Question about Samsung Refrigerators
I have Samsung Fridge/Freezer (RSH1DBBP1), and have lost the manual for it. Could you please tell me where can I get it from ?
    Producer:
    Uploaded 30 video answers.
  • 117 Answers
Hello this guy may be able to help you ....
if not contact samsung direct ">
Posted on Nov 11, 2010
Error code 24 e. Freezer defrost error. Now what do I do? Help Please!
You have a problem in the de-frost system. Could be a timer, very common, heat element, very common. Look on line or your owner manual and see what that code is telling you. The average person can not make this repair. Hope it is under warranty.
Aug 27, 2016 | Samsung RFG29PHDRS 28.4 cu. ft. French...
Hi. Just had a Samsung RS7567BHCBC American style fridge freezer installed today. Does it take a few days ti build up a stock of ice cubes? Had a few out tonight but then stopped. Thanks
you should have a manual that tells you this information, yes, it takes 24 hours for your fridge to kick in and have ice built up and for the freezer and fridge to be up to the settings you have it at
Aug 22, 2016 | Samsung Refrigerators
Hi my freezer is not keeping food frozen it starts to thaw after a few days i have cleaned the back of the fridge it is not up against a wall the door seal seems okay the compressor works as i can hear it...
the defrost heater or thermostat on the evaporator coil is bad,you can tell if the inside rear wall of the freezer is covered with frost,you need to remove this panel after defrosting with a hair dryer and find which part is bad
May 19, 2011 | Refrigerators
I have lost my instuctions for this Bosch
Problem solved went to Currys and looked at the instruction book in there!!!!!!!
Jan 09, 2010 | Bosch KGU32124 Bottom Freezer Refrigerator
Freezer not freezing, moves from 8 degrees to 34 degrees. Fridge keeps constant 40. Someone said it was frost temp sensor? Cant even get into interior back pannel to replace now I have the part.
There are 2 thermistors for frost and 2 for temperature....Fridge and freezer compartment have one each.
Access to the thermistor sensors are from the inside of the fridge and freezer. You have to remove the shelves, trays and the inside panels to get at them.
The manual will show you how.
There are diagnostics you can run that will tell you which one is in trouble.
There are sensitive voltages that may be required to measure. So from a tech point of view you may need someone with electronics expertise to do the measurements.
The procedures and various measurements are too lengthy to tell you but I will give you the link to the service manual PDF and you or someone can do the diagnostics...The Manual is 87 pages long. Can you imagine a fridge needing that much documentation.
That said. I have the same fridge and have fought 3 different problems...not fun....
here's the link...
http://www.ajmadison.com/ajmadison/itemdocs/DA68-01778A-EN.pdf
Make sure you unplug the fridge before you go taking things apart...
Good luck
Maytag owns Samsung
Dec 29, 2009 | Samsung RB215LASH
Weve lost the instruction manual for our Hotpoint Fridge-Freezer
Sorry, no secret. The fan wasnt working so we called an engineer who bypassed a sensor. Now it works perfectly again.
Mar 22, 2009 | Bosch Freezers
FLASHING E8 (WARNING) ON MY FRIDGE FREEZER
A model number and serial number would help in any diagnosis.
May 04, 2008 | Freezers
Samsung Fridge Freezer
Possible bad defrost timer.
Mar 08, 2008 | Refrigerators
Side by side fridge freezer
Based on your weird display issues I'd lean toward the control board problem. At least that can be "one" of a couple problems...
Feb 01, 2007 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
159 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
