etc., up to a maximum of four blinks and 4-1/2 minutes.
Oct 20, 2017 | Building Materials
Toshiba 50HP95 timer/Rex light blinking green. Tv wont turn back on.
place to begin if you are able is examine the power board for puffed up caps and or voltages coming into the board and out of it.
Aug 27, 2012 | Toshiba 50HP95 50 in. Plasma Television
Westek SLC6CFL programming instructions
Copy following link for Westek outdoor socket timer instructions:
http://waterheatertimer.org/pdf/Westek-SLC6CFL-timer-instructions.pdf
Jun 27, 2012 | Ace Hardware AMERICAN TACK 3236858...
I have a problem with my nova simonelli aurora v. i can't reprogram the coffe size, eaven i use the instruction that request the continous cup in group 1 to be pressed for 5 sec (i press it eaven long
First thing I would do is try to program from another keypad (I am assuming you have a 2 or 3 group machine), it is possible that there is a problem with that keypad or flowmeter. If you cannot get into program mode using another keypad.
Dec 15, 2011 | Coffee Makers & Espresso Machines
I have a intermatic ej351 in my garage to turn the outside coach lights on and off. I made the mistake of putting some 10 year bulbs in the coach lights and now the red light on the timer just flashes...
I answer questions for free.
I specialize in timers and electrical devices
Below is the manual for the EJ351
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
The red light is a good indicator of the EJ351 timer.
The manuals says that you can clear all programming by moving control lever to OFF-CLEAR position for 20 seconds.
After programs are cleared, the red light will turn off.
Then move control lever to ON position, and then red indicator light will start flashing.
So the problem may be that the timer programs were accidentally cleared.
Use the instruction manual to re-program your timer.
Add a comment if you need more assistance, and I will help.
Nov 02, 2010 | Intermatic Timer E1020, Single pole/single...
I have a GE in-wall digital timer that I want to use to replace a light switch The light swithc has 2 wires, the timer has 3 which does not make sense. What do I do
Now you need to know a few things before you trying this, #1 Where the Circuit breaker for the lighting you are working on is located. #2 which wire is your power/hot wire going in to your switch. #3 which wire is going directly to the light. #4 what a neutral/return wire is. #5 some general electronic terms.
If you do not understand or if you cannot understand the above paragraph Please seek the help of a qualified/licensed election.
Well the reason the wall timer has 4 wires, is that it IS NOT just a Switch. It is in fact an election device. It requires Power (your Black Wire), a Return (your White wire), and a Ground (your Green wire). It also has a Output (your Red wire), this output wire controls your light (turns it on or off).
IF you’re still with me?
#1 turn OFF the Circuit breaker for the lighting you are working
#2 Take a part the light switch box for the light you are working on (only disassemble as far as necessary)
#3 Take your Ground wire and hook it up to the ground within the same location.
#4 Take your Return wire and hook-it-up to the nearest return wire within the same location.
#5 Take the black wire on the wall timer and hook-it-up to the Hot/Power wire.
#6 Take your Output wire and hook-it-up to the wire going directly to the light.
#7 Inspect your work to make sure there are no shorts, no unconnected/terminated wires in your light switch box.
#8 Before placing everything back tougher turn ON the Circuit breaker for the lighting you are working then run a test.
#9 OFF the Circuit breaker, then inspect your work to make sure there are no shorts, no unconnected/terminated wires in your light switch box.
#10 If everything is working then place everything back tougher. Then turn ON the Circuit breaker.
#11 If you did not have your Circuit breaker pop/turn off the lighting you were working, your dun.
Dec 18, 2009 | Intermatic Inc. ST01C Digital In-Wall...
Timer is set properly, but, the daytime lights never switch off
The timer doesn't know what time it is until you set current time.
The yellow outlets are controlled for 12 hours, and you can determine when those hours occur when setting current time.
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
If you want timer to control one lamp with both day and night schedules, you have to adjust current time setting so lamp schedule falls within a 12 hour period. If that schedule doesn't fit, then buy a second timer.
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 07, 2009 | Coralife Zilla Aqualight Power Center
H500 will not pair/find with LG Shine
Turn the LG Shine off, wait 10 seconds and try again. Power cycling the phone really does help sometimes. Let us know if this doesn't work.
Feb 15, 2009 | Motorola Mobility H500 Headset
Toshiba 52HM95 lights blinking
Mine was having the same problem. Just heard back from the shop and they said it's the light engine. They want $750 to fix!!!
Sep 10, 2008 | Toshiba 52HM95 52" HDTV Projection...
Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Oct 13, 2007 | Toshiba TLP S30 Multimedia Projector
Panasonic CW-1006FU Air Conditioner Logo
301 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
