Question about Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C)
Installing Wireless-g I want to install the wireless-g notebook adapter on my laptop, atm i have a wire connection to my internet
  • 197 Answers
Ok..do you have the drivers? go here for them
www.linksys.com
Posted on Jun 16, 2008
I already installed the right driver for my Wireless Adapter of my laptop but I cant connect to the internet through wireless connection. It say's their "The driver successfully installed used Fou
Did you reboot after install? What does it say when you try to connect? Why did you have to re-install the wireless adapter driver? Did you download the driver from Asus?
Jan 08, 2013 | ASUS Eee PC 1215BPU17BK 121Inch Netbook
I bought a TP-link TL-WN821N wireless network USB adapter. I installed the driver on my desktop and I cant connect to our network nor the internet. I connected it to my laptop and deactivated the...
Dear Joeri_troch This is Howard from TP-LINK Support Force. Could you please check if your desktop has recognized the wireless adapter? And can you see Wireless Network Connection icon?
TP-LINK Support Force http://www.tp-link.com/en/support/ http://www.facebook.com/TPLINK
Sep 17, 2011 | TP-LINK TL-WN821N (TPLINKWN821N) 802.11b...
My netbook tells me to reset my wireless adapters Im trying to get wireless internet. It tells me there a network to connect to but it won't let me connet to it.
Hi
For uninstall the driver of Wireless adapters follow the mention below instruction.
  • Go to the control panel and click the Add & Remove program.
  • You see the install driver list you have to select the your wireless adapters and click the remove.
  • After few min you driver is uninstall the window show you driver uninstalling finish.
  • Then reboot you computer.
  • After rebooting you get New hardware found window in start up the notebook,take the wireless driver installation CD and put the notebook CD-ROM.
  • And new hardware found window click next, automatic he install the driver in CD, after complete the driver installation reboot you laptop once more.
  • Now you wireless adapter connect to Internet and your problem will solve.
If my answer solve you problem then give me 4 thum
Thanks
Aug 24, 2011 | Acer Aspire One D255 Netbook
How can i connect a wireless internet connection with a compaq armada E500
Get a PCMCIA to USB2 adapter that has an external 5 Volt connection to it to supply the higher current for the wireless adapter. The power can come from the USB via USB adapter cable
After installing the adapter, the USB wireless device should be installed just like in any later notebook. The wireless device requires USB2 and high power. and won't work off a powered hub.
Feb 05, 2010 | Compaq Armada E500 Notebook
Has An Acer Travelmate 243LC laptop got a build-in Wireless?
The link below will take you to a page on the Acer Web site that shows the specs for this laptop. According to the specs, this laptop does not come with onboard wireless (if this feature were part of the system, it would be listed in the specs). Also, you can check Device Manager to see if you have a Wireless Adapter listed under Network Adapters. If you don't see any type of Wireless adapter listed then you'll definitely know that your laptop doesn't have it built in.
To access Device Manager:
Right-click My Computer
Click Properties
Click Manage
In the left navigation pane, click Device Manager.
In the larger window, scroll down the list to Network Adapters.
Expand the Network Adapters tree to see the installed adapters.
http://www.acersupport.com/notebook/html/tm243lc_specs.html
However, the specs do show that this laptop has 2 PC Card slots. These slots give you at least a couple of options for connecting to the Internet. You can buy an Air Card that is installed in one of the PC Card slots when you want to use it to access the Internet. My company used to provide Air Cards for laptop users through AT&T. The advantage is that you have an uninterrupted connection to the Internet no matter your location.
You can also buy a WiFi card that fits into a PC Card slot. This card will be your Wireless NIC (adapter) providing you with the means to set up connections to wireless networks. Linksys is a pretty good brand and fairly easy to install and support. After installation and configuration, you can pop the card in your PC Card slot anytime you want to connect to a Wireless network then remove it when it's no longer needed.
I hope this helps you connect wirelessly using your laptop. Please rate this solution and thanks for using Fixya.
Mar 28, 2009 | Acer TravelMate 243LC Notebook
Can't connect To internet w/ Wireless
try uninstalling it and re-installing it. the problem may be with its drivers.
Jan 24, 2009 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Don't have wireless connection on my Toshiba notebook.
Make sure the drivers are installed for your wireless adapter. XP sometimes overlooks adapters during installation. Check the Device Manager for any yellow exclamation points. If you find one, uninstall it and click on the top item (your computer). Right-click the same device and then click Scan for Hardware Changes. You should have your drivers disk ready. The device will likely install, but be unable to find drivers. Point XP to your drivers disk and it should install the drivers for you.
BTW, if you don't have a drivers disk, check your system BIOS for the chipset and google for "<chipset number/name> Windows XP drivers". You should be able to find the drivers and download them from the wired connection before trying the above instructions for reinstalling the wifi drivers.
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
Nov 17, 2008 | Toshiba Satellite A135-S4527 Notebook
Linksys WPC54G Wireless-G Notebook... Problem:
Your computer locking up could be a spyware or virus program taking over your machine as soon as you get an internet connection.
Try connecting the laptop to a wired connection and see if it does the same thing.
Run some virus scans from trend micro.
If you can re-install the software for the wireless card. This might help too.
Firefox can freeze your system but highly unlikely from a fresh install.
best wishes.
Oct 31, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Open Questions:
Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C) Logo
57 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
