Question about Bosch KGU66920 Side by Side Refrigerator
I have a double door fridge, at the bottom is the deep freeze and top the fridge, the fridge is not working at all no matter what temp i set it on, but the deepfreeze is working, what could be the problem If i have to pay for this info then please dont worry.
  • 320 Answers
If the deep freeze is working it only means that your problem is on the thermo switch on the the fridge section. Try to check the temperature setting panel if its possible open it and look for the thermo sensors that switches the temperature in the fridge.
Posted on Nov 08, 2010
Hi I have Westinghouse freestyle 450 my problem is that no matter how low I have temp the begs freeze in crisper other wise been very happy I have had this fridge for 20years
fridge settings work in reverse to freezer settings
1 for a fridge is almost freezing where it should be around 4
cold air sits at the bottom of the fridge so the setting will be colder in the crisper draw that at the top shelf
May 26, 2017 | Westinghouse Refrigerators
The temperature in refrigerator is coler than setting on the display why?
Before I begin is the model number=> GI5FVAXVL correct? If not I will need the correct model number to proceed. Thanks, John Tripp Appliance 911
Jan 29, 2014 | Whirlpool GI5FVAXVL (249 cu ft) Bottom...
Fridge is freezing everything
Check the top of the inside of the fridge. There is usually a flap door mechanism that sometimes falls off or sticks. This regulates the temp in the fridge.
Jan 29, 2014 | Amana ABB2524DE Bottom Freezer...
Refrigerator food freezing even when on lowest setting
There is one of three reasons why your fridge section is freezing food. You didnt mention whether you had a side by side or freezer on top or bottom model, so the following checks may not apply to your unit.
One reason food might be freezing is your cold control has failed, and will not turn the unit off when the physical temps are correct. When this occurrs food normally freezes throughout fridge section, top, bottom, middle, front and back.
BOTH controls, though you may only have one, should be at the middle setting. Adjust your controls, place a plastic cup of water at the top, the middle, and bottom shelf of your fridge. Check all three AFTER 24 hours. if all three are ice, you COULD have a bad cold control.
It is possible you might also have a door damper that is stuck open. A door damper is a swinging or sliding door that opens / closes either when temp control settings are adjusted, or on some fridges, when either door is opened, the damper closes. Please note, door dampers are USUALLY only present on side by side refrigerators. They can have a motor, or thermostat open the door automatically,which can break, and others will simply have a lever of some sort, which usually wont.
If after 24 hours, only the middle and bottom cups are ice, your evaporator fan motor, in the freezer, is likely not operating. Not knowing the BRAND you own, it could be the motor itself, a thermostat located on the evaporator, your defrost heater, or a main computer control board that controls the fan motor.
Sorry I cant be as specific as id like, but i had to cover all possible bases
Oct 16, 2011 | GE HSM25GFTSA Side by Side Refrigerator
Lower part of fridge freezes no matter what the set ting.
IM guessing your icemaker is not working either. these symptoms are caused by your evaporator fan motor not blowing air throughout cabinet. However, your problem could be the motor itself not operating correctly, wr60x10185, or the main control board is not operating correctly, wr55x10942. the problem with the board can and often will be caused due to a faulty motor, so both have to be replaced. It would be much too long for me to explain how to test everything you need to test to see source of problem, but your symptoms are definitely caused by that fan motor not running.
www.FixMyFridge.net
Mar 08, 2010 | GE GSS25JFM Side by Side Refrigerator
My Jenn-Air JCD2389DE* constantly freezes produce
Hi; Need more info. Does the refridg. cycle on and off during the day. When You say no matter where You set the tstat concerns Me to think that the unit might be
runing all the time. Remember the coldest place in the refridgerator is the bottom. Excluding the freezer compartment. Also are the door gaskets in good condition this will also cause the unit to run more
...alpharome416
Feb 23, 2010 | Refrigerators
Older model fridge freezes on the refrig. side
check the damper door and see if its iced up this is between the refrige and freezer compartments and lets cold into refrige from freezer,if it ices up in the open condition the refrige control cant change the temp,defrost the door and then see if the control moves the door,if so also check the door seals to make sure they are sealing good so as not to let warm air in that can condense and freeze things like the damper door
Jan 16, 2010 | Refrigerators
Bottom of fridge section freezing, rest fine.
maybe fridge fan not working when door is closed could also be iced up air ducts between fridge and freezer
Oct 09, 2009 | Fisher Refrigerators
Everything freezes in the refrigerator bottom drawers - no matter what we set the temp in the freezer or refrigerator, everythign freezes.
Make sure the vents from the freezer to the fridge are not blocked by ice etc. One is at the bottom and one at the top. The on at the top is adjusted open or closed when you adjust the fridge temp. Make sure it's working. Also make sure the fan in the freezer is circulating the air from the freezer through the vent at the top.
Aug 25, 2009 | Whirlpool ED2GHEXN Side by Side...
Bosch KGU66920 Side by Side Refrigerator Logo
112 people viewed this question
Top Bosch Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
