When switched on, you can hear volume and change channel, but no picture. The bulb is lighting up in the rear. the fuses are ok. Just no picture whatsoever
    Sergeant:
  • 252 Answers
You have bad capacitors in the high voltage section of your TV. Please replace and this will Fixya.
Posted on Nov 08, 2010
Brake light switch not working
If you press the brake pedal and the rear lights don't work, It can be a number of things. Blown bulbs, Blown fuse or a broken circuit. The broken circuit could be a cable or connection failed, a broken switch or a bad earth. The fact that both lights don't work would indicate the problem is most likely to be a fuse or a switch. Just because you can hear the switch click, doesn't mean it is working. Replacement of a brake switch should only take a novice mechanic about 30 minutes.
Mar 24, 2013 | Cars & Trucks
My additional brake light is not working i have tested the brake unit and that works is there a seperate fuse for this or is it all on one fuse for all the brake lights
The third or High Mounted Brake Light runs straight off the brake light switch on the brake pedal arm. You say you tested the "brake unit"? I assume you mean the third brake light assembly, and if you get power there when someone steps on the brake pedal, then the bulbs are bad.
The power flow for the brake lights goes like this: Fuse ->Brake switch -> Turn signal switch -> Rear lights. The only difference is, if you have a 3rd brake light in your rear window, that gets its power directly from the brake switch. It does not go thru the signal switch first. So, if you are having a brake light problem, and your fuses are good, check the 3rd light in the rear window, if it lights up (assuming the bulbs are good, no one ever changes them), then the problem is most likely in the turn signal switch, hope this helps!
Aug 28, 2011 | 2002 Ford SVT Focus
Right rear turn signal and brake light not working, but running light does, changed bulbs still not working - fuse is ok, Front tuen flshes rapid like burnt out bulb? short somewhere, live in the dessert...
Do you have a test light? On the plug to the right rear light, check for power on the dark green wire with someone holding the brake. If it lights up replace the circuit board the bulbs are pushed into. The parts stores stock these. If you don't have a test light, try switching the rear lenses side to side and see if the problem switches sides.
May 16, 2010 | 1997 Chevrolet Tahoe
Rear lights not working
Chwct under your hood, you have switch on transmision box, unplug it and shortconnect it with a piece of wire, thew if the lights go on, you need to change that switch.
Apr 15, 2010 | 2001 Volkswagen Golf
NO REAR OR BRAKE LIGHTS BUT ALL BULBS AND FUSES SEEM OK.
check the Switch under the dash on the brake peddle . it could be stuck or broken get a a wire tie the lights together test for continuity at that switch. check your trailer light hook ups for shorts. If you have a braking power module for towing you may have to replace it or check and make sure it is getting juice.
Apr 07, 2010 | 1998 Dodge Ram 3500 2WD
The picture of whats being watch wont show up
Most likely the vertical output IC has gone bad. No light bulbs in this one. Have a shop check it out for you. Thanks for using fixya.
Mar 03, 2010 | Toshiba 32A33 32" TV
1965 ford mustang...rear turn signals, rear emerg flashers & brake lights not working.
Are the rear bulbs OK?
Is the ground good at the rear?are the sockets good?
Are there tail lights and a license plate light?then the ground is OK.
All the things that you say do not work go through the signal light switch....it may need replacing.
First make sure the bulbs and fuses are OK and power is getting to the signal light switch and to the brake light switch.
Nice car!
Aug 31, 2009 | 1965 Ford Mustang
No rear turn signals, front turn signals light but dont flash
bulbs might look good but it dont mean they are. I suggest changing the bulbs.
Jan 17, 2009 | 1999 Cadillac DeVille
2005 RCA HDTV
Ok. no U can hear the audio for the channels?... this set has no bulbs to replace. does it shut down. does the front green light flash. if u push menu on remote does anthing come up?
Dec 01, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
KP-53XBR45, Sound OK, but no picture
You may have a bad convergence... short will shutdown your HV circuitry leaving just audio?
It has no bulb to change?
Oct 29, 2007 | Sony KP-53XBR45 53" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
