Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
Maths ti 84 SILVER EDITION Can not graph even y=x. ERR:INDEFINED. dO YOU KNOW WHY? tHANKS
You might have a stat plot turned on. Use [2nd] [STAT PLOT] (over the Y= button), and either manually turn off the plot or hit [4] to turn them all off.
Posted on Sep 08, 2008
2nd
STST PLOTS
Posted on Jun 16, 2008
Ti-84 plus err: invalid dim
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
May 27, 2014 | Texas Instruments TI-84 Plus Silver...
I get a ERR: DIM MISMATCH when I try to use graph an inequality using the inequalz app
Your TI-84 Plus displays the ERR:DIM MISMATCH error if you are trying to perform an operation that references one or more lists or matrices whose dimensions do not match.
For example, multiplying L1*L2, where L1={1,2,3,4,5} and L2={1,2} produces an ERR:DIM MISMATCH error because the number of elements in L1 and L2 do not match
Nov 29, 2012 | Texas Instruments TI-84 Plus Silver...
TI-84: trying to graph an equation and ERR: INVALID DIM shows up only PLOT 1 is highlighted Window XMax XMin Ymax and Ymin are correct Any ideas? Test tomorrow
Jan 05, 2011 | Texas Instruments TI-84 Plus Silver...
My TI-84 Plus Silver Edition Graphing Calculator continues to read "ERR: INVALID DIM" whenever I attempt to graph equations.
Dec 04, 2010 | Texas Instruments TI-83 Plus Calculator
When I graph, it shows "ERR: INVALID DIM 1:QUIT"
Oct 28, 2010 | Texas Instruments TI-84 Plus Silver...
When trying to graph anything, ERR: INVALID DIM appears..
The easiest and quickest way to start graphing is to reset the RAM. Press [2nd][MEM][7:Reset][1:All Ram][2:Reset], then [CLEAR] to clear the RAM Cleared Message and go to the main screen.
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-84 Plus Silver...
When i press most buttons it gives me the message ERR:MEMORY i cant access memory so i cant reset ram or delete . also i can not connect to my cpu it says TI-84 plus Silver Edition detected, but couldn't...
From the TI knowledge base and FAQ
How do I correct ERR: MEMORY on a TI-83 family or TI-84 Plus family graphing calculator?
An ERR: MEMORY is given when there is not enough memory to perform the instruction or function. To increase available memory by deleting the contents of any variable (real or complex number, list, matrix, Y= variable, program, Apps, AppVars, picture, graph database, or string), follow these steps. • Press [2nd] [MEM] to display the MEMORY menu.
• Press 2: Mem Mgmt/Del.
• Select a variable or data that needs to be deleted and press [ENTER].
• Use the arrow keys to move the cursor next to the item, and then press [DEL]. The variable or data should now be deleted from the memory.
When deleting programs or Apps, a message asking for confirmation will appear. Select 2:Yes to continue. To leave any variable screen without deleting anything, press [2nd] [MODE].
Notes:
With the exemption of programs and Apps, no warning will be given to verify the deletion.Some system variables, such as the last-answer variable Ans and the statistical variable RegEQ, cannot be deleted.
Hope it helps.
Oct 06, 2009 | Texas Instruments TI-84 Plus Silver...
Ti-84 plus silver edition will not graph
try going into the memory men (2ND - +), and selecting option 2.  Delete some stuff you know you don't need.  If the problem persists, 2ND - +, this time option 7.  Reset the defaults.  You won't lose anything, it will just reset the settings that may be causing this issue.
Jan 25, 2009 | Texas Instruments TI-84 Plus Silver...
"Err: Data Type" - Not Allowing Me to Graph
First, turn it on. Once the calculator is on, press the "2ND" key (I believe it is a blue key in the ti-84 plus silver edition). Now press the plus key (+). A little above that key, you should see the word "mem." When you see the screen titled MEMORY, move the cursor all the way down to the option that says "Reset." From here, you can choose to reset either the RAM memory, or the factory settings. The factory settings are the "Defaults" option. I hope this helps.
Jul 25, 2008 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
252 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
