42MF230A/37 My picture and sounds goes off then goes back on in 5-10 seconds. Is there a resent button. We unplugged it from everything and replugged it back in but still does it especially after it has been on for a while.
    Brigadier General:
  • 8,909 Answers
Within the power supply, you may find dry joints. The go high resistance when they warm up due to movement caused by temperature change or viabration etc.
Check all components that are on heat sinks for bad solder joints and electrolytic capacitors that are swollen.
Hope this helps.
Posted on Nov 08, 2010
Samsung LN37B530 37" LCD TV
Sounds like your Tcon board is giving issues.
Nov 16, 2017 | Samsung Televison & Video
My 42mf230a/37 plasma tv has sound but no picture
Check the power supply, Y and Z sustain boards caps, fuses, burnt parts first.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Dec 23, 2010 | Philips 42MF230A/37 42 in. Plasma HDTV
42' plasma magnavox model # 42MF230A has no picture and no sound
I had the same problem with an Insignia 42" 1080p. Turn off the tv power and disconnect all cables (i started with power cable, then HD cables then HDMI). Wait 30 seconds with nothing plugged in, then I plugged everything back in (in reverse order) and it works fine.
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
This sounds like your Z sustain board has gone bad. I just repaired an HP plasma today with the same complaint. All the modules inside were LG. The Z board is the one on the Right side of the set with the cover off or facing the back. You might have 1 or 2 ceramic fuses on it, check them, if one is bad Replace the board.
Apr 28, 2009 | Philips 42MF230A/37 42 in. Plasma HDTV
Red Lights on the Power button blink and picture goes dark
60PL9200D/37 When I unplug it for a while and turn it back on, the picture starts to come on, but it turns dark. And the red lights on the left and right side of the power button blink. Sound but no picture.
Feb 02, 2009 | Philips 60PP9202 60" Rear Projection...
Magnavox 42MF230A/37 Plasma TV should i fix it? ?
you will need that part to repair yours. i recomend using the heatsinks from yours. u need to check the FETs on the board that drives that one before u power it up, or u could damage the new part.
Dec 05, 2008 | Philips Magnavox 42MF521D/37 Television
37PF7320A/37 comes on the turns off after 30 minutes
Check the firmware and if it is not BX23U-1.5.0.0_03531 go to www.usasupport.com and down load the current software on to the set wil a USB stick. If the problem is still there replace the small signal baord.
Jul 25, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
42 inch magnavox #42mf230a/37
One of the driver IC'S has gone bad. Need to replace just the driver IC or the board that the IC is on and that should solve your problem. If that doesn't do it, then the BAD NEWS IS THAT THE PANEL IS BAD. Replacement is you only option then. Good luck. GURU JAY.
Mar 16, 2008 | Televison & Video
I have a plasma tv need help
Sounds like panel is bad or driver ic is bad on the board directly below the black line. Good luck on the repair. Any questions, we can do a chat and go from there. GURU JAY
Mar 14, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
