Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
I have the WD62725 and the TV is making a loud noise coming from the speakers. It doesn't sound like a bad fan, but something the speakers may be picking up from something in the TV. When you shut the TV off, the noise stops.
    Sergeant:
  • 252 Answers
You have some leaky caps in the sound section of your TV or a bad audio output chip.
Posted on Nov 08, 2010
Samsung HLR5064W DLP TV load vibrating noise like a fan blade hitting something, lamp light is one, Tv will light up but discolored
Sounds like a bad color wheel----remove lamp---the wheel faces it--look for missing pieces or the wheel shattered---these are known for the wheel making a loud high pitched sound or even a grinding sound if the wheel shatters.
if wheel bad You Tube has video instructions for replacing it---seen several people able to do this themselves in about a hour. Google the model number to ("color wheel") to locate a replacement on the internet.10_24_2012_3_58_01_pm.jpg
Oct 24, 2012 | Samsung HLR5064W DLP Projection TV
Maytag Legacy series dryer making loud noise. Sounds like something flapping.
A common problem on these dryers is the blower wheel itself will wobble out and make noises. Pop the top with a putty knife then remove the front panel. Check the blower housing for looseness.or something in it. I worked on a monkey wards dryer with a bad blower wheel and made crappy movie on my phone:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 04, 2012 | Maytag Dryers
Our ac unit is making a loud noise and there is water coming into the house via the vents. we cleaned out the vent and took some of the water out of the middle pan and the outside pan, and it doesn't...
My recommendation would be to have some one knowledgeable in refridgeration come in and take a look. You make have more than one problem going on. However the water build up can be due to a plugged drain line. Try using a wet and dry vac to clean the drain line . the fan noise may be the fan motor bearings. If this is the case you can remove the fan and possibly have bearing installed but most likely will need to replace the fan motor
Jul 07, 2011 | General Air Tools & Compressors
Samsung 4663w rear projection tv loud buzzing
Hai,
Buzzing can be caused by a bad ballast, colorwheel, or cooling fan... Nothing else makes a noise, unless it's comming from you speaker.
Hope it Helped U!
Aug 04, 2009 | Samsung Televison & Video
Making a loud noise sounds like Fan
ok first i want you to pull your Refrigerator and look for a part of a loaf of bread or something else that has got inyour fan. hope this helps. if you don't find anything you may have a bad bearing on one of your fans. there are to fans one under the rear, and one inside the Refrigerator that you here when the door opens and closes pay close attn: to both!
good luck sawdust46
Aug 03, 2009 | GE Refrigerators
Funny noise when TV is on
if the tv is a "DLP" the "color wheel" is going bad, check the model # to get the right part
Nov 28, 2008 | RCA Scenium D40W20 40" Rear Projection...
Very loud fan or vibration noise
Listen from the back of the TV and locate the source of the noise. There may be fan with a bad bearing. The noise will lead you to it.
Nov 06, 2007 | Soyo Dymond DYLT037A Television
Loud Humming
It's possible a fan or a hard drive is going bad. When the bearings in those devices start to go out they a start making noises like that.
Jul 18, 2007 | Tivo Series2 TCD649180 DTV Receiver /...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
87 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
