Question about Acer TravelMate 8103WLMi PC Notebook
Screen Inverter and bulb
I need a part number for these items for the Travelmate 8103WLMi PC
Thank you! Is there someplace I can get the parts other than ACER?
Sean
Posted on Jun 16, 2008
  • 106 Answers
Take your LCD apart. That's the only way you could do it otherwise, contact acer and provide them with your information and hopefully they'll have some type of record of the original shipped parts.
My laptop screen will not say on for a normal time period. I change the inverter board but the screen still turn off. Why?
you are getting display when the backlight bulb of the monitor is working,when the back light bulb is going off you are not getting the display... in some computer the backlight bulb of the screen is the part of lcd screen assembly..your computer model has got one CCFL BULB WITH DISPLAY ASSEMBLY..The item number of your comput's lcd is - NXK702-0293,resolution-WXGA+(1440*900),type-Matte,backlight connector-2 pin,video signal connector- 30pin
Sep 16, 2010 | Toshiba Satellite P35-S6111 Notebook
ACER TRAVEL MATE 2480 WILL POWER ON BUT SCREEN REMAINS BLANK.
look close to the screen and see if there is a faint picture. if there is then read below for the issues and solutions that can cause this problem.
Issue 1: Lid button sticking
this is a common issue with this model that the lid button sticks closed. fiddle with it to see if it opens and the light comes on.
issue 2: Inverter for the monitor is bad
this is not to uncommon an issue when this problems shows itself. Laptops monitors light up with a fluorescent bulb. This is powered by an inverter. These can go bad and if they do the light will not turn on. you need to take this to a service station. i don't recommend trying to replace without knowledge of this. They are high powered and you can hurt yourself or damage the screen
issue 3: fluorescent bulb went bad
this is usually the least common but could have happened. usually happens when peopel spray their screen with cleaner and it drips down inside the bottom. This can be fixed by a service center but coudl get costly. best bet is buy a new screen.
Feb 11, 2010 | Acer TravelMate 2480 Notebook
Laptop screen brightness mild flicker will not stay bright
inverter circuit connector need to reconnect
or ccfl bulb not working properly change your inverter circuit
Feb 01, 2010 | Acer TravelMate 2300 Notebook
When i press the power button it makes noise and the screen does not show anything
NOise coming from?? Screen do not show anything is Possible problem of LCD, LCD BULB, INVERTER, CPU, MEMORY, OR GRAPHIC CARD. Issue. Try external for make sure if you get picture Your GRAPHIC CARD, MEMORY, CPU is fine.
If sound is coming from FAN system, That is need to be clean(or Change), Or HDD makes sound that is Coming to DUE.
JMC
Aug 15, 2009 | Acer TravelMate 2355 Notebook
Graphics Card loose.
Here are the instructions for an older model, but the models may be similar:
http://global.acer.com/support/pdf/TM6293.pdf
Before you start pulling stuff apart, I would try to figure out if it is a driver/OS issue as advised earlier
Feb 01, 2009 | Acer TravelMate 8103WLMi Notebook...
Acer Travelmate 201T most times no display
If the backlight is coming on its not the inverter, check the ribbon cable for the screen itself, If its been opened and closed alot maybe be time to replace the screen. Check connections first, go from there.
Dec 11, 2008 | Acer TravelMate 201T (91.44G01.4J4) PC...
Acer travelmate 2410
This doesn't necessarily rule out the inverter. I've had inverters with intermittent problems that had the same effect, so having the inverter tested is the only way to rule it out. Other possibilities are a bad connection, a corroded/dirty pin or socket in a connector, a bad ribbon/cable, and a failing backlight. If it is a failing backlight, the entire screen will need replaced, as the screen is considered a sealed unit and the backlight isn't available and not considered a replaceable item. Also, it's rare, but it could have a faulty motherboard component or video card. I'm leaning towards a faulty backlight, but keep in mind the inverter and cable possibility. Start by checking and cleaning all connections.
Sep 17, 2008 | Acer TravelMate 2300 Notebook
I have two docking stations for my Travelmate 8103WLMi both docking statins have lost there USB port connectivity. Is there anything that can be done so that the USB ports work again?
Try updating the drivers for the docking stations. Even in commonly used items such as docking stations which can be used without drivers, if you go to the manufacturer's web site and download drivers or management software, you will find it works better.
Otherwise, try somone else's laptop with those docking stations to make sure it's not your latop causing the problem. If it doesn't work for them either, the docking station is broken and there is really nothing you can do about that short of paying more than it's worth for someone to change out the USB component of the docking station.
Jul 09, 2008 | Acer Computers & Internet
Black screen
Sounds like the inverter that poweres the backlight is dead. Search on eBay for the FL inverter for your model. Should be easy to replace.
Jul 04, 2008 | Acer TravelMate 2500 Notebook
Acer TravelMate 8103WLMi PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
