Question about HP W19b LCD Monitor
The HP Audio box keeps appearing on the screen and turning down the volume(dont care about the volume) but the box will not disappear what do i do
5 Suggested Answers
Roonie Tunes
  • 136 Answers
SOURCE: my volume menu from monitor pops up, volume auto-decreases
Was something spilled on the volume key? Sounds like it is stuck... you can use a fine toothpick and plain water to "scrub" around the key, there may be some buildup that inhitbits the key from "unpressing".
Hope this helps!
-- RT
Posted on Sep 02, 2009
SOURCE: the volume menu on my hp w2207
dirty switch. I took my 2009m apart and cleaned the switches with alcohol on a qtip and the problem's gone. Not too hard to do. Leverage the case gently with a putty knife or something and it will pop open. Then pop around the edge to remove the back completely.
Posted on Feb 05, 2010
linswad
  • 258 Answers
SOURCE: the volume menu on my hp w2207 monitor keeps
Sounds like one of the buttons on the monitor is sticking physically. Try:
  • checking the buttons for dirt that might be holding it in
  • cleaning the buttons with a soft brush
Posted on Apr 15, 2010
pankaj_dic
  • 1252 Answers
SOURCE: When im doing something on
this happens when the program chip that control the functions in monitor does not work properly better rectify it with some technician
Posted on Jul 28, 2011
Pioneer receiver -no volume or volume display on screen. As if the function has disappeared. Knob still turns; just NO effect
Did the volume control get an impact? Could be internal damage to the digital control. Did it act up prior to this non-function, like volume went up on a down command or jump up or down when a slight turn was made? Thnose would reinforce a damaged volume control.
Jun 02, 2015 | Pioneer Audio Players & Recorders
Yamaha receiver picture disappears and reappears when changing volume
I had the same problem with HDMI input to the RX-V373 from a DirecTV receiver. The RX-V373 volume display and menus on the screen are HD only, which forces the monitor to switch modes when viewing SD.
My solution was to turn off 480i and 480p signals from the DirecTV receiver, and also turn off its native output. The DirecTV receiver then upconverts SD signals to HD. Changing RX-V373 volume then doesn't affect monitor video mode.
May 10, 2012 | Yamaha Audio Players & Recorders
Suddenly my yamaha Rx-v2300 only works to provide sound at nearly full volume to get any sound at all. This then comes with a background buzz. This only occurs while getting cable TV signal, using other...
I'm assuming you have a cable converter box (set-top box) that you have hooked to your receiver. Check the box volume using the cable company's remote control. These boxes frequently have variable audio output, and if you turn the volume down on the box you'll have the symptom you're describing. When you press the volume up or down buttons on the remote, you'll usually see a volume bar on the TV screen. As you raise the volume, there may be a point marked by an arrow, which is where you should set the volume. On some boxes, when you get to a certain level the words "best stereo" appear, and that's where to set it. If your box doesn't have some indication like this just leave the volume set 3/4 or full up. Then the volume on the receiver should function properly with the cable TV input.
Jan 12, 2011 | Audio Players & Recorders
Black box appears in middle of screen
Hello tinycc88,
turn off the TEXT MODE in the closed caption menu.
tvdan
Mar 15, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Sound vibrates
Test it by moving the bass and treble up and down. If the buzzing seems disappear at lower volumes with little bass and appears from one side only, it is probably a blown speaker on that side.
If the buzzing is apparent even at very low volumes or from both sides, it is probably an audio board issue. I am not certain if your model has a separate audio board or that functionality resides on the main board.
Dec 21, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Black box on screen
go into menu find
cc settings and
change setting to off
(make note of the one thats
causing the problem)
Dec 02, 2007 | Sansui DTV2760 27" TV
Jvc flat screen television model AV32F713 Black box on screen.
On the reomte control (bottom) left of the sleep button is a cc button, push that until "OFF" appears on the screen. The close caption box should disappear. It worked for me, finally.
Nov 29, 2007 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
HP W19b LCD Monitor Logo
420 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
