Question about Microwave Ovens
I have a Frigidaire over the stove microwave. The handle has come loose, the fan comes on and will not turn off, when the door is closed I can not always get it to come on I have to push on the handle. Also, one time recently it came on by itsself. Sometimes the light will not go off.
    Brigadier General:
  • 8,909 Answers
Check, and replace as necessary, the door interlock and switches. These are safety items as is the door handle.
Hope that helps.
Posted on Nov 08, 2010
Frigidaire microwave not working
Is the door closing properly? Do you hear it "click" when it closes. A lot of times the problem is the door switch. It is located inside the microwave. They are made of plastic and they break. If the switch is broken, the magnetron(microwaves) will not start.
Mar 27, 2014 | Microwave Ovens
Frigidaire microwave fmv156dcc
You likely have a failed bottom door switch, or that switch's mount is loose, misaligned, or broken.
The service manual will help you with disassembly, etc. It is here.
My help file on door switches is here.
Jan 07, 2014 | Microwave Ovens
Loose microwave handle
The handle screws are installed from inside the door, so it would be necessary to disassemble the door to tighten them. You have to decide whether the time and labor involved are worth it.
May 19, 2013 | Microwave Ovens
When door is shut some type of internal fan kicks on...
Hello Derrick Baker - Typically no fan should come on without starting the microwave. There is one exception! For an example, if the microwave becomes too hot from something that is cooking on the stove below the microwave, the fan will come on and will cycle off once the bottom of the microwaves cools back down. If the fan is turning on when the door is closed, more than likely, a door switch as failed. At this point, I recommend connecting with a certified technician to move forward accurately to assist with the repairs.
Mar 09, 2013 | Frigidaire FMV157GM Microwave Oven
Hot microwave door handle
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
Jan 08, 2013 | Whirlpool Microwave Ovens
Frigidaire microwave not heating over the range
Hello
Try to cook something simple such as microwave popcorn. If the unit does not light up or turn on, check the outlet with another appliance to make sure the outlet is functioning correctly.
Check the fuses or circuit breakers in you house. If the outlet does not work after testing it with another appliance, try to plug the microwave in a different outlet.
Check the hinges and door hooks to make sure the door is closing properly. Look to see whether a small piece of food is clinging to the door, preventing it from closing all the way. Check the release mechanism and the rotating plate to make sure they can move freely as well.
Plug in the microwave and start it a the bag of microwave popcorn inside. If the lights go on but it is not producing heat, listen and try to hear whether the unit sounds the way it usually does. If it does not, there might be problems with the circuit board. This will need to be repaired by a certified Frigidaire professional.
Check the display that shows the time and power. If the display is flickering but it does not alter the operation of the microwave, it is not a problem. If, however, the lights flicker and your food is not heating, there may be a problem in the microwave cabinet.
Listen for buzzing sounds. If there is a buzzing sound and no heat is being produced, you may have to get a new magnetron, power diode, or high-voltage capacitor. These can be purchased from a Frigidaire retailer.
Look at the handle on the door. The most common complaint about all models of the Frigidaire microwave, according to Consumeraffairs.com, was cracked or broken door handles. Frigidaire will replace faulty handles while the oven is under warranty. In many cases, they will replace the handle even after the warranty expires for a "reasonable" amount of time.
Oct 04, 2011 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Fridigaire over the stove microwave. the handle is broken. We can order a new handle but don't know how to install it. Can you help? thanks, Linda C. e mail ...
You must take the door out by removing a screw then lifting the door off the hinge pin then the door must be laid on it's front and, completely
disassembled to replace the door handle.
Aug 13, 2010 | Frigidaire Microwave Ovens
All the lights and buttons on the front of my Frigidaire PLMBZ209GC work but the turn table does not turn and the fan does not run and it does not heat. It counts down and the cook light beside the timer...
Hello :
That problem could happen because of a bad door switch .
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
That could happen because of slamming the door and not closing it gently .
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 31, 2010 | Frigidaire Built-In Microwave
Frigidaire Microwave Fan won't shut off plmv169dcd
Had the same issue, leave Microwave unplugged for 30 minutes and then plug back in. My fax stopped blowing and now fucntions 100% normal again HI/LO / OFF
Best of Luck!!! :)
Jan 17, 2010 | Frigidaire PLMV169DC Microwave Oven
Door handle coming loose, only 2 years old
I recommend that u glue it using some one minute epoxy, available at hardware stores, lowes, home depot
May 21, 2009 | Microwave Ovens
Microwave Ovens Logo
75 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
