Question about Saeco D-XXDX 8-Cup Coffee Maker
I cannot reset the time on my Saeco coffee maker!! It keeps going back to the old time~~ the time buttons are on the bottom of the coffee base
    New Friend:
Simply hold down the 'H' button until the machine beeps. Then proceed to set the time using hour and minute buttons. Top left button is for auto brew feature only.
Posted on Jan 26, 2014
  • Meg unter
    Meg unter Jan 26, 2014
    Simply hold down the 'H' button until the machine beeps, then proceed to set the time using hour and minute buttons. The button on the top left is for the auto brew function only.
  • 81 Answers
SOURCE: Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Posted on Feb 03, 2010
  • 1089 Answers
SOURCE: how do i reset my saeco sclass incanto coffee machine
Hi
If you are talking about the descale light you must let the machine quit on its own. The lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle until all the red lights go away and you only have a green blinking light. Stopping it when it is out of water will only let it continue on with the descale cycle. The pump must quit on its own.
Posted on Oct 26, 2009
mirran
  • 515 Answers
SOURCE: Saeco Magic leaks water between water tank and machine.
You have to replace the gasket in the machine where the water tank goes in to the machine.
Posted on Jul 10, 2008
  • 81 Answers
SOURCE: I Have descaled my Saeco Odea Go but still it doesnt brew coffee
That is serious, that means the grinder is jammed or not working. To check the components of the machine follow these instructions.
Press and hold the steam button and turn on the machine, when you see the lights going around in anticlockwise direction, release the button. Turn the coffee dial to the left and press the steam button, the grinder should turn. Dial on the right and pressing coffee ****. water pump runs. Press steam ****. brew group go up, dial 1/4 to left B/Group down.
If grinder not turning the motor is bad. Hope it will help to find out.
Posted on Mar 28, 2010
espressonist
  • 1711 Answers
SOURCE: how do I clean my Saeco Vienna SuperAutomatica
In order to proceed with decaling of the espresso machine you need to have the solution appropriate for decaling an espresso machine.
Different brands of espresso machines, like Krups, Saeco, Gaggia e.t.a. have their own brands of decaling solutions. You should know that all of these are similar products so you can use them in all different bands if you don't have the one of you specific brand without any problem. So if you have Krups machine and you can only find Saeco decaling solution you can use it with the same results.
One thing you should have in mind Never use any Vinegar as a decaling solution since this will destroy some parts of the machines not instantly but in long term since vinegar is corrosive to this parts.
So the first thing is to remove any water fitters or small softeners that are included in you water tank. Fill the water tank with water up to maximum, dissolve your solution in the water you do need only two to three spoonfuls of solution.
Switch on the machine and wait to warm up. When the machine is ready you can turn the water knob and start getting some water in a pot. Leave it for a couple of minutes and then again the same. Do these until you draw off all the water with dissolve solution. After that leave the machine for more than 20 minutes. Remove then the remaining water with solution from the water tank, rinse it and fill it with fresh water. Now draw again continuously hot water from the machine in order to rinse it completely.
The last portion of hot water taste it to be sure that is pure clean and if not refill the water tank again and perform another rinsing.
Now the machine is ready to be used again.
Try to do decaling every 20 to 30 days.
If you plan to leave the machine unused for along time perform a decaling in order to avoid the possibilities of having the machine stuck when you will try using it again after a long time.
A machine which is used frequently every day is more secure to work fine even without any decaling but machines which are used rarely is more possible to have problems of stacking out in water outlet or coffee outlet.
Posted on Jul 01, 2010
Saeco royal professional machine started giving half cup less coffee then normall
Do you know how to reset the amount of the cup amount. I have a different saeco model but this mite help. Press the button for a coffee and keep it pressed in this is how you reset the level on mine when you release the button it resets the level.
Nov 09, 2013 | Saeco Coffee Makers & Espresso Machines
My Saeco Primea Touch Plus every time I turn it on says to add detergent at the milk conteiner. After I give the comand it tryes to wash the milk conteiner and when this is finished says to turn of the...
From what the User Manual indicates, the prompt to clean the milk circuit is based on the number of days since the last time this was done. The counter which keeps track of this is probably only reset at the completion of the wash cycle. You might be missing a step.
The User Manual is available here, see page 28. There are 16 steps plus the "perform another rinse cycle" (page 27):
https://www.seattlecoffeegear.com/assets/user-manuals/saeco/saeco-primea-touch-plus-user-manual.pdf
Jan 14, 2018 | Saeco Primea Cappuccino Touch Plus Coffee...
Machine just stopped working. dead
Hi
If the machine is less than 4 years old there are reset buttons on the outside edge of the boiler. There are 2 wires going to 2 thermostats. In between the wires on the thermostats are reset buttons. 1 on each thermostat. They are hard to get to but they might restore you machine. if not it could be your PCB board.
If its older than 4 years there is a reset button on the back of the boiler with just 1 thermostat. Reset button between the wires again.
Jan 02, 2011 | Saeco Vienna SuperAutomatica Coffee...
The squigley light at the bottom of the info cluster is flashing, ive totally cleaned the machine, and it will brew coffee but its still flashing. What does this mean??
you can reset that warning light by pushing the "steam' button for about 10 seconds, or until the 'squiggly' light (the indicator that it's time to descale the machine) goes out.
Oct 18, 2010 | Saeco Odea Go
I have descaled my Saeco Odea and the coffee beans light and the descaling light keep on flashing from one to the other
Hi, Try holding down the steam button for 10 seconds. It should reset the descale warning lamp.
Hope it helps.
Andrew
Dec 06, 2009 | Saeco Odea Go
Saeco vienna saying brewunit blocked !
Hi There is a test mode for the Digital and we can see if you have a bad power board. Turn the machine off in back. Push and hold the small coffee button and the menu button (top left) at the same time and while you are holding the buttons turn the machine on. Release the buttons and you should have numbers in the display. If you can push the bottom left button and the machine makes a sound like the motor is moving, turn it off and then back on. If you don't get the message now you should really clean and lube your brew unit.
Jun 05, 2009 | Saeco Vienna SuperAutomatica Coffee...
My Saeco Giro keeps flashing red, what's wrong?
Hold the water button in for about 15 seconds.
Mar 30, 2009 | Saeco Odea Giro Plus Coffee Maker
Selftest sign
Try to make a cup of water(tea), press the button for water.
On the old Royal Cappuccino that are the button on the right down corner and the new machine had it on the upper right corner.
Hope this will help you.
/Mirran
Aug 16, 2008 | Saeco Royal Cappuccino Espresso Machine
Saeco D-XXDX 8-Cup Coffee Maker Logo
59 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
