Question about Proform XP XP 690T Treadmill
The belt is loose on treadmill how do I tighten it
  • 20 Answers
Is the belt drifting side to side? If so, adjust it with the Allen bolts on both sides of the base. If the belt is just slipping, has your treadmill had a lot of use? If so, you may need a new belt. You can order one at Treadmill Parts
Posted on Nov 09, 2010
I have a gold gym vx 5000, the motor does not keep a consistent speed and jerks a lot, is there any way to fix this?
You have to check the treadmill belt. is it properly tightened or not. If the belt is loose the this type of problem can occur. check the video and tighten the belt and the check is it jerking of not .
Almost all the treadmill have the same belt tension procedure.
Treadmill Running Belt Tensioning
www.electro-medical.blogspot.com
Sep 21, 2015 | Exercise & Fitness
Belt is loose
there are adjustment bolts on the back end of the treadmill. they are on either side. start with belt running about 3mph. tighten the side where the belt is closest. about 1/4 turn. give 15-20 seconds to see adjustment . when it is centered, tighten both bolts evenly until belt is tight.
Apr 19, 2014 | Nordic Track NordicTrack A2550 PRO...
Belts are slipping,
hi,
your treadmill's belt is loose. You have to tight the belt from the both side.
all the treadmills follow the same procedure for tightening the waking belt. Watch the following video for the same.
ok
Mar 16, 2011 | Precor 956i Experience Series Treadmill...
I have a Reebok treadmill. The belt stops while the motor continues while walking on it. What could be causing this to happen?
the drive belt is too loose. you need to tighten the belt that drives the front rolller, which drives the walking belt. depending on the type of treadmill there shoudl be a way you can do this by loosening the motor and adjusting that to tighten the belt. it could also be that the belt needs to be replaced and also could be the walking belt. you should try to tighten the walking belt first. that is at the end of the treadmill where you walk on it. there are two holes one on each side of the treadmill where teh belt goes back under the treadmill. there are allen key bolts that you need to tighten clockwise one turn then try the treadmill. if it doesnt tighten then turn another full turn. if not tight enough then it might be the drive belt. if you tighten the walking belt all the way then try to tighten the drive belt.
Jan 28, 2011 | Reebok Exercise & Fitness
Have a 4.9 treadmill and cant get it to adjust if i loosen bolts in back it slips if i tighten bolts on motor it quits pulling when i put weight on it can you help
Ok I really need more info but let's take a stab at it. The bolts in the back of the rear roller adjust the belt right and left. It also tightens and loosens. Ok there is also a drive belt from the motor that needs to be tight. Generally you should be able to twist the drive belt about 45 degrees. If it's more than that it probably needs to be tightened. If this is loose it will affect the walking belt the same as the walking belt being loose. So when your walking belt is slipping, make sure you tightened the right belt. Tightening the wrong belt can lead to other problems. Tightening the walk belt with the rear roller- turn both bolts clockwise equally to tighten. Remember the walking belt will travel to side with least tension. So to center belt, adj left or right side to fine tune. If belts are adjusted properly and machine stops when you walk on it, you have other issues. Could be the deck ( the board under the belt) and belt or the motor.
Nov 17, 2009 | Proform 6.5q Treadmill Walking Belt
The belt is slipping and making a squealing sound
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
May 14, 2009 | Proform Crosswalk 500 Treadmill
My treadmil is slipping and I can not find an online manual.
Apr 04, 2009 | Exercise & Fitness
Treadmill seems to slip while running,
Feb 22, 2009 | Proform XP Weight Loss 620 Treadmill
Belt slipping on treadmill
Jan 06, 2009 | Exercise & Fitness
Proform XP XP 690T Treadmill Logo
332 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
