Question about Krups FME4 Coffee Maker
Coffee maker will not start. It is program correctly and acts like it wants to start, but will not.
  • 36 Answers
If your display works then there is probably a problem with your heating element. Without the heating element working properly it will not draw in any water to brew.
Posted on Nov 08, 2010
Keurig
Check the needle that pierces the bottom K-Cup, those can clog which can cause it to run slow.
You might also try de-scaling it: http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/FD69E91A51CA41BEBF4CCAA138325BBF.ashx
If this doesn't help, it could be an issue with the B60 itself. If it's under warranty still, call Keurig, they'll likely send you a new one. The B60's seem to have control board issues. Every once in a while mine acts up, and I have to pull the plug, reset it, and fiddle with it til it starts working correctly.
Jul 10, 2012 | Keurig Special Edition B60 Coffee Maker
The machine pours too much coffee for an expresso and even for a normal cup. We have been using it for 3 years and this just started a few weeks ago. I reset the machine to factory settings and it still...
You don't mention if you've programmed the quantity since it started behaving strangely, so....
instead of pressing the 'coffee cup ' icon button once, hold it down all the way through the brewing procedure (it will bip) until the correct amount of coffee has been pumped into your cup, then release the button. This quantity has now been programmed into the memory and should produce the same amount of coffee every time, on a sigle press.
Mar 04, 2011 | Saeco Incanto Sirius Fully Automatic...
How do I program the stay or go coffee maker to turn on at a certain time, I worked the past few evenings, but the green light will not come on, I did have trouble the other times also
To Program Automatic Brew
1. Make sure clock is set for correct
time of day.
2. Press PROG button and digits will
flash.
3. Press H and M buttons until desired
brewing time is reached.
4. Press PROG button to confirm setting.
Digits will stop flashing and
return to set time of day.
5. Once brewing time has been set,
follow this procedure:
• Follow steps in "How to Make
Coffee."
• Push AUTO-ON-OFF button once
and "Auto" will be shown in display
indicating the brew cycle will begin
at the set time.
NOTE: If AUTO-ON-OFF is pushed
twice, the light will glow and brewing
will begin immediately. Press AUTOON-
OFF once to turn off and once
more to set programming mode.
Jan 13, 2011 | Hamilton Beach Stay or Go 45234 Coffee...
I forgot how to program it . I don't know how to set the clock
Make sure that the machine is plugged in but neither the coffee or espresso side are turned on. Hold the small button on the left under the screen (S1) for at least a 10 count. When you've held it long enough, the time will start flashing. Press S1 again until you have the correct hour. Press S2 to set, and the minutes will start flashing. Press S1 again until the minutes are correct and Press S2 to finalize.
Hope this helps. I almost tore out my hair trying to figure this out.
Jan 08, 2011 | Krups XP2070 10 cup Coffee Maker/15 bar...
My Incanto Sirius coffee maker is acting strange. It automatically keeps brewing (1) large coffee. The only way to stop this is to shut off the machine. I am getting a LCD read out of Program quantity....
Program quantity is trying to program that amount.
When it starts to brew and gets to the quantity you want for that cup size push the brew button again and see if it stops.
Nov 21, 2009 | Saeco Incanto Sirius Fully Automatic...
Just bought a new cuisinart coffee maker and no book came with it. I need to know how to program the coffee maker.
  1. Setting the time
  • When the machine is plugged in, the screen will display 12:00.
  • Press and hold the "HR" and "MIN" button until the numbers flash.
  • Then press the "HR and "MIN" button to scroll through the numbers. When the numbers stop flashing, the time has been set.
CAUTION! When you pass the number 12, the letters "PM" appear to indicate the time between 12 noon and 12 midnight. When these letters do not appear, the time corresponds to the morning hours, from midnight to noon. Always make sure the hour is set according to the correct period so that programming is correct.
  • 2 Programming the start time
  • Press and hold the "PROG" button. The numbers and the indicator light flash.
  • Press "HR" and "MIN" in the same way to set the hour to the desired start time for the cycle. When the numbers stop flashing, the programmed time is set.
CAUTION! Programming the start time is not possible when the coffee maker is running.
Hope this will help you.
Best regards
/Mirran
Aug 28, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Bubbles in measuring column
I had the same problem. How Frustrating. What I discovered is if you pour the water in really slow, the bubble do not appear.
This was one of 3 problems I had this this maker. The other two were.
  • Could never get the clock set correctly. The buttons are very cheaply made. Would push the time advance button and the numbers would not change. Started acting whacky, flipping between the hours, minutes and program functions.
  • For 3 mornings straight the removal of pot lid gave me troubles. Was like trying to crack a safe. Needless to say, after the forth morning attempt, it lost the battle and broke.
I have been a Krups fan for many many years, dating back to the early 80s. After this even, I have become VERY disappointed with the quality of their consumer product line.
Jan 05, 2008 | Krups FMF5-14 Stainless Steel 10-Cup...
Krups FME4 Coffee Maker Logo
408 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
