Question about GPS
I have a citroen C5 2.2 hdi. car is showing engine immobiliser fault. key seems to be doing nothing. sometimes will lock and unlock car but still it will not start it.I have changed the battery in the key. HELP Please!
  • 5370 Answers
SOURCE: I lost my key for
For making you new keys work,you will have to get your car key chips programmed.This can be done at dealer.Also a local locksmith can do this programming.But in some case the locksmith programming does not help,in that case the keys chips are to be programmed with car dealer only.The immobilizer is connected to the car ignition switch harness and ECU ( ELECTRONIC CONTROL MODULE) Also known as cars computer.--------- The system of working is as follows:---- When you insert the key in ignition the key gets detected by the ECU and ECU sends the car immobilizer to accept the key. But if you use new keys which are not programmed then ,ECU will not send the message to immobilizer to accept the key. ------------ Disarming the immobilizer is actually not advisable,but yes it can be done,but its not that easy.You will have to disconnect the immobilizer wiring from ignition harness switch as well as you will have to unplug the immobilizer connector from ECU also.This will disconnect the immobilizer.But if you disconnect wrong wires then car ignition switch will get disconnected and car will not get started at all.You will have to check ignition wiring by meter.The live wire is mostly 12 volt for ignition.So you can disconnect the other wire from ignition harness switch to disconnect immobilizer.The immobilizer wire can differ in color,but mostly the color of wire is purple/green.A local car garage can do this for you,They will check the wiring with meter and disconnect the immobilizer wire instead of disconnecting ignition switch.------------ But in all this options getting the key reprogrammed is most advisable option.In key programming,it will not take much time and also it will not disturb the car wiring and functions also. -------------- Also for more help on bypassing the anti theft system in your car.Click this link directly:--- http://newrockies.com/the-problem-and-the-solution/ ------------- This link is just to know how the anti theft system works.-------- ----------This will help.Thanks.Helpmech.
Posted on Feb 11, 2011
  • 5370 Answers
SOURCE: XFfalcon fairmont changed battery wont
As per your problem it indicates that your security system is blocking the engine to start.This system requires key learning and a parameter reset via scan tool by dealer, to reset the security system.This will let the car to start.---- ---------- There is one manual reset procedure, which you can try before taking it to dealer.------- Insert the key into ignition and turn the ignition to ON position and let the key remain in ignition On position for next 30 minutes.Then exactly after 30 minutes turn the key to off then again ON and check.It will start, This is reset procedure.but if this not helping then it has to be reset by scan tool.This is done by dealer.----- This should help.Thanks.Helpmech.
Posted on Jul 04, 2011
  • 16 Answers
SOURCE: citroen c3 14hdi heater blower on constant
sounds like the control unit is bad.
Posted on Feb 01, 2009
  • 89 Answers
SOURCE: Immobiliser problem - 94' Golf Mk3 GTI 2lt 8 valve
just unplug the immobiliser unit. its behind the glove compartment for rhd models.
Posted on Mar 18, 2009
citroenchris
  • 600 Answers
SOURCE: citroen picasso battery charge fault
Probably a short brush in the alternator, if you can find a specialist auto electrician it is possable to replace the brush/control pack but most places want to stripe you for an exchange unit.
Posted on Jan 02, 2010
Citroen saxo vtr problems
I have answered this one many times before... repalace your battery in your fob. Partial signal can also set a fault...Often these questions are answered between 8 and 9:30 in the morning joyfully by your service desk .... sometimes when they are in a rush their brain reject the question out of hand .... so start off the conversation with compliments and a positive point about their nice voice be surprised how many flies can be caught with honey.
Aug 09, 2014 | Vehicle Parts & Accessories
Anti pollution fault on my peugeot 308
my 2008 308 shows anti pollution fault,what do i do now.? any help please
Dec 23, 2012 | 2008 Peugeot 308 1.6
Citreon picasso 1.6 hdi engine code errors P1166 & P0193
Still i have p0193 fault and no pick computersay fuel rail sensor but i was diconect the first injector electric swich then this pro
Jul 09, 2012 | Citroen Xsara Cars & Trucks
How to set timing up on 1.6 Hdi engine without reluctor after cambelt snapped
please state year and model of this engine as they do change ,i think its a citreon something like a berlingo or maybe a 306 or whatever but need the year as the common rail is different to the injector pump model or is it a dreaded my favourite motor and thats a renault
Feb 29, 2012 | Citroen Cars & Trucks
Where the bloody hell do i put the locking tool in the crank of a citroen relay 2.2 hdi ! Thanks guys
Sorry i can't help,re-post the question and see if someone else can,citroen relay??? I don't know what you need.
Jan 23, 2010 | 2005 Peugeot 405
Peugeot 406 hdi executive 2002 will not start
immobiliser problem main dealer me thinks
Aug 18, 2009 | Peugeot 406 Cars & Trucks
Engine immobiliser fault light on after battery flat
There might be an immobiliser fault or a problem with the key transponder but try the following before you call the dealer or local auto locksmith.
Disconnect the battery and leave overnight. Next morning open the car, put the ignition key in and switch on the ignition - then connect the battery.
Sep 17, 2017 | Vehicle Parts & Accessories
Peugeot 307 hdi 2002 5 door will not start
Check the fob battery because if the battery has gone then you can't immobilise the car immobiliser which in turn doesn't let you start the engine however it cranking. open the bonnet and remove the clips of car battery for a good 15-20 minutes and put them back and check your remote key and try to start your car. If nothing happens then let your car diagnosed by a experienced mechanic who is able to read out the ecu codes.
Aug 20, 2008 | 2005 Peugeot 405
GPS Logo
1,847 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
