Question about Sony KP-46WT510 46" Rear Projection HDTV
MY SONY PROJECTION TV DOESN'T WORK. IT BLINKS 10 TIME (RED BLINKS) AND PAUSES FOR short time and then it blinks again ten times and so on
    Sergeant:
  • 252 Answers
I prefeer you go to a tech with this problem beacause of highvoltage. Your problem is siple though the red light flash is an error code that means your bulb is blown in your set. This is the bulb that illuminates your screen. Bulb cn cost up to a $100.00 for one so please shop around if you are a do it yourselfer. Once again I stress please take it to a tech if you are not electronic savvy
Posted on Nov 08, 2010
SONY KP-61HS20 DOESN'T COME ON JUST BLINK 6 TIMES PAUSE AND 6 TIMES AGAIN
Sis blinks of standby light denotes No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. If you wish to get more details about blinking codes to Sony PTV, check this link.
Mar 03, 2013 | Sony KP-57HW40 57" Rear Projection...
IT TURN OFF ITSELF RIGHT AFTER TURN ON GREEN
If the Lamp red light is blinking then replace lamp, replacement procedure is written in user manual and its easy.
If standby/ power red light is blinking then please count its blinking and post here. It is an error code that has info about problem in specific section of tv.
You will see 3 seconds long pause between blinks so count pause to pause.
May 11, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
SONY KP-61V90 tv will not power on, red light in front,
Its 2 times blink error code that shows +B volt supply (+135 volts) is shorted, most probably horizontal output transistor is shorted, replace it.
If you are good in soldering parts in circuit board then take out horizontal transistor, check it, found shorted then replace it with same number.
Horizontal output Transistor Q502 number is 2SD2578 and available in Part Store for $10
Let me know for further query, if any.
Thanks.
Nov 18, 2009 | Sony Televison & Video
Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Sep 14, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Led 10 blinks then turns off
According to sony,
Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Thanks.
Jun 16, 2009 | Sony KP-FX532M91 TV
Sony kp51 ws500 red screen, 8 blinks
The 8 blinks is pointing to a bad flyback transformer and may be common with this set. (We have one too.)
High voltage error -- blinks 8 times • T8005 is faulty. (D board)
Jan 01, 2009 | Sony KP-57HW40 57" Rear Projection...
Sony kt-46wt520
Oct 18, 2008 | Televison & Video
Sony Kp-fw46m31
count the flashes again carefully, as that model should only blink a maximum of 9 times, unless your getting two seperate codes. Try counting and trying to notice if it pauses a second before blinking again. then let me know what you discover.
Apr 06, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
97 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
