Question about Locks & Locksmithing
Need the code for a Kasp 110 lock combination lock. Its locked in the open position.
4 Suggested Answers
flbergeron68
  • 541 Answers
SOURCE: how to reset an open master lock
your answer is on this site
http://www.masterlock.com/faq/lostcombo.shtml
Posted on Jul 05, 2010
SOURCE: need instructions to reset kasp combination lock
I have a kask 119 series combination locke. Some clever person thought they would reset and didn't think to remember the code. What can I do to find out the code. Or reset it.
Posted on Aug 29, 2010
Obertelli
  • 3006 Answers
SOURCE: my daughter jammed a kasp
If it's jammed and assuming that you've already used non-destructive means to try and unjam it, the the quickest, safest and cheapest way to overcome the problem is to use bolt croppers to cut the lock off.
Posted on Sep 29, 2010
My Brinks 3 dial combination lock is locked in open position
Your lock's code is unique and no way that someone from a Q/A forum like fixya might guess it. Get the help of an experienced local locksmith.
Maybe, should it have 999 possible combinations, you could go through them one by one
May 21, 2015 | Locks & Locksmithing
How to reset combination
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
the door and conceal your combination
7. Close the shutter door
Sep 03, 2014 | Master Lock 5400d: Portable Select Access...
How do i set lock on axa ntc=95 combination lock
with the lock open (!) (with the right combination set, push the gray buttons backwards so the lock opens), then rotate the right triangular marker clockwise 90 degrees, then turn the numbers to set your new code, then place the right triangular marker back to it's normal position. (rotate back 90degrees counter-clockwise).
Took me a while to find out too...!
Nov 07, 2012 | Locks & Locksmithing
My daughter jammed a kasp 11030 brass combination lock because she forced it closed.it's used to lock our school allotment shed, so we need help as children can't access their tools.how can we solve this...
Sep 26, 2010 | Locks & Locksmithing
Need instructions to reset kasp combination lock
Aug 07, 2010 | Locks & Locksmithing
Problems to open a Samsonite TSA 007 lock on suitcase
Hi I have a problem to aopen my luggage I think my niece has change my security code accidentally , but now I cannot open my luggage can you please chelp me out?
Nov 08, 2009 | Samsonite Tripod
Set luggage lock
the lock is currently set to 000. To set your own combination and with the lock in the 000 position, open the case and on the inside of the lock mechanism you will see a red tab. slide this tab to the left and then move the digits on the front to your desired code. ie 123. then move the red tab back to lock in this new setting as your own personal combination. close the case and then move the digits away from our setting of 123 and this locks the case. only if the digitrs are 123 in this example will the lock now open.
Dec 24, 2008 | Locks & Locksmithing
I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
factory to 0-0-0-0
(see instructions above)
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
Locks & Locksmithing Logo
191 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
