Question about Bose Wave Radio
The remote won't turn on the system at all. i replaced the battery with 2 new batteries and no change
  • Bose Master
  • 17,130 Answers
If the problem is related for sure in the remote control then find some tips related to remote control problems. make sure there is no IR emission fromt he remote to confirm the fault of the remote.
Check this link below:
Remote control
Posted on Nov 08, 2010
Remote doesn't work
did you program the remote? or was it standard? if you did all of this it sounds like a new remote is in order,but I'd get the codes from the maker and instructions on reprogramming it,if that fails you need a new one
Apr 24, 2013 | Amphion Mediaworks T342 System
I have 2004 chev tahoe w/ a viper remote starter system,but no key fob. I replaced the car battery & now the cars computer won't let it start. How do I reset the computer?
The car's computer wont let it start?
Well, if you changed the battery and the viper alarm is the issue; locate the push button valet/programming switch. Turn the ignition on, press and release the switch. The alarm will disarm and you can start the vehicle.
To put the alarm in valet, turn the ignition on then off, within 10 seconds press and release the valet switch. The LED will illuminate solid to show that the system is in valet.
Aug 20, 2012 | 5900 SST 2-Way Security System / Remote...
WON'T CHANGE INPUTS
Reset your code according to the instructio manual.
2) change the batteries by new ones.
3) clean the contacts batteries with contacts cleaner
4) resolder the wires contacts batteries.
5) retight the springs contacts batteries with pliers if they have.
6) open the remote.control and clean the keypads switch, from oxide diryt, open contacts, or bad contacts with VOM.remember they must send signal infrared from SYScon Trans vs Sys receiver clean
7) Try.it
God bless you
Jul 30, 2012 | Logitech Harmony One Advanced Universal...
Remote with new batteries won't work
Even after replacing new battery cells only ON/OFF button responding and other buttons are not responding. Pl suggest how to solve it
Jul 15, 2012 | LG LSC121PMA Split System Air Conditioner
Remote hand control won't turn system on. Batteries are OK
1) Change by new batteries type alkaline
2) Clean the contacts batteries with special spray contacts cleaner
3) Retight the springs contacts batteries with plier very well for good contacts.
4) Resolder wires contacts batteries.
5) Reset the code again download for free from www. fitness.manualsonline.com or www. remotecodelist.com
Otherwise you must opent the remote and clean any contact from keypads very well, or go to the repair shop
God bless you
May 14, 2012 | Televison & Video
My remote control won't pick up any codes for our tv
1) clean contact batteries with special spray contact.
2) retight the spring with plier for better contact batteries
3) replace new batteries.
4) resolder the wires for contact batteries.
5) You open the remote and resolder any point contact solder for cool solder.
6) Otherwise you must go to repair shop or replace by new from radio shack, i recommend satellite PRO .
sincerely God bless you
May 09, 2012 | Televison & Video
Remote won;t work
Hi
if the battery is new, you need to replace the IR in the remote control this is the bad parts thats why you can not operate.
Thanks!
Jun 06, 2009 | Daewoo DVD Player
No Remote
The remote have to work with new batteries. You can check the board where the components are mounted and resoled any that look bad. In your case it could caused by a leaky diodes or a bad solder. All can be replaced at a local electronic or hardware store and they're easy to replace Possible batteries problems: 1 batteries are not making contact properly inside the remote. Test by cleaning connections of the batteries and the remote. 2 battery charger is bad and isn't actually charging the battery. Test by charging on another charger if possible. 3 batteries are bad and are not actually recharging. test by using other batteries if possible. 4 other, unknown, internal remote problem. buy a new one.
Dec 28, 2005 | RCA RS2044 Shelf System
Bose Wave Radio Logo
315 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
