How long does it take to charge archos vision 1 for the first time ?
2 Hours.
Posted on Nov 08, 2010
My archos vision 1 is not recognised by computer
Hi, archos vision 1 player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see archos vision 1 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the archos vision 1 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: archos vision 1 Players can connect to your computer in MSC or MTP mode. Exceptions are archos vision 1 Connect and archos vision 1 Express which only use MTP mode. MTP mode is the recommended and default method for archos vision 1 Players when used with Windows OS.
The archos vision 1 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
How do i transfer dvd to my archos 43 vision.
Copying your videos from your computer to the ARCHOS 43 vision does not require specific software, just drag and drop the video files you want onto your ARCHOS 43 vision.
Best regards .
Jan 20, 2011 | Computers & Internet
My archos 3 vision screen has frozen how do i fix this problem
press the reset button in the back with a pin or small pen, hold for 10 s or so.
May 20, 2010 | Archos 3 Vision Digital Media Player
I tried putting videos with all different file formats onto my Archos 3 vision -- mp4, wmv, avi... But each time I input it, and try to play it, a 'File Format Error' Sign pops up and it won't play... I...
Well, one thing u need to know is that Archos 3 vision cant support all file formats and codecs. U need to transcode video files to compatible format with Archos 3 vision. I recommend u Pavtube Video Converter(http://www.pavtube.com/video_converter/) which can transcode between any video files, and it still offers u foramt presets for Archos.
May 07, 2010 | Archos 3 Vision Digital Media Player
Archos vision 3 with cracked acreen can it be fixed?
If it is still under warranty, you can fix it for free.
Apr 26, 2010 | Archos 3 Vision Digital Media Player
How do i transfer from itunes to my archos 3 vision
Archos 3 will not play DRM protected songs. You may need to find a converter. I don't know if this is possible.
Mar 24, 2010 | Archos 3 Vision Digital Media Player
HOW DO I PUT A DVD MOVIE ON A ARCHOS 3 VISION
You need to convert the DVD into AVI format. There are multiple programs out there that do this. Be prepared for long conversion times unless you have a powerful computer.
Mar 17, 2010 | Archos 3 Vision Digital Media Player
Hi my archos 3 vision is frozen, how do I get it going again
Hi
My Archos 1 Vision. Wont play a particular music file. It has played it amazingly fine since i bought it 3 months ago. It was connected to my computer charging for a while, then i turned my system off so it was off for a while.
Wanted to listen to a few songs before bed,turned it on,selected Music,Scrolled down to the file i wanted,Went to select a song.........FROZEN! I can turn it off but the same thing happens everytime i go to select something from this file
Please help i need music on my travels ;-)
Feb 19, 2010 | Archos 2 Vision MP3 Player
222 people viewed this question
 Grubhead
Grubhead
