Question about Norelco T 800 Beard Trimmer
How to remove battery from norelco t 800 can not get to come apart after removing 1 screw on grip
Disassembling the Norelco T800 is quite easy -- once you know what to do!
* Remove the single small Philips screw that you can see near the power connector
* Twist (hard) the cutter depth ring past 9 and it will come loose.
* Now remove both the ring and the guide piece that it moves up and down
* Now pry off the cutter head (black piece of plastic)
* Now remove the metal clip that you find under the head -- press down on the two free ends and pry the other end of the clip loose.
* Now release two plastic tabs that we under the rotating ring.
* Now I just pried the two parts apart by inserting a small screwdriver and twisting. I'm not sure if there are any more tabs that can be released at this point.
* Now you can remove the circuit board (which is held in my a couple of plastic tabs).
Now you can replace the *single* NICD 600maH battery (AA size). The longest bit of this step was heating up the soldering iron!
Reassembly is the reverse.
Philip
Posted on Jul 21, 2012
  • 91 Answers
SOURCE: replacing batteries in a 6705x norelco shaver
Go to this link
you can find it.
Posted on Jan 07, 2009
VtToolMan
  • 704 Answers
SOURCE: how to replace batteriers in norelco quadra electric shaver
The rechargeable batteries are solder into the circuit board of the electric shaver. You'll have to use a soldering iron to de-solder the terminals/tabs from the PCB (printed circuit board) in order to get them out.
Then you'll need new replacement rechargeable batteries to solder back into the shaver.
You can get teh correct replacement batteries from Electric Shaver Service in Lincoln, Nebraska (if you're in the US or Canada). They even do service and repair work in about a week, if you want to have them fix your shaver for you.
Here's a link to the battery page with your shaver model's rechargeable batteries for about $15.00 (plus s&h)
http://www.electricshaverstore.com/get_item_13810334_norelco-13810334-electric-shaver-battery-set.htm
Hope you find this Very Helpful and best regards!
Posted on Aug 22, 2009
brector3
  • 1602 Answers
SOURCE: I need to know how to remove the battery from a norelco mod #
To get to the batteries, you will need to flip up the lotion packet cover on the back and remove the lotion packet if there is one. You will see four screws on the back. Remove these to take off the back of the shaver case. Once this back case is removed, you will be able to see the battery pack. The circuit board can be lifted up slightly for better access to the batteries.
To replace the batteries, you will need to do a little soldering. For easy replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather that removing them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can them solder the tabs from the new batteries to the old existing tabs.
Batteries for this shaver can be found at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
Posted on Feb 22, 2010
brector3
  • 1602 Answers
SOURCE: Norelco 6735X shaver:batteries replacing. I
If you have removed the 5 screws the back cover will come off. There are seals that make it fit pretty snug. You will need to gently pry the back cover off.
You will find batteries for this model at shaveroutlet.com. See link below
Posted on Apr 13, 2010
brector3
  • 1602 Answers
SOURCE: How do I remove the
Remove the 4 screws on the back to take off the back cover. You will have to extend the trimmer to access 2 of the screws. You can then unsolder the batteries from the circuit board.
If you are replacing the batteries, for easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
You will find replacement batteries for model at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
Posted on Jan 12, 2011
How do you change the batteries in a norelco 7735x razor?
Remove the translucent back cover to reveal 4 screws. Remove those screws and a 5th screw located in the 'cap' on the bottom of the shaver. This will allow you to remove the lid of the battery compartment.
Use the information at the shaveroutlet.com video below fro battery installation
https://www.youtube.com/watch?v=2oAnLpvdYqQ
Batteries for your model can also be found at shaveroutlet.com at the link below
Oct 19, 2014 | Norelco 7735X Electric Shaver
How open norelco reflexplus 6 model 6863xl to replace the battery
Hi rafael110807,
This Norelco Razor contains rechargeable Nickel-Cadmium batteries, which must be
disposed of properly.
Batteries should be removed only when the razor is to be discarded. Batteries should be recycled or disposed of properly. To recycle the batteries please call 800-8BATTERY (1-800-822-8837) for a location in your area. If you have additional questions or need further assistance, Consumer Care can be reached at 1-800-243-3050. You can also visit this product's Support Site @ http://ow.ly/6j5Ep for chat, FAQ's, manuals, and more. Hope this helps. If so, let me know by rating this solution.
Sep 01, 2011 | Norelco ReflexPlus 6863 XL Electric Shaver
How do i replace batteries for model 5615x norelco shaver
Flip up the lotion cover on the back to access the screws. Remove screws on the back and then gently pry off the battery compartment cover. You can then access the batteries.
For tips on removing the batteries and replacing them, see video at shaveroutlet.com. Click on the link below and scroll down for video
Jul 19, 2011 | Norelco Advantage 5615 X Electric Shaver
Is the battery replaceable on the MB-300?
Unfortunately not. The rechargeable nickel-cadmium is hard-wired and not replaceable. The battery is hazardous waste and must be removed for proper disposal. Instructions for removing the battery from the user manual:
1. Make sure your groomer is unplugged from any outlets so you don't risk an electric shock.
2. Remove side panels/grips
3. Remove the 4 housing screws
4. Pull or gently pry the clipper halves apart, exposing the batteries.
5. Remove batteries from the unit.
6. Twist batteries to break wires. Wires may also be cut.
The user manual has a toll-free phone number to call for disposal instructions in your area: 1-800-822-8837
Feb 24, 2011 | Remington MB-300 Beard Trimmer
How I can replace my norelco rechardgeble battery
You will find the correct battery for model 4601 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-pack-fits-norelco-3605-others-p-277.html
Remove the back cover by removing the 4 screws on the back. Two screws are easily visable. Push the trimmer up to reveal the other two screws. Then lift off the back cover to reveal the battery. You will need to then unsolder the battery from the circuit board. Replace with the new battery by soldering to the circuitboard just like the original. Reassemble
Sep 27, 2010 | Norelco 4601 Electric Shaver
How do you get into and change the battery in the razor model 3805 xl I have the screws out but does not want to come apart!
Remove the head, then remove the screws. There is usually another screw under the pop-up trimmer so be sure to remove that one two. When ALL the screws are removed you can gently pry the case apart. Once you've done that you will need to desolder the battery connections from the circuit board and then solder in new ones. You'll need batteries with solder tabs which can be ordered from various online merchants including Radio Shack.
Aug 09, 2010 | Norelco 3805 XL Electric Shaver
How to remove rechargeable battery for norelco 7864
hi minglim, welocme to the forum!
    Replacing a Norelco Shaver Battery Things You'll Need:Torx screwdriver set Rechargeable Ni-Cd AA battery 1)Slide up the sideburns trimmer on the shaver .2)Try the various torx head screwdriver sizes to find the fit for the two screws holding the top of the back shaver cover on. Unscrew the two screws that are under the sideburns trimmer that hold the back of the shaver on. On some Norelco shavers, the back will now slide off if you apply downward pressure on the shaver's back. Other Norelco shavers have one or two torx screws on the base of the back cover on the shaver; if so, unscrew them also. Place the screws in a safe place. 3)Take the back cover off the shaver. Some shavers may have a strap fastening the battery down. Unfasten the strap if there is one. Take out the battery. 4)Replace the old battery with a new rechargeable Ni-Cd AA battery. Re-fasten the battery holding strap if there was one. 5)Replace the back shaver cover and re-screw in all the torx screws,
May 20, 2010 | Norelco 7800XLCC Electric Shaver
Norelco 6735X shaver:batteries replacing. I removed the 5 screws but the back case remained not removable. How to get to the mounted batteries? Thanks, Guido
Apr 12, 2010 | Norelco Advantage 6735 X Electric Shaver
Norelco 5822 XL - need new battery, but can't determine how to take apart!
There are just two screws on the back. Remove the screws to take off the back cover. You can then access the batteries.
You will find replacement batteries at shaveroutlet.com. See link below
If you are not able to complete the repair yourself, shaveroutlet.com can do this also. See link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Mar 14, 2010 | Norelco Reflex 5822 XL Electric Shaver
How to replace battery in Norelco 6867xl
You will need to remove the two screws on the back to remove the back cover. Inside, you will first need to remove the two white plastic pieces that the screws you just removed screw into. The larger one snaps in and will have to be popped out from the bottom on each side. The other one has two screws that need to be removed. Once these are removed, you will be able to better access the batteries.
The batteries are soldered to the circuit board but instead of unsoldering them, I suggest carefully breaking the solder tabs off of the ends of the batteries. This leaves the old tabs still attached to the circuit board and you can them simply solder the new batteries to those old tabs. This prevents you from having to put a hot soldering iron directly to the circuit board.
You will find batteries for your model at shaveroutlet.com. See link below.
Feb 10, 2010 | Norelco Quadra 6867 XL Electric Shaver
Norelco T 800 Beard Trimmer Logo
202 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
