Question about Garden
I have a 115mm DeWALT D28113-XE Angle Grinder. The power swith button came off (looks to be broken off the switch extention strip). I cannot re-attach it as the two prongs underneath the button, that attach to the ext. strip are now too short. Might need a replacement button. Any suggestions?
  • Garden Master
  • 3,772 Answers
Buy a new switch. Don't run without a switch.
Posted on Feb 06, 2018
3 Suggested Answers
SOURCE:
Mike258
  • 1498 Answers
SOURCE: Fault on a Kinzo 115mm Angle Grinder
Hi J,
Hopefully you just wore out the brushes. Replacement kits are available for a few bucks and the fix is pretty easy.
On the darker side, If it overheated enough that it burned the windings (insulation melts, shorts, badness), there isn't much you can do unless it's still under warranty.
You won't know until you get it apart. You'll know which it is at a glance.
Unplug it and dismantle the base of the grip where the cord is attached.
The brushes are small spring loaded graphite blocks that transfer electricity to what looks like a cylinder around the central drive shaft that has a lot of vertical copper strips on it. They are normally housed inside small copper tubes opposite each other.
If those tubes are empty but for the spring, it's brushes.
If the insides are full of ashy residue, it's not the brushes
Best regards and I hope it it's the brushes
Mike
Posted on May 27, 2010
Testimonial: "Excellent-many thanks."
barterjoe
  • 346 Answers
SOURCE: where can i buy brushers
You can lookup and purchase DEWALT parts here: http://www.dewalt.com/parts-and-service.aspx
Good luck Joe
Posted on Feb 15, 2011
Grinder makes a scraping sound
They all make a funny growling noise while they're running. It's just a rough fit in the gearing.
Jan 25, 2014 | Dewalt D28110R Heavy-Duty 4-1/2" 115mm...
I want to use flap disc's on my grinder with out the threaded portion attached. What do I have to do to install them on the grinder.
flap discs can be used on a grinder the same as grinding disc and cut off wheels . You may need a centre adaptor as some flap discs are larger in the centre hole
Aug 31, 2011 | Dewalt D28402 412" (115mm) Small Angle...
I have a D28110 grinder and it started making a loud noise (not the regular noise) and got very hot at the front where the gears are. I removed the gears cover and tried to get the shaft out of the casing...
You have to pull the brushes back there should be screw caps on the back (cord end) remove them and take out the brushes if the gears are ok and there is grease in ther then it will be the brushes or the bushing on the back
good luck
Oct 14, 2010 | Dewalt DEWD28110 Heavy Duty 4 12"...
Do you have a basic training course and knowledge assessment for 115mm and 230mm angle grinders
Hi, a good place is youtube, there are videos on most tools and some very good tips.
Oct 01, 2010 | Clarke Power Products 7 in 9 in Angle...
I have a Dewalt Angle Grinder (4 1/2'' D28402) Checked that I have the O rings and don't see anything missing....don't know why but blade won't tighten down (unless I put the tightening wheel, wheel side...
What do you mean wheel side out? It should look just like the picture, the nut side of the disc threads on first. Depending on what disc you want to put on you may need a spacer that goes on first and then a threaded washer on the outside.
Jul 08, 2010 | Dewalt D28402 412" (115mm) Small Angle...
Hi J,
Mike
May 27, 2010 | Dewalt DEWD28110 Heavy Duty 4 12"...
Dewalt dw474 grinder quit
you need new brushes. carbon is meant to be touching the armature not the contact from the spring. Its worn down
May 10, 2009 | Dewalt DW824 5" Electric Angle Grinder
Garden Logo
46 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
