Question about Asko D1716 Built-in Dishwasher
Sparks from the Dishwasher door
Spark comes from a dishwasher door and then burning smell. Is the dishwasher safe to use. How can this be fixed.
Thank you.
SS
  • Ryanmabob May 11, 2010
    I had this as well.. Although it just tripped the power.. Didn't sound good.
I did learn today that this might have been a problem in one of the control plannel board and they might have to change all boards to make sure problem does not exist. It is costly. Might get a new dishwasher in the same price.
How did your problem got resolved. Did you change th eparts. I was told that it won't be safe to use the dishwasher untill it is fixed completely.
Posted on Jun 17, 2008
Why is the dishwasher smelling like electric burning and smoke coming out of the door vent?
Hi friend, thank you for your post!
I understand that your Frigidaire dishwasher is giving off an electric burning smell and you are seeing smoke coming out of the door vent. It could possibly be an issue with your control panel or door vent, both have electrical components inside of them. Since it could be either one of these underlying issues I would recommend having a technician come out to your home and diagnose and repair the dishwasher. Hope this helps. -Matt
Jul 27, 2014 | Frigidaire Dishwashers
Sparks are coming from the base of the dishwasher door
You have a pinched wire your front controls are wired through the base of the door so take the door face off my removing the screws on the inner face if the door or call a appliance repair service I'm sure it's a easy fix if you have some basic tinkering skills
Mar 12, 2014 | Dishwashers
Bosch dishwasher smells burning rubber
Certainly could be a pinched wire in the door panel. I would remove the panel and see if anything is pinched or being interfered with like the rinse dispenser solenoid.
Dave
Jul 04, 2017 | Bosch Dishwashers
My dishwasher by Frigidaire Gallery Professional Series Model gpd8998jc0 has all lights flashing and could not be started. I smelled burning from dishwasher. Could it be motor burning?
it could be the motor depending on where it's coming. You can remove the lower panel, there are only two screws that hold it on. Look under their and inspect the motor.
Another part that could cause this issue is the mother board. The board is located behind the control panel. Remove the screws around the door frame to loosen and remove the control panel.
On most of these you also have to remove the plastic shielding that cover the control board. To do so remove the three or four screws that mount the board down.
Often these control boards will burn and create a smell like this.
Let me know.
Mar 26, 2011 | Frigidaire Professional Series 24 in....
A burning smell and steamy smoke come out when we open the door.
Normally, the last part of any cycle involves using the heater element inside, and at the bottom of, the dishwasher to give dishes a final hot rinse. Possibly some small plastic-type material has become melted and stuck to the element - which will remain hot even after all water is discharged. Hence the smell.
Nov 17, 2009 | Whirlpool 24 in. GU980SCG Built-in...
Frigidaire Gallery dishwasher smoke coming out of door. smells like wires burning.
You need to replace the blower assembly, common prob after a few years of use.
Part number: 154226802 "Blower-Crossflow", suggested list at this time is around 30.00 us dollars.
To replace: TURN OFF BRAKER TO DISHWASHER
Open door, remove inside screws form panel and carefully remove panel up from door, blower is next to timer on control panel.
Nov 12, 2009 | Frigidaire 24 in. FDB636GF Built-in...
My Maytag MDB9150AWS is no longer working due to what I believe is a electrical fire in the front control panel as there was smoke coming out of the top of the front panel. There were no flames but the...
My dishwasher (same make and model) had a similar problem except I did see some sparks coming out from th front on the side of it (on Thanksgiving Day no less - a lot of manual diswahing followed). What the problem ultimatly was is what I believe to be a factory defect. On the front door if you remove the inside panel to expose the wiring, I found where the door closes, the ruber coating on the bottom metal edge was worn away (from just years of opening and closing the door. There is a bunch of wires that run from the control panel to the power source and pump. Once the metal was exposed it comes in contact with these wires when the door is opened and closed and it was just a matter of time before they got shorted out. Fortunatly for me this happened while I was standing right there and was able to turn it off or this may have resulted in a fire. Also because of the quick shut off, none of the electronics or motors seemed to be affected. After respliceing the wires that were exposed, the dishwasher is working as normal. I plan to go back to Maytag to see if there is any complaints regarding this same issue.
Nov 03, 2009 | Dishwashers
Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Mar 11, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Dishwasher
Yes, have it checked out.  You have a wiring issue inside the door panel that is smoking and needs to be addressed.
Mar 24, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Asko D1716 Built-in Dishwasher Logo
578 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
