Question about Zodiac Baracuda G3 Automatic In Ground Pool Cleaner
My cleaner works for a few minutes, climbs a wall and rolls over onto it's head.
  • 640 Answers
If the problem always occurs when the pool cleaner starts to climb walls, there are a few things that you will want to check. First of all, if your pool has a vinyl liner, this pool cleaner has limited climbing ability. You need to check the flow of water through the cleaner with your flow gauge. It might be low. If it is, increase the water flow. Also, make sure that your hose weight positioning is correct. The cleaner should sit at a 45 degree angle at the bottom of the pool when resting when the weights are right.
Posted on Mar 31, 2011
G4 keeps heading for and climbing the sides of the pool, always making a long run along the side walls of the pool. The bottom is not being cleaned. Have adequate lenght of hose. Diaphram has no holes....
If these pool cleaners are staying on the edge on the pool, there are two things that you can do to correct the problem. First, reduce the flow through the cleaner to the low side of the ideal range. Second, add a hose weight about 3 feet from the cleaner's head. That should correct the issue.
Apr 15, 2011 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Cleaner comes to the sides and top of pool, and won't stay on the bottom.
Cleaner won't leave or rim of edge of pool. Use Pool Pulse to lower flow. Utilize return flow to move cleaner. Adjust hose weight.
POOL PULSE (metering flow)
The Pool Pulse is a flow meter that measures the volume of water flowing through your Zodiac cleaner. It must be used to properly set the flow and can be used as a diagnostic tool when the cleaner isn't running properly. This piece should have been provided with your original box, but if you have lost or discarded the pool pulse flow meter, then you will need to purchase another one either online, or at your local swimming pool retailer. For the following steps (using 2 people is recommended; one poolside and the other at the plumbing manifold.) Vacuum and skimmer valves are located at your plumbing manifold. • Remove the cleaner head. • Attach the Pool Pulse to the end of the hose and keep it under water. • Turn on the filtration system. • For pools with one skimmer, flow is automatically regulated by the Flowkeeper Valve. Insure the blue indicator of the Pool Pulse is in the ideal range (when viewed from the side). • For pools with two or more skimmers, leave the selected skimmer open and slowly close the other skimmer(s) until the blue indicator of the Pool Pulse moves into the ideal range (when viewed from the side). • For pools with a wall vacuum fitting, leave the wall vacuum fitting fully open and slowly close the skimmer valve until the blue indicator of the Pool Pulse moves into the ideal range (when viewed from the side). • Keeping the hose under water, remove the Pool Pulse. Submerge the cleaner head, and when the bubbles stop coming from the extension pipe, attach the hose end. Your installation is now complete.
REGULATING RETURNS Divert the pool return inlets downward - Your Zodiac Automatic Pool Cleaner must move randomly throughout the pool and water circulating at the surface will influence the hose and limit coverage. • To adjust the return inlet: loosen the lock ring and redirect the eyeball downward, then retighten the lock ring. If the eyeball is difficult to adjust, insert a screwdriver inside the eyeball and gently adjust downward. • If the return inlets cannot be pointed downward, then you MUST install Zodiac return line diverters. They are available online or through you local retailer.
Adjusting weight on cleaner: FOLLOW THE GUIDELINES BELOW FOR YOUR SPECIFIC CLEANER MODEL. (Model number is stated on the cover of the manual that came with your cleaner) MODEL# W83251 - Hose weight is not required for this model cleaner in most pools. As a troubleshooting technique to improve coverage or prevent the cleaner from climbing the walls excessively, snap (1) hose weight onto the first hose section, one meter from the cleaner head. MODEL# W03000 - Snap (1) hose weight onto the middle of the first hose section, 1/2 meter from the cleaner head. MODEL# W83215 & W83216 - Snap (2) hose weights onto the middle of the second hose section, 1 1/2 meters from the cleaner head.
If you are still experiencing issues with your cleaner, you have a full 1 year warranty on the cleaner and Zodiac is happy to help you with the ownership! They can be contacted at: 1-888-786-779
Sure hope this takes care of that issue for you, and I look forward to your feedback! Thanks for allowing us to help you out!
Brian Morris, The Ugly Pool Guy www.WeFixUglyPools.com
Dec 10, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
I put the eyeball diverter on my pool and the cleaner runs up to it and the hose hangs on it. I keep my hose laying out strait when not in use. It does seem to stay on the sides also.
If the eyeball diverter is not working, you might need to install a wall climb adjuster (Part #K12065). This will keep the automatic pool cleaner on the pool's floor and walls and away from pool obstructions. Make sure the narrow end of the wall climb adjuster points down to the drive tubes.
Aug 23, 2010 | Universal Kreepy Krauly In-Ground Pool...
It stops after 30 min. Lays on it's back then starts up again. Has trouble climbing the walls to the very top
There are several problems that could make these automatic pool cleaners fail to climb the walls. The cleaner could be too heavy. Empty and wash the filter bag and add floats if necessary. If there are excessive amounts of algae on the wall, you will need to brush the walls first. The algae can prevent the cleaner from climbing. Make sure that the temp is at least 65 degrees in the pool. Make sure that there is no water in the handle and that the bushes arent worn. If the cleaner is too light, add weights. Make sure there is nothing caught in the impeller.
Jun 25, 2010 | Smart Pool Inc Dolphin Diagnostic...
My dolphin begins to work, then stops. What could
There are several problems that could make these automatic pool cleaners fail to climb the walls. The cleaner could be too heavy. Empty and wash the filter bag and add floats if necessary. Make sure there is no water in the handle and that the brushes arent worn. If the cleaner is too light, add weights. If there are excessive amounts of algae on the wall, you will need to brush the walls first. The algae can prevent the cleaner from climbing. Make sure that the temp is at least 65 degrees in the pool. Make sure there is nothing caught in the impeller.
Jun 14, 2010 | Dolphin Maytronics Advantage
My polaris won't climb the walls and stays on his left two wheels.
Make sure that your hose length is long enough to cover the entire pool. This sounds like common sense, but it is often the problem. Make sure that your thrust jets are working properly. Turn the cleaner over while it is operating. You should see 3 distinct thrust jets. Check to see that they are all working. Remove the head float and shake it. If there is water in the head float, you will need to replace it. This is also a common problem with these pool cleaners.
May 27, 2010 | Polaris 380 In Ground Pool Cleaner
Our Dolphin Orbit poolcleaner ( one year old) works for only a few minutes, as soon as it starts to climb the wall it cuts out. If I turn it off and pull it to the pool bottom it will start again but the...
Have a dolphin orbit pool cleaner and the cord just winds itself in knots all the time and then takes us a long time to wind it back. This machine is new and our old one never did this what is happening
Nov 15, 2009 | Sport & Outdoor - Others
Tiger shark just doesnt clean very well
I the filter is not very clean the pump will not push hard enough to hold the tracks onto the walls. Try running without filter in a very clean pool for a few minutes to see if it solves the climb walls replace the filter and clean the unit
May 26, 2009 | Aqua Vac Tiger Shark
Aquabot Turbo T won't climb
1.`. Replace your old, water logged floats. They will dry out when the unit is out of the pool, and the unit will work fine until they water log again, which may takes as few as 10 minutes in the pool. 2. Stop using all those words *********** didn't teach you and probably didn't even know...This is a common problem. http://www.i-love-my-aquabot-automatic-pool-cleaner.com/ gives some really good insight, too! S. Christian dansker01@msn.com.
May 11, 2009 | Aquabot Turbo T
Zodiac Baracuda G3 Automatic In Ground Pool Cleaner Logo
276 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
