Question about Singer 2662
I have singer 2662 sewing machine. I am facing the problem of threading the sewing machine. Kindly explain to me as to how to do the threading in singer 2662 Looking forward to hearing from you. Regards Paul
  • 340 Answers
Do you have a manual?
You can get a free manual download from the Singer site.
http://www.singerco.com/accessories/manuals.html
Just type in 2662 and click on search.
On the next page choose the free download option.
There are also some helpful videos on Youtube, like this one:
http://www.youtube.com/watch?v=-DexrUyBQpA&p=99BDF7AE917374BF&playnext=1&index=17
Hope this helps!
Posted on Nov 08, 2010
Singer 2662 diagram for parts
Contact singer by email with a photo
Feb 17, 2014 | Singer 2662
Singer 2662 bobbin case keeps popping out.
Check our bobbin for burrs and damage. If the thread catches a rough edge it can pop the bobbin out. Try a different bobbin with new thread... see if that helps. If it does your current bobbin is likely trash.
Hope that helps.
Jul 14, 2012 | Singer 2662
How to thread the bobbin
Are you trying to thread the bobbin for winding or for sewing?
For sewing, make sure the needle is fully up and then release the bobbin cover plate. Insert the bobbin so that the bobbin rotates counter-clockwise. Pull the thread through the slot at the center-front of the bobbin case. Hold down the bobbin with a finger then bring the thread to the left and through the slot on that side. You should here a clicking sound when you pull on the thread. Leave 6" of thread free and replace the cover plate. Refer to the manual (page 12) for pictures.
Many Singer sewing machine manuals are available for sale or download here: http://www.singerco.com/accessories/instruction-manuals . The direct link to the manual for the 2662 is here: http://www.singerco.com/uploads/download/429_2662_efs.pdf . See page 11 and 12.
If the bobbin thread isn't feeding, clean the hook and surrounding area. Then with the presser foot down, retry. If you aren't hearing the clicking sound when the thread is pulled, you may need the bobbin tension adjusted. There is a small set screw for the adjustment but it's really easy to damage the threads. If you still have a problem, the bobbin case or shuttle race may need to be replaced (See http://parts.singerco.com/CPpartCharts/2_2999/2662.pdf for the parts breakdown).
I hope this helps.
Oct 28, 2011 | Singer 2662
How do I thread/load the bobbin????
singer.com has free operation manuals
in the search box put the model number 2662
Nov 27, 2010 | Singer 2662
The needle thread will not pick up the bobbin thread. the bobbin mechanism turns but it doesnt catch the thread.
Most of the time, it is because of the needle. Try a new needle and make sure that the flat side is facing the rear. Hope this helps you,
Oct 27, 2010 | Singer 2662
Needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Dec 12, 2009 | Singer Sewing Machines
Skipping stiches
1) It’s possible the machine is threaded incorrectly. Remove the thread completely and rethread the machine. Be sure to use good quality thread--don't buy the cheapest you can find. A good thread will help your machine perform better and your projects last longer.
2) Poor stitch quality can be caused by the needle. Make sure you're using a new needle that's right for the job. Many times machines are taken in for repairs and all they need is a new needle. If you can't remember the last time you changed the needle--it's past time. Needles should be changed at least every eight hours of sewing.
3) When inserting a new needle, make sure the flat side of the needle faces away from the bobbin area. For example, if your machine has a frontloading bobbin, the flat side of the needle faces the back of the machine. If your machine has a side-loading bobbin, the flat side faces the right side of the machine. Some older sergers require special needles that don't have a flat side. Refer to your owner's manual to properly install a serger needle.
4) Thread that shreds or breaks can be blamed on the needle. Use a good thread and make sure the needle eye is large enough for the thread type. Also use the right type of needle for the fabric;
5) The machine tension adjustments put stress on the thread so it doesn't simply flow through the machine. When the upper and lower tensions are balanced, the stitch forms correctly. Tension is easy to adjust--stitch on fabric samples with a different thread colour for the upper and lower threads. Observe the stitch, adjusting the tension until the stitch is formed correctly. As a general rule, adjust the upper tension first. If the stitch still isn't right, adjust the bobbin tension.
Feb 26, 2008 | Singer 2662
Singer 2662 Logo
313 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
