Question about B&W Bowers and Wilkins Zeppelin iPod Music Speaker System
The red light on my speaker system is constantly flashing and wont stop even if I switch off and on again.
    Scholar:
  • 159 Answers
Power supply board, b and w know this is a problem, contact their service for a repair.
Posted on Jan 14, 2011
When i plug in my radio it wont come on and when i pull the face plate off the little red light flashes and when i hit the reset button it still flashes
Double check both power (red for constant, yellow for switched) and your ground. Also, if it's switched, you need to have the key in the on position. check to see if this helps.
Aug 29, 2011 | Car Audio & Video
My ps seems to have crashed!! it will only turn on momentarily,the light goes blue for a second, flashes orange?? then turns off!! the red light flashes till i touch the power on sensor,beeps then goes...
Hi tomtoremar,
Are you seeing any flashing red/yellow lights?
If so this is the red light error and you will find that is why the system will not turn on.
Why Does It Happen?
The GPU and the CPU are the 2 main chips in the system and they deal with all of the number crunching however they can get very hot and if they lose connection the system will either freeze up or turn off and give you the red flashing light.
How To Fix?
The key is stopping the heat build up and you can either send it in and they will fix it for you.
Bear in mind that for the PS3 red flashing light error you will be waiting for about 4 weeks and it will also cost you $150 for the repair bill!
Other Ways To Fix?
You can also use a good PS3 Repair Guide to fix it and this will show you how to stop the heat build up with a few household items.
Just make sure that you get a good guide there are some good ones out there!
Click Here For A Complete Review Of All Available PS3 Repair Guides.
Hope this helps and any questions let me know?
Mar 27, 2011 | Sony Playstation 3 (PS3) Console
Power button turns green, flashes and then turns red and flashes.
While working it stops and flashes red approximately 2 seconds interval
Causes
Protection circuit is activated depending on the temperature of the surroundings
Remedy
Switch off the power supply and power on after the temperature have reduced.
While working it stops and flashes red approximately 0.5 seconds interval
Causes
1.Using speakers having less impedance than the specified.
2.If speaker core wire touch each other Protection circuit is activated
Even applying power red flashes 0.5 seconds interval
Cause
Amplifier circuit has failed
Remedy
Switch off the power and contact denon service centre
Thank You
Sep 07, 2010 | Denon AVR-789 Receiver
My Panasonic SC-HT995W keeps on flashing W and the rear speakers wont work. Ive tried turning off all other wireless devices but it still persists
I had exactly the same problem. My unit worked fine until a loose power cable resulted in the receiver being turned on and off a couple of times in quick succession and then after this the a/c in light on the rear speaker was lit but the wireless link light would not come on (and the 'W' on the main unit flashed constantly). The solution for me was basically a reboot. This is what I did;
- unplug the wireless receiver
- unplug the main unit
- remove the digital transceiver unit from its slot in the back of the main unit
- plug the main unit back in and turn it on - the 'W' won't flash as the transceiver has been removed (not sure if you if it's necessary but I made sure it was producing sound to the front speakers)
- unplug the main unit again
- reinsert the digital transceiver
- plug the main unit back in, turn it on and set it to produce output/sound (the 'W' will be flashing)
- then plug the wireless receiver back in again
...presto the link is made, the 'W' stops flashing and the rear speakers work again.
Hope this elaborate reboot works as well for you as it did for me.
Aug 08, 2010 | Panasonic SC-HT995W System
Need color codes for 1995 ford explorer with premium sound system. Ive found my constant, ground, switched, and memory i need the color codes for the other harness
For 1995 Ford Explorer Car Stereo check this Wiring Diagram...
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Good luck.
Jul 07, 2010 | 1995 Ford Explorer
Gauge light on?
Gauge light illuminates when the ignition is switched on. It should extinguish as soon as the engine starts.
If it illuminates with the engine running, it indicates a malfunction with the engine management system. Have this checked as soon as possible.
If it flashes when driving, reduce the vehicle speed immediately until the light illuminates constantly. If it continues to flash, avoid heavy acceleration and high engine speed, stop the vehicle and have it checked immediately.
On some vehicles this light may be red – again stop the vehicle and seek assistance.
If it is safe to do so, try stopping the vehicle, switching off the engine, wait two minutes, then restarting the engine to reset the engine management system.
With the light illuminated, the vehicle is still safe to drive as long as no other faults are apparent with the engine. Have the vehicle checked by a dealer or garage as soon as possible to avoid any damage being caused to the catalytic converter.
Jun 24, 2009 | 1998 Toyota Corolla
B&W Bowers and Wilkins Zeppelin iPod Music Speaker System  Logo
50 people viewed this question
Top B&W Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Are you a B&W Audio Player and Recorder Expert? Answer questions, earn points and help others
